void | UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override |
| This method will do the actual interpolation. More...
virtual void | SetPhase (double) |
| Get/Set the phase for the sine wave. More...
virtual double | GetPhase () |
virtual void | SetFrequency (double) |
| Get/Set the frequency for the sine wave in number of cycles for the entire length of this keyframe i.e. More...
virtual double | GetFrequency () |
virtual void | SetOffset (double) |
| Get/Set the Wave offset. More...
virtual double | GetOffset () |
virtual void | RemoveAllKeyValues () |
| Removes all key values. More...
virtual void | SetKeyTime (double) |
| Key time is the time at which this key frame is associated. More...
virtual double | GetKeyTime () |
virtual void | SetKeyValue (double val) |
| Get/Set the animated value at this key frame. More...
virtual void | SetKeyValue (unsigned int index, double val) |
double | GetKeyValue () |
double | GetKeyValue (unsigned int index) |
unsigned int | GetNumberOfKeyValues () |
| Set/Get the number of key values this key frame currently stores. More...
virtual void | SetNumberOfKeyValues (unsigned int num) |
virtual void | Modified () |
