bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) override |
| Gather information about an object referred by the globalid . More...
vtkTypeUInt32 | RegisterDataInformation (vtkTypeUInt32 globalid, unsigned int port, vtkPVInformation *information) |
| Update the data information for a given proxy with the given globalid. More...
void | UpdateIdMap (vtkTypeUInt32 *idMapArray, int size) |
void | ResetIdMap () |
virtual void | PushState (vtkSMMessage *message) |
| Push the state message. More...
virtual void | PullState (vtkSMMessage *message) |
| Pull the state message from the local SI object instances. More...
virtual void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) |
| Execute a command on the given processes. More...
virtual const vtkClientServerStream & | GetLastResult () |
| Returns the response of the ExecuteStream() call from the location. More...
virtual void | UnRegisterSIObject (vtkSMMessage *message) |
| Notify that the given SIObject is not used anymore . More...
virtual void | RegisterSIObject (vtkSMMessage *message) |
| Notify that the given SIObject is used. More...
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
| Returns a vtkSIObject or subclass given its global id, if any otherwise return nullptr;. More...
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Return a vtkObject given its global id if any otherwise return nullptr;. More...
void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkObject *obj) |
| Register a remote object. More...
void | UnRegisterRemoteObject (vtkTypeUInt32 globalid) |
| Unregister a remote object. More...
int | GetNumberOfProcesses () |
| Returns the number of processes. More...
virtual vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () |
| Provides the next available identifier. More...
virtual vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) |
| Return the first Id of the requested chunk. More...
void | PushStateSatelliteCallback () |
void | ExecuteStreamSatelliteCallback () |
void | GatherInformationStatelliteCallback () |
void | RegisterSIObjectSatelliteCallback () |
void | UnRegisterSIObjectSatelliteCallback () |
virtual void | GetAllRemoteObjects (vtkCollection *collection) |
| Allow the user to fill a vtkCollection with all RemoteObjects This is useful when you want to hold a reference to them to prevent any deletion across several method call. More...
void | GarbageCollectSIObject (int *clientIds, int nbClients) |
| Delete SIObject that are held by clients that disappeared from the given list. More...
virtual vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the interpreter. More...
virtual vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| Provides access to the proxy definition manager. More...
void | SetMPIMToNSocketConnection (vtkMPIMToNSocketConnection *) |
| Get/Set the socket connection used to communicate between data=server and render-server processes. More...
virtual vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () |
virtual void | Modified () |
