object for general options. More...
#include <vtkPVGeneralSettings.h>
enum | { DEFAULT_TIME_STEP_UNCHANGED, DEFAULT_TIME_STEP_FIRST, DEFAULT_TIME_STEP_LAST } |
Enum for DefaultTimeStep. More... | |
enum | RealNumberNotation { MIXED = 0, SCIENTIFIC, FIXED, FULL } |
enum | { ALL_IN_ONE = 0, SEPARATE_DISPLAY_PROPERTIES = 1, SEPARATE_VIEW_PROPERTIES = 2, ALL_SEPARATE = 3 } |
void | SetInheritRepresentationProperties (bool val) |
Forwarded for vtkSMParaViewPipelineControllerWithRendering. More... | |
void | SetIgnoreNegativeLogAxisWarning (bool val) |
bool | GetIgnoreNegativeLogAxisWarning () |
void | SetAutoConvertProperties (bool val) |
Automatically convert data arrays as needed by filters including converting cell arrays to point arrays, or vice versa, and extracting single components from multi-component arrays. More... | |
bool | GetAutoConvertProperties () |
virtual int | GetBlockColorsDistinctValues () |
Determines the number of distinct values in vtkBlockColors. More... | |
virtual void | SetBlockColorsDistinctValues (int) |
virtual bool | GetAutoApply () |
Automatically apply changes in the 'Properties' panel. More... | |
virtual void | SetAutoApply (bool) |
virtual int | GetAutoApplyDelay () |
Get/Set delay for auto apply. More... | |
virtual void | SetAutoApplyDelay (int) |
virtual bool | GetAutoApplyActiveOnly () |
virtual void | SetAutoApplyActiveOnly (bool) |
virtual std::string | GetDefaultViewType () |
Get/Set the default view type. More... | |
virtual void | SetDefaultViewType (std::string) |
virtual std::string | GetInterfaceLanguage () |
Get/Set the default interface language. More... | |
virtual void | SetInterfaceLanguage (std::string) |
void | SetCacheGeometryForAnimation (bool val) |
Set when animation geometry caching is enabled. More... | |
bool | GetCacheGeometryForAnimation () |
void | SetAnimationGeometryCacheLimit (unsigned long val) |
Set the animation cache limit in KBs. More... | |
virtual unsigned long | GetAnimationGeometryCacheLimit () |
virtual void | SetAnimationTimeNotation (int) |
Set the notation for the animation time toolbar. More... | |
virtual int | GetAnimationTimeNotation () |
virtual void | SetAnimationTimeShortestAccuratePrecision (bool) |
Get/Set the usage of shortest accurate precision instead of actual precision for animation time. More... | |
virtual bool | GetAnimationTimeShortestAccuratePrecision () |
virtual void | SetAnimationTimePrecision (int) |
Set the precision of the animation time toolbar. More... | |
virtual int | GetAnimationTimePrecision () |
virtual void | SetShowAnimationShortcuts (bool) |
Set when animation shortcuts are shown. More... | |
virtual bool | GetShowAnimationShortcuts () |
virtual void | ShowAnimationShortcutsOn () |
virtual void | ShowAnimationShortcutsOff () |
virtual void | SetResetDisplayEmptyViews (bool) |
Set whether to reset display when showing a representation in an empty view. More... | |
virtual bool | GetResetDisplayEmptyViews () |
virtual void | ResetDisplayEmptyViewsOn () |
virtual void | ResetDisplayEmptyViewsOff () |
virtual void | SetRealNumberDisplayedNotation (int) |
Get/Set the notation of real number displayed in widgets or views. More... | |
virtual int | GetRealNumberDisplayedNotation () |
virtual void | SetRealNumberDisplayedShortestAccuratePrecision (bool) |
Get/Set the usage of shortest accurate precision instead of actual precision for real numbers. More... | |
virtual bool | GetRealNumberDisplayedShortestAccuratePrecision () |
virtual void | SetRealNumberDisplayedPrecision (int) |
