builds server manager undo sets and pushes them on the undo stack. More...
#include <vtkSMUndoStackBuilder.h>
virtual void | Begin (const char *label) |
Begins monitoring of the vtkSMProxyManager for undoable operations. More... | |
virtual void | End () |
Stops monitoring of the vtkSMProxyManager for undoable operations. More... | |
virtual void | PushToStack () |
If any undoable changes were recorded by the builder, this will push the vtkUndoSet formed on to the UndoStack. More... | |
virtual void | Clear () |
Discard all recorded changes that haven't been pushed on the UndoStack. More... | |
virtual bool | Add (vtkUndoElement *element) |
One can add arbitrary elements to the active undo set. More... | |
virtual void | OnStateChange (vtkSMSession *session, vtkTypeUInt32 globalId, const vtkSMMessage *previousState, const vtkSMMessage *newState) |
virtual void | OnCreateObject (vtkSMSession *session, vtkSMMessage *newState) |
void | EndAndPushToStack () |
Convenience method call End(); PushToStack(); in that order. More... | |
virtual vtkSMUndoStack * | GetUndoStack () |
Get/Set the undo stack that this builder will build. More... | |
virtual void | SetUndoStack (vtkSMUndoStack *) |
virtual void | SetIgnoreAllChanges (bool) |
If IgnoreAllChanges is true, any server manager changes will be ignored even if the changes happened within a Begin()-End() call. More... | |
virtual bool | GetIgnoreAllChanges () |
virtual void | Modified () |
static vtkSMUndoStackBuilder * | New () |
static vtkSMUndoStackBuilder * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMUndoStackBuilder () | |
~vtkSMUndoStackBuilder () override | |
virtual void | SetLabel (const char *) |
virtual bool | HandleChangeEvents () |
Returns if the event raised by the proxy manager should be converted to undo elements. More... | |
void | InitializeUndoSet () |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSMUndoStack * | UndoStack |
vtkUndoSet * | UndoSet |
char * | Label |
int | EnableMonitoring |
bool | IgnoreAllChanges |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMUndoStackBuilder records Server Manager changes that are undo/redo able and collects them. To begin recording such changes one must call Begin(). To end recording use End(). One can have multiple blocks of Begin-End before pushing the changes on the Undo Stack. To push all collected changes onto the Undo Stack as a single undoable step, use PushToStack(). Applications can subclass vtkSMUndoStackBuilder to record GUI related changes and add them to the undo stack.
Definition at line 31 of file vtkSMUndoStackBuilder.h.
Definition at line 35 of file vtkSMUndoStackBuilder.h.
Reimplemented in pqUndoStackBuilder.
All noted actions are converted to UndoElements and collected. One vtkUndoElement is created per action. All undo elements become a part of a vtkUndoSet which is pushed on to the Undo Stack on PushToStack(). label
is a suggestion for the UndoSet that will be built. If the UndoSet already has elements implying it hasn't been pushed to the stack then the label is ignored.
Any changes made to the proxy manager will not be converted to UndoElements. This method does not push the vtkUndoSet of undo elements built. One must call PushToStack() to push the UndoSet to the Undo stack. Alternatively, one can use the EndAndPushToStack() method which combines End() and PushToStack().
Definition at line 64 of file vtkSMUndoStackBuilder.h.
The UndoStack which the builder is building must be set by using SetUndoStack(). If the UndoSet is empty, it is not pushed on the stack. After pushing, the UndoSet is cleared so the builder is ready to collect new modifications.
It is essential that the StateLoader on the UndoStack can handle the arbitrary undo elements. If that element has been escaped for any reason, the method will return false;
This provides a mechanism for the application to perform non-undoable operations irrespective of whether a undo set if being built. By default, it is set to false.
protectedvirtual |
inlineprotectedvirtual |
Definition at line 134 of file vtkSMUndoStackBuilder.h.
Definition at line 125 of file vtkSMUndoStackBuilder.h.
Definition at line 126 of file vtkSMUndoStackBuilder.h.
Definition at line 127 of file vtkSMUndoStackBuilder.h.
Definition at line 140 of file vtkSMUndoStackBuilder.h.
Definition at line 141 of file vtkSMUndoStackBuilder.h.
