vtkPolarAxesRepresentation Class Reference
representation for a polar-axes. More...
#include <vtkPolarAxesRepresentation.h>
Inheritance diagram for vtkPolarAxesRepresentation:
Collaboration diagram for vtkPolarAxesRepresentation:
enum  DesiredOutputPrecision
virtual doubleGetDataBounds ()
 Get the bounds of the data. More...
virtual void GetDataBounds (double &, double &, double &, double &, double &, double &)
virtual void GetDataBounds (double [6])
void MarkModified () override
 This needs to be called on all instances of vtkPolarAxesRepresentation when the input is modified. More...
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
virtual void SetParentVisibility (bool visible)
 Set (forward) visibility of the parent (composite) representation. More...
virtual void SetPosition (double, double, double)
 Get/Set the Position to transform the data bounds. More...
virtual void SetPosition (double [3])
virtual doubleGetPosition ()
virtual void GetPosition (double &, double &, double &)
virtual void GetPosition (double [3])
virtual void SetOrientation (double, double, double)
 Get/Set the Orientation to transform the data bounds. More...
virtual void SetOrientation (double [3])
virtual doubleGetOrientation ()
virtual void GetOrientation (double &, double &, double &)
virtual void GetOrientation (double [3])
virtual void SetScale (double, double, double)
 Get/Set the Scale to transform the data bounds. More...
virtual void SetScale (double [3])
virtual doubleGetScale ()
virtual void GetScale (double &, double &, double &)
virtual void GetScale (double [3])
virtual void SetCustomBounds (double, double, double, double, double, double)
 Get/Set custom bounds to use. More...
virtual void SetCustomBounds (double [6])
virtual doubleGetCustomBounds ()
virtual void GetCustomBounds (double &, double &, double &, double &, double &, double &)
virtual void GetCustomBounds (double [6])
virtual void SetEnableCustomBounds (int, int, int)
 Get/Set whether to use custom bounds for a particular dimension. More...
virtual void SetEnableCustomBounds (int [3])
virtual intGetEnableCustomBounds ()
virtual void GetEnableCustomBounds (int &, int &, int &)
virtual void GetEnableCustomBounds (int [3])
virtual void SetEnableCustomRange (bool)
 Get/Set the use of a custom range. More...
virtual bool GetEnableCustomRange ()
virtual void SetCustomRange (double, double)
 Get/Set custom range to use. More...
void SetCustomRange (double [2])
virtual doubleGetCustomRange ()
virtual void GetCustomRange (double &, double &)
virtual void GetCustomRange (double [2])
virtual void SetEnableAutoPole (bool)
 Get/Set the use of automatically placed pole (origin of the axes). More...
virtual bool GetEnableAutoPole ()
virtual void SetEnableCustomAngle (bool)
 Get/Set the use of custom min/max angles. More...
virtual bool GetEnableCustomAngle ()
virtual void SetMinAngle (double)
 Get/Set the custom min/max angles when EnableCustomAngle is On. More...
virtual double GetMinAngle ()
virtual void SetMaxAngle (double)
virtual double GetMaxAngle ()
virtual void SetEnableCustomRadius (bool enabled)
 Get/Set the use of custom min radius. More...
virtual bool GetEnableCustomRadius ()
void SetEnableCustomMinRadius (bool enabled)
virtual double GetEnableCustomMinRadius ()
virtual void SetMinRadius (double)
 Get/Set the custom min radius when EnableCustomMinRadius is On. More...
virtual double GetMinRadius ()
virtual void SetEnableCustomMaxRadius (bool)
virtual bool GetEnableCustomMaxRadius ()
virtual void SetMaxRadius (double)
 Get/Set the custom min radius when EnableCustomMaxRadius is On. More...
virtual double GetMaxRadius ()
virtual bool GetEnableOverallColor ()
 Set the actor color. More...
virtual void SetEnableOverallColor (bool enable)
virtual void SetOverallColor (double r, double g, double b)
virtual void SetPolarAxisColor (double r, double g, double b)
virtual void SetPolarArcsColor (double r, double g, double b)
virtual void SetSecondaryPolarArcsColor (double r, double g, double b)
virtual void SetSecondaryRadialAxesColor (double r, double g, double b)
virtual void SetLastRadialAxisColor (double r, double g, double b)
virtual void SetPolarAxisTitleTextProperty (vtkTextProperty *prop)
virtual void SetPolarAxisLabelTextProperty (vtkTextProperty *prop)
virtual void SetLastRadialAxisTextProperty (vtkTextProperty *prop)
virtual void SetSecondaryRadialAxesTextProperty (vtkTextProperty *prop)
virtual void SetLog (bool active)
 Forwarded to internal vtkPolarAxesActor. More...