Get/Set the precision of real number displayed in widgets or views. More... | |
virtual int | GetRealNumberDisplayedPrecision () |
virtual void | SetFullNotationLowExponent (int) |
Get/Set the low exponent used with full notation. More... | |
virtual int | GetFullNotationLowExponent () |
virtual void | SetFullNotationHighExponent (int) |
Get/Set the high exponent used with full notation. More... | |
virtual int | GetFullNotationHighExponent () |
virtual void | SetPropertiesPanelMode (int) |
Properties panel configuration. More... | |
virtual int | GetPropertiesPanelMode () |
virtual void | SetLockPanels (bool) |
Set whether to dock widgets into place. More... | |
virtual bool | GetLockPanels () |
void | SetLoadAllVariables (bool val) |
Load all variables when loading a data set. More... | |
bool | GetLoadAllVariables () |
void | SetLoadNoChartVariables (bool val) |
Load no variables when showing a 2D chart. More... | |
bool | GetLoadNoChartVariables () |
virtual void | SetGUIFontSize (int) |
Get/Set the GUI font size. More... | |
virtual int | GetGUIFontSize () |
virtual void | SetGUIOverrideFont (bool) |
Get/Set whether the GUIFontSize should be used. More... | |
virtual bool | GetGUIOverrideFont () |
virtual void | SetColorByBlockColorsOnApply (bool) |
Automatically color by vtkBlockColors if array is present on Apply . More... | |
virtual bool | GetColorByBlockColorsOnApply () |
void | SetEnableStreaming (bool) |
Turn on streamed rendering. More... | |
virtual bool | GetEnableStreaming () |
virtual void | EnableStreamingOn () |
virtual void | EnableStreamingOff () |
void | SetUseAcceleratedFilters (bool) |
Enable use of accelerated filters where available. More... | |
bool | GetUseAcceleratedFilters () |
virtual void | UseAcceleratedFiltersOn () |
virtual void | UseAcceleratedFiltersOff () |
virtual bool | GetSelectOnClickMultiBlockInspector () |
ActiveSelection is hooked up in the MultiBlock Inspector such that a click on a/multiple block(s) selects it/them. More... | |
virtual void | SetSelectOnClickMultiBlockInspector (bool) |
virtual void | Modified () |
static vtkPVGeneralSettings * | New () |
static vtkPVGeneralSettings * | SafeDownCast (vtkObject *o) |
static vtkPVGeneralSettings * | GetInstance () |
Access the singleton. More... | |
static int | GetNumberOfCallbackThreads () |
Sets the number of threads that are used for vtkPVSession::ThreadedCallbackQueue . More... | |
static void | SetNumberOfCallbackThreads (int) |
static int | GetNumberOfSMPThreads () |
Sets the number of threads that are used by vtkSMPTools . More... | |
static void | SetNumberOfSMPThreads (int) |
static vtkObject * | New () |
vtkPVGeneralSettings ()=default | |
~vtkPVGeneralSettings () override=default | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
vtkPVGeneralSettings keeps track of general options in a ParaView application. This is a singleton. All calls to vtkPVGeneralSettings::New() return a pointer to the same global instance (with reference count incremented as expected).
Definition at line 23 of file vtkPVGeneralSettings.h.
Definition at line 27 of file vtkPVGeneralSettings.h.
anonymous enum |
Enumerator | |
DEFAULT_TIME_STEP_UNCHANGED | |
DEFAULT_TIME_STEP_FIRST | |
DEFAULT_TIME_STEP_LAST |
Definition at line 105 of file vtkPVGeneralSettings.h.
anonymous enum |
Enum for ScalarBarMode.
Enumerator | |
AUTOMATICALLY_SHOW_AND_HIDE_SCALAR_BARS | |
AUTOMATICALLY_HIDE_SCALAR_BARS | |
MANUAL_SCALAR_BARS |
Definition at line 116 of file vtkPVGeneralSettings.h.
