packages a Python module into a ParaView plugin. More...
#include <vtkPVPythonAlgorithmPlugin.h>
vtkPVPythonAlgorithmPlugin (const char *pythonmodule) | |
~vtkPVPythonAlgorithmPlugin () override | |
const char * | GetPluginName () override |
const char * | GetPluginVersionString () override |
bool | GetRequiredOnServer () override |
bool | GetRequiredOnClient () override |
const char * | GetRequiredPlugins () override |
const char * | GetDescription () override |
const char * | GetEULA () override |
void | GetXMLs (std::vector< std::string > &xmls) override |
vtkClientServerInterpreterInitializer::InterpreterInitializationCallback | GetInitializeInterpreterCallback () override |
vtkPVPlugin () | |
virtual | ~vtkPVPlugin () |
const char * | GetFileName () |
virtual void | GetBinaryResources (std::vector< std::string > &resources) |
Provides access to binary resources compiled into the plugin. More... | |
virtual | ~vtkPVServerManagerPluginInterface () |
virtual void | GetXMLs (std::vector< std::string > &vtkNotUsed(xmls))=0 |
Obtain the server-manager configuration xmls, if any. More... | |
virtual bool | GetEnsurePluginLoaded () |
Return if the plugin should be ensured when using a proxy provided by the XMLs Useful for delayed load plugin. More... | |
Friends | |
class | vtkPVPythonAlgorithmPluginLoaderInitializer |
typedef bool(* | EULAConfirmationCallback) (vtkPVPlugin *) |
Type for EULAConfirmationCallback. More... | |
static bool | ImportPlugin (vtkPVPlugin *plugin) |
Used when import plugins programmatically. More... | |
static void | SetEULAConfirmationCallback (EULAConfirmationCallback callback) |
Get/Set the static callback to call to confirm EULA. More... | |
static EULAConfirmationCallback | GetEULAConfirmationCallback () |
void | SetFileName (const char *filename) |
Set the filename the plugin is loaded from, if any. More... | |
vtkPVPythonAlgorithmPlugin helps us support loading a Python module as a ParaView plugin
. The only supported type of plugin is a server-manager plugin that adds support for algorithm proxies i.e. readers, filters, and writers.
Definition at line 25 of file vtkPVPythonAlgorithmPlugin.h.
vtkPVPythonAlgorithmPlugin::vtkPVPythonAlgorithmPlugin | ( | const char * | pythonmodule | ) |
Implementation of the vtkPVPlugin interface.
Implements vtkPVPlugin.
inlineoverridevirtual |
Definition at line 37 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 38 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 39 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 40 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 41 of file vtkPVPythonAlgorithmPlugin.h.
Implementation of the vtkPVServerManagerPluginInterface.
Definition at line 48 of file vtkPVPythonAlgorithmPlugin.h.
friend |
Definition at line 61 of file vtkPVPythonAlgorithmPlugin.h.
