singleton/facade to vtkSMSessionProxyManager More...
#include <vtkSMProxyManager.h>
struct | LoadStateInformation |
struct | ModifiedPropertyInformation |
struct | RegisteredProxyInformation |
struct | StateChangedInformation |
enum | eventId { ActiveSessionChanged = 9753 } |
vtkSMSession * | GetActiveSession () |
Returns the current active session. More... | |
vtkSMSessionProxyManager * | GetActiveSessionProxyManager () |
Convenient method to get the active vtkSMSessionProxyManager. More... | |
vtkSMSessionProxyManager * | GetSessionProxyManager (vtkSMSession *session) |
Return the corresponding vtkSMSessionProxyManager and if any, then create a new one. More... | |
virtual void | SetBlockProxyDefinitionUpdates (bool) |
virtual bool | GetBlockProxyDefinitionUpdates () |
virtual void | BlockProxyDefinitionUpdatesOn () |
virtual void | BlockProxyDefinitionUpdatesOff () |
void | UpdateProxyDefinitions () |
std::string | GetUniqueProxyName (const char *groupname, const char *prefix, bool alwaysAppend=true) |
Given a group, returns a name not already used for proxies registered in the given group. More... | |
void | SetActiveSession (vtkSMSession *session) |
Set the active session. More... | |
void | SetActiveSession (vtkIdType sessionId) |
vtkSMProxy * | NewProxy (const char *groupName, const char *proxyName, const char *subProxyName=nullptr) |
Calls forwarded to the active vtkSMSessionProxyManager, if any. More... | |
void | RegisterProxy (const char *groupname, const char *name, vtkSMProxy *proxy) |
vtkSMProxy * | GetProxy (const char *groupname, const char *name) |
void | UnRegisterProxy (const char *groupname, const char *name, vtkSMProxy *) |
const char * | GetProxyName (const char *groupname, unsigned int idx) |
const char * | GetProxyName (const char *groupname, vtkSMProxy *proxy) |
void | SetUndoStackBuilder (vtkSMUndoStackBuilder *builder) |
Get/Set the undo-stack builder if the application is using undo-redo mechanism to track changes. More... | |
virtual vtkSMUndoStackBuilder * | GetUndoStackBuilder () |
virtual vtkSMPluginManager * | GetPluginManager () |
PluginManager keeps track of plugins loaded on various sessions. More... | |
virtual vtkSMReaderFactory * | GetReaderFactory () |
Provides access to the reader factory. More... | |
virtual vtkSMWriterFactory * | GetWriterFactory () |
Provides access to the writer factory. More... | |
virtual void | Modified () |
static vtkSMProxyManager * | SafeDownCast (vtkObject *o) |
static vtkSMProxyManager * | GetProxyManager () |
Provides access to the global ProxyManager. More... | |
static void | Finalize () |
Free the singleton. More... | |
static bool | IsInitialized () |
Allow to check if the Singleton has been initialized and has a reference to a valid ProxyManager. More... | |
static int | GetVersionMajor () |
These methods can be used to obtain the ProxyManager version number. More... | |
static int | GetVersionMinor () |
static int | GetVersionPatch () |
static const char * | GetParaViewSourceVersion () |
Returns a string with the format "paraview version x.x.x, Date: YYYY-MM-DD". More... | |
static vtkObject * | New () |
vtkSMProxyManager () | |
~vtkSMProxyManager () override | |
void | ConnectionsUpdated (vtkObject *, unsigned long, void *) |
Connections updated. More... | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Static Protected Member Functions | |
static vtkSMProxyManager * | New () |
Protected Attributes | |
vtkSMUndoStackBuilder * | UndoStackBuilder |
vtkSMPluginManager * | PluginManager |
vtkSMReaderFactory * | ReaderFactory |
vtkSMWriterFactory * | WriterFactory |
bool | BlockProxyDefinitionUpdates |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSMSessionProxyManager |
vtkSMProxyManager is a singleton/facade that creates and manages proxies. It maintains a map of vtkSMSessionProxyManager and delegate all proxy related call to the appropriate one based on the provided session.
Definition at line 35 of file vtkSMProxyManager.h.
Definition at line 38 of file vtkSMProxyManager.h.
Enumerator | |
ActiveSessionChanged |
Definition at line 164 of file vtkSMProxyManager.h.
Free the singleton.
Returns the major version number eg. if version is 2.9.1 this method will return 2.
Returns the minor version number eg. if version is 2.9.1 this method will return 9.
Returns the patch version number eg. if version is 2.9.1 this method will return 1.
vtkSMSession* vtkSMProxyManager::GetActiveSession | ( | ) |
If no active session is set, and there's only one registered vtkSMSession with vtkProcessModule, then that session is automatically treated as the active session.
void vtkSMProxyManager::SetActiveSession | ( | vtkSMSession * | session | ) |
It's acceptable to set the active session as nullptr (or 0 in case of sessionId), however GetActiveSession() may automatically pick an active session if none is provided.
void vtkSMProxyManager::SetActiveSession | ( | vtkIdType | sessionId | ) |
vtkSMSessionProxyManager* vtkSMProxyManager::GetActiveSessionProxyManager | ( | ) |
If no
vtkSMSessionProxyManager* vtkSMProxyManager::GetSessionProxyManager | ( | vtkSMSession * | session | ) |
vtkSMProxy* vtkSMProxyManager::NewProxy | ( | const char * | groupName, |
const char * | proxyName, | ||
const char * | subProxyName = nullptr |
Raises errors if no active session manager can be determined (using GetActiveSessionProxyManager()).
void vtkSMProxyManager::RegisterProxy | ( | const char * | groupname, |
const char * | name, | ||
vtkSMProxy * | proxy | ||
vtkSMProxy* vtkSMProxyManager::GetProxy | ( | const char * | groupname, |
const char * | name | ||
void vtkSMProxyManager::UnRegisterProxy | ( | const char * | groupname, |
vtkSMProxy * | |||
const char* vtkSMProxyManager::GetProxyName | ( | const char * | groupname, |
void vtkSMProxyManager::UpdateProxyDefinitions | ( | ) |
void vtkSMProxyManager::SetUndoStackBuilder | ( | vtkSMUndoStackBuilder * | builder | ) |
This provides access to the application-wide plugin manager.
Before using the reader factory, it is essential that it's configured correctly.
std::string vtkSMProxyManager::GetUniqueProxyName | ( | const char * | groupname, |
const char * | prefix, | ||
bool | alwaysAppend = true |
The prefix is used to come up with a new name. if alwaysAppend is true, then a suffix will always be appended, if not, the prefix may be used directly if possible. If there are multiple vtkSMSessionProxyManager instances in the application, this method tries to find a unique name across all of them.
staticprotected |
Update the active session accordingly.
friend |
Definition at line 222 of file vtkSMProxyManager.h.
Definition at line 229 of file vtkSMProxyManager.h.
Definition at line 230 of file vtkSMProxyManager.h.
Definition at line 231 of file vtkSMProxyManager.h.
Definition at line 232 of file vtkSMProxyManager.h.
Definition at line 234 of file vtkSMProxyManager.h.
