view for comparative visualization/ film-strips. More...
#include <vtkPVComparativeView.h>
void | Initialize (unsigned int) |
Provides empty handlers to simulate the vtkPVView API. More... | |
void | StillRender () |
Call StillRender() on the root view. More... | |
void | InteractiveRender () |
Call InteractiveRender() on the root view. More... | |
void | Initialize (vtkSMViewProxy *rootView) |
Initialize the vtkPVComparativeView giving the root view proxy to be used to create the comparative views. More... | |
void | Build (int dx, int dy) |
Builds the MxN views. More... | |
void | AddRepresentation (vtkSMProxy *) |
Adds a representation proxy to this view. More... | |
void | RemoveRepresentation (vtkSMProxy *) |
Removes a representation proxy from this view. More... | |
void | Update () |
Updates the data pipelines for all visible representations. More... | |
void | GetViews (vtkCollection *collection) |
Get all the internal views. More... | |
void | SetPPI (int) |
Satisfying vtkPVView API. More... | |
void | MarkOutdated () |
Marks the view dirty i.e. More... | |
void | PrepareForScreenshot () |
These methods mimic the vtkPVView API. More... | |
void | CleanupAfterScreenshot () |
vtkImageData * | CaptureWindow (int magX, int magY) |
void | SetOverlayAllComparisons (bool) |
When set to true, all comparisons are shown in the same view. More... | |
virtual bool | GetOverlayAllComparisons () |
virtual int * | GetDimensions () |
Returns the dimensions used by the most recent Build() request. More... | |
virtual void | GetDimensions (int &, int &) |
virtual void | GetDimensions (int [2]) |
virtual vtkSMViewProxy * | GetRootView () |
Returns the root view proxy. More... | |
void | SetViewSize (int x, int y) |
ViewSize, ViewPosition need to split up among all the component views correctly. More... | |
void | SetViewPosition (int x, int y) |
void | SetTileScale (int x, int y) |
When saving screenshots with tiling, these methods get called. More... | |
void | SetTileViewport (double x0, double y0, double x1, double y1) |
virtual void | SetSpacing (int, int) |
Set spacing between views. More... | |
void | SetSpacing (int [2]) |
virtual int * | GetSpacing () |
virtual void | GetSpacing (int &, int &) |
virtual void | GetSpacing (int [2]) |
void | AddCue (vtkSMComparativeAnimationCueProxy *) |
Add/Remove parameter cues. More... | |
void | RemoveCue (vtkSMComparativeAnimationCueProxy *) |
virtual double | GetViewTime () |
Get/Set the view time. More... | |
void | SetViewTime (double time) |
virtual void | Modified () |
static vtkPVComparativeView * | New () |
static vtkPVComparativeView * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkPVComparativeView () | |
~vtkPVComparativeView () override | |
void | UpdateViewLayout () |
Update layout for internal views. More... | |
void | SetRootView (vtkSMViewProxy *) |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | Dimensions [2] |
int | ViewSize [2] |
int | ViewPosition [2] |
int | Spacing [2] |
double | ViewTime |
bool | OverlayAllComparisons |
bool | Outdated |
vtkSMViewProxy * | RootView |
bool | Debug |
vtkTimeStamp | MTime |
vtkPVComparativeView is the view used to generate/view comparative visualizations/film-strips. This is not a proxy
Definition at line 24 of file vtkPVComparativeView.h.
Definition at line 28 of file vtkPVComparativeView.h.
Definition at line 34 of file vtkPVComparativeView.h.
void vtkPVComparativeView::StillRender | ( | ) |
void vtkPVComparativeView::InteractiveRender | ( | ) |
void vtkPVComparativeView::Initialize | ( | vtkSMViewProxy * | rootView | ) |
This method simply creates the MxN internal view modules. It does not generate the visualization i.e. play the animation scene(s). This method does nothing unless the dimensions have changed, in which case it creates new internal view modules (or destroys extra ones). Note that the it's the responsibility of the application to lay the views out so that they form a MxN grid.
void vtkPVComparativeView::SetOverlayAllComparisons | ( | bool | ) |
Otherwise, they are tiled in separate views.
void vtkPVComparativeView::AddRepresentation | ( | vtkSMProxy * | ) |
void vtkPVComparativeView::RemoveRepresentation | ( | vtkSMProxy * | ) |
void vtkPVComparativeView::Update | ( | ) |
void vtkPVComparativeView::GetViews | ( | vtkCollection * | collection | ) |
The views should only be used to be laid out by the GUI. It's not recommended to directly change the properties of the views.
Definition at line 112 of file vtkPVComparativeView.h.
Definition at line 125 of file vtkPVComparativeView.h.
Not to be confused with tile scale and viewport setup on tile display.
We don't need to do anything here since the subviews have their own PPI settings.
Definition at line 148 of file vtkPVComparativeView.h.
void vtkPVComparativeView::SetSpacing | ( | int | [2] | ) |
void vtkPVComparativeView::AddCue | ( | vtkSMComparativeAnimationCueProxy * | ) |
void vtkPVComparativeView::RemoveCue | ( | vtkSMComparativeAnimationCueProxy * | ) |
Definition at line 171 of file vtkPVComparativeView.h.
on next Update() it needs to regenerate the comparative vis by replaying the animation(s).
Definition at line 186 of file vtkPVComparativeView.h.
They do nothing here since each view internal view will call PrepareForScreenshot and CleanupAfterScreenshot explicitly when we capture the images from each of them as needed.
Definition at line 193 of file vtkPVComparativeView.h.
Definition at line 194 of file vtkPVComparativeView.h.
vtkImageData* vtkPVComparativeView::CaptureWindow | ( | int | magX, |
int | magY | ||
Definition at line 206 of file vtkPVComparativeView.h.
Definition at line 207 of file vtkPVComparativeView.h.
Definition at line 208 of file vtkPVComparativeView.h.
Definition at line 209 of file vtkPVComparativeView.h.
Definition at line 210 of file vtkPVComparativeView.h.
Definition at line 211 of file vtkPVComparativeView.h.
Definition at line 212 of file vtkPVComparativeView.h.
Definition at line 215 of file vtkPVComparativeView.h.
