virtual void | GoToFirstItem ()=0 |
| Move the iterator to the beginning. More...
virtual void | InitTraversal () |
| Reset the iterator and move it to the head. More...
virtual void | GoToNextItem ()=0 |
| Move the iterator to the next item. More...
virtual void | GoToNextGroup ()=0 |
| Move the iterator to the next group. More...
virtual bool | IsDoneWithTraversal ()=0 |
| Test whether the iterator is currently pointing to a valid item. More...
virtual void | AddTraversalGroupName (const char *groupName)=0 |
virtual const char * | GetGroupName ()=0 |
| Return the current group name or nullptr if Next() was never called. More...
virtual const char * | GetProxyName ()=0 |
| Return the current proxy name or nullptr if Next() was never called. More...
virtual bool | IsCustom () |
| Return true if the current definition has been defined in the Custom scope. More...
virtual vtkPVXMLElement * | GetProxyDefinition ()=0 |
| Return the current XML proxy definition. More...
virtual vtkPVXMLElement * | GetProxyHints ()=0 |
| Return the current XML proxy hints. More...
virtual void | Modified () |
