pqUndoStackBuilder Class Reference
pqUndoStackBuilder extends the vtkSMUndoStackBuilder as follows: More...
#include <pqUndoStackBuilder.h>
Inheritance diagram for pqUndoStackBuilder:
Collaboration diagram for pqUndoStackBuilder:
typedef vtkSMUndoStackBuilder Superclass
- Public Types inherited from vtkSMUndoStackBuilder
virtual bool GetIgnoreIsolatedChanges ()
 Get/Set if all modifications triggered when not within a Begin/End block should be added to the undo stack or not. More...
virtual void SetIgnoreIsolatedChanges (bool)
void SetUndoStack (vtkSMUndoStack *) override
 Overridden to add observers to not record changes when the stack is being undone/redone. More...
void OnStateChange (vtkSMSession *session, vtkTypeUInt32 globalId, const vtkSMMessage *previousState, const vtkSMMessage *newState) override
 Overridden to filter unwanted event and manage auto undoset creation. More...
- Public Member Functions inherited from vtkSMUndoStackBuilder
virtual void Begin (const char *label)
 Begins monitoring of the vtkSMProxyManager for undoable operations. More...
virtual void End ()
 Stops monitoring of the vtkSMProxyManager for undoable operations. More...
virtual void PushToStack ()
 If any undoable changes were recorded by the builder, this will push the vtkUndoSet formed on to the UndoStack. More...
virtual void Clear ()
 Discard all recorded changes that haven't been pushed on the UndoStack. More...
virtual bool Add (vtkUndoElement *element)
 One can add arbitrary elements to the active undo set. More...
virtual void OnCreateObject (vtkSMSession *session, vtkSMMessage *newState)
void EndAndPushToStack ()
 Convenience method call End(); PushToStack(); in that order. More...
virtual vtkSMUndoStackGetUndoStack ()
 Get/Set the undo stack that this builder will build. More...
virtual void SetIgnoreAllChanges (bool)
 If IgnoreAllChanges is true, any server manager changes will be ignored even if the changes happened within a Begin()-End() call. More...
virtual bool GetIgnoreAllChanges ()
static pqUndoStackBuilderNew ()
static pqUndoStackBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMUndoStackBuilder
static vtkSMUndoStackBuilderNew ()
static vtkSMUndoStackBuilderSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 pqUndoStackBuilder ()
 ~pqUndoStackBuilder () override
bool Filter (vtkSMSession *session, vtkTypeUInt32 globalId)
 Return false if this state should be escaped. More...
- Protected Member Functions inherited from vtkSMUndoStackBuilder
 vtkSMUndoStackBuilder ()
 ~vtkSMUndoStackBuilder () override
virtual void SetLabel (const char *)
virtual bool HandleChangeEvents ()
 Returns if the event raised by the proxy manager should be converted to undo elements. More...
void InitializeUndoSet ()
 vtkSMObject ()
 ~vtkSMObject () override
bool IgnoreIsolatedChanges
bool UndoRedoing
- Protected Attributes inherited from vtkSMUndoStackBuilder
vtkSMUndoStackUndoStack
vtkUndoSetUndoSet
char * Label
int EnableMonitoring
bool IgnoreAllChanges
Definition at line 46 of file pqUndoStackBuilder.h.
Definition at line 50 of file pqUndoStackBuilder.h.
◆ pqUndoStackBuilder()
pqUndoStackBuilder::pqUndoStackBuilder ( )
◆ ~pqUndoStackBuilder()
pqUndoStackBuilder::~pqUndoStackBuilder ( )
static pqUndoStackBuilder* pqUndoStackBuilder::New ( )
virtual const char* pqUndoStackBuilder::GetClassName ( )
Reimplemented from vtkSMUndoStackBuilder.
static int pqUndoStackBuilder::IsTypeOf ( const char *  type)
virtual int pqUndoStackBuilder::IsA ( const char *  type)
static pqUndoStackBuilder* pqUndoStackBuilder::SafeDownCast ( vtkObject o)
void pqUndoStackBuilder::PrintSelf ( ostream &  os,
◆ GetIgnoreIsolatedChanges()
virtual bool pqUndoStackBuilder::GetIgnoreIsolatedChanges ( )
On by default. Must be set before performing changes to Server Manager which the GUI is certain shouldn't be added to the Undo stack.
◆ SetIgnoreIsolatedChanges()
virtual void pqUndoStackBuilder::SetIgnoreIsolatedChanges ( bool  )
◆ SetUndoStack()
void pqUndoStackBuilder::SetUndoStack ( vtkSMUndoStack )
◆ OnStateChange()
void pqUndoStackBuilder::OnStateChange ( vtkSMSession session,
const vtkSMMessage previousState,
const vtkSMMessage newState
◆ Filter()
bool pqUndoStackBuilder::Filter ( vtkSMSession session,
◆ IgnoreIsolatedChanges
bool pqUndoStackBuilder::IgnoreIsolatedChanges
Definition at line 83 of file pqUndoStackBuilder.h.
◆ UndoRedoing
bool pqUndoStackBuilder::UndoRedoing
Definition at line 84 of file pqUndoStackBuilder.h.