Enumerator | |
MIXED | |
SCIENTIFIC | |
FIXED | |
FULL |
Definition at line 142 of file vtkPVGeneralSettings.h.
anonymous enum |
Enumerator | |
ALL_IN_ONE | |
SEPARATE_DISPLAY_PROPERTIES | |
SEPARATE_VIEW_PROPERTIES | |
ALL_SEPARATE |
Definition at line 245 of file vtkPVGeneralSettings.h.
protecteddefault |
overrideprotecteddefault |
void vtkPVGeneralSettings::SetAutoConvertProperties | ( | bool | val | ) |
Forwards the call to vtkSMInputArrayDomain::SetAutomaticPropertyConversion.
bool vtkPVGeneralSettings::GetAutoConvertProperties | ( | ) |
This array is added to each block if the dataset is a composite dataset. The array has one value set to (blockIndex % BlockColorsDistinctValues)
Default is false.
Default is false.
Not exposed in the UI. Default is 0.
Default is false.
Default is false.
Default is en
Default is en
void vtkPVGeneralSettings::SetScalarBarMode | ( | int | ) |
void vtkPVGeneralSettings::SetCacheGeometryForAnimation | ( | bool | val | ) |
bool vtkPVGeneralSettings::GetCacheGeometryForAnimation | ( | ) |
void vtkPVGeneralSettings::SetAnimationGeometryCacheLimit | ( | unsigned long | val | ) |
Accepted values are MIXED, SCIENTIFIC, and FIXED.
void vtkPVGeneralSettings::SetInheritRepresentationProperties | ( | bool | val | ) |
void vtkPVGeneralSettings::SetIgnoreNegativeLogAxisWarning | ( | bool | val | ) |
bool vtkPVGeneralSettings::GetIgnoreNegativeLogAxisWarning | ( | ) |
void vtkPVGeneralSettings::SetLoadAllVariables | ( | bool | val | ) |
bool vtkPVGeneralSettings::GetLoadAllVariables | ( | ) |
void vtkPVGeneralSettings::SetLoadNoChartVariables | ( | bool | val | ) |
bool vtkPVGeneralSettings::GetLoadNoChartVariables | ( | ) |
This is used only if GUIOverrideFont is true.
void vtkPVGeneralSettings::SetEnableStreaming | ( | bool | ) |
void vtkPVGeneralSettings::SetUseAcceleratedFilters | ( | bool | ) |
bool vtkPVGeneralSettings::GetUseAcceleratedFilters | ( | ) |
Default is true.
Default is true.
Definition at line 355 of file vtkPVGeneralSettings.h.
Definition at line 356 of file vtkPVGeneralSettings.h.
Definition at line 357 of file vtkPVGeneralSettings.h.
Definition at line 358 of file vtkPVGeneralSettings.h.
Definition at line 359 of file vtkPVGeneralSettings.h.
Definition at line 360 of file vtkPVGeneralSettings.h.
Definition at line 361 of file vtkPVGeneralSettings.h.
Definition at line 362 of file vtkPVGeneralSettings.h.
Definition at line 363 of file vtkPVGeneralSettings.h.
Definition at line 364 of file vtkPVGeneralSettings.h.
Definition at line 365 of file vtkPVGeneralSettings.h.
Definition at line 366 of file vtkPVGeneralSettings.h.
Definition at line 367 of file vtkPVGeneralSettings.h.
Definition at line 368 of file vtkPVGeneralSettings.h.
Definition at line 369 of file vtkPVGeneralSettings.h.
Definition at line 370 of file vtkPVGeneralSettings.h.
Definition at line 371 of file vtkPVGeneralSettings.h.
Definition at line 372 of file vtkPVGeneralSettings.h.
Definition at line 373 of file vtkPVGeneralSettings.h.
Definition at line 374 of file vtkPVGeneralSettings.h.
Definition at line 375 of file vtkPVGeneralSettings.h.
Definition at line 376 of file vtkPVGeneralSettings.h.
Definition at line 377 of file vtkPVGeneralSettings.h.
Definition at line 378 of file vtkPVGeneralSettings.h.
Definition at line 379 of file vtkPVGeneralSettings.h.
Definition at line 380 of file vtkPVGeneralSettings.h.