virtual void SetNumberOfRadialAxes (vtkIdType val)
virtual void SetNumberOfPolarAxes (vtkIdType val)
virtual void SetDeltaAngleRadialAxes (double angle)
virtual void SetDeltaRangePolarAxes (double range)
virtual void SetSmallestVisiblePolarAngle (double angle)
virtual void SetTickLocation (int location)
virtual void SetRadialUnits (bool use)
virtual void SetScreenSize (double size)
virtual void SetPolarAxisTitle (const char *title)
virtual void SetPolarLabelFormat (const char *format)
virtual void SetExponentLocation (int location)
virtual void SetRadialAngleFormat (const char *format)
virtual void SetEnableDistanceLOD (int enable)
virtual void SetDistanceLODThreshold (double val)
virtual void SetEnableViewAngleLOD (int enable)
virtual void SetViewAngleLODThreshold (double val)
virtual void SetPolarAxisVisibility (int visible)
virtual void SetDrawRadialGridlines (int draw)
virtual void SetDrawPolarArcsGridlines (int draw)
virtual void SetPolarTitleVisibility (int visible)
virtual void SetRadialAxisTitleLocation (int location)
virtual void SetPolarAxisTitleLocation (int location)
virtual void SetRadialTitleOffset (double offsetX, double offsetY)
virtual void SetPolarTitleOffset (double offsetX, double offsetY)
virtual void SetPolarLabelOffset (double offsetY)
virtual void SetPolarExponentOffset (double offsetY)
virtual void SetPolarLabelVisibility (int visible)
virtual void SetArcTicksOriginToPolarAxis (int use)
virtual void SetRadialAxesOriginToPolarAxis (int use)
virtual void SetPolarTickVisibility (int visible)
virtual void SetAxisTickVisibility (int visible)
virtual void SetAxisMinorTickVisibility (int visible)
virtual void SetAxisTickMatchesPolarAxes (int enable)
virtual void SetArcTickVisibility (int visible)
virtual void SetArcMinorTickVisibility (int visible)
virtual void SetArcTickMatchesRadialAxes (int enable)
virtual void SetTickRatioRadiusSize (double ratio)
virtual void SetArcMajorTickSize (double size)
virtual void SetPolarAxisMajorTickSize (double size)
virtual void SetLastRadialAxisMajorTickSize (double size)
virtual void SetPolarAxisTickRatioSize (double size)
virtual void SetLastAxisTickRatioSize (double size)
virtual void SetArcTickRatioSize (double size)
virtual void SetPolarAxisMajorTickThickness (double thickness)
virtual void SetLastRadialAxisMajorTickThickness (double thickness)
virtual void SetArcMajorTickThickness (double thickness)
virtual void SetPolarAxisTickRatioThickness (double thickness)
virtual void SetLastAxisTickRatioThickness (double thickness)
virtual void SetArcTickRatioThickness (double thickness)
virtual void SetDeltaAngleMajor (double delta)
virtual void SetDeltaAngleMinor (double delta)
virtual void SetRadialAxesVisibility (int visible)
virtual void SetRadialTitleVisibility (int visible)
virtual void SetPolarArcsVisibility (int visible)
virtual void SetUse2DMode (int use)
virtual void SetRatio (double ratio)
virtual void SetPolarArcResolutionPerDegree (double resolution)
virtual void SetDeltaRangeMinor (double delta)
virtual void SetDeltaRangeMajor (double delta)
virtual void SetRendererType (int)
 Set the renderer to use. More...
virtual int GetRendererType ()
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPolarAxesRepresentationNew ()
static vtkPolarAxesRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPolarAxesRepresentation ()
 ~vtkPolarAxesRepresentation () override
int RequestData (vtkInformation *, vtkInformationVector **inputVector, vtkInformationVector *) override
virtual void InitializeDataBoundsFromData (vtkDataObject *data)
virtual void UpdateBounds ()
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkNew< vtkPolyDataOutlineGeometry
vtkNew< vtkPolarAxesActorPolarAxesActor
vtkWeakPointer< vtkPVRenderViewRenderView
double Position [3] = { 0.0 }
double Scale [3] = { 1.0 }
double Orientation [3] = { 0.0 }
double CustomBounds [6] = { 0.0, 1.0, 0.0, 1.0, 0.0, 1.0 }
int EnableCustomBounds [3] = { 0 }
double CustomRange [2] = { 0.0, 1.0 }
bool EnableCustomRange = false
bool EnableAutoPole = true
bool EnableCustomAngle = true
double MinAngle = 0.0
double MaxAngle = 90.0
bool EnableCustomRadius = true
double MinRadius = 0.0
bool EnableOverallColor = true
double OverallColor [3] = { 1.0 }
double PolarAxisColor [3] = { 1.0 }
double PolarArcsColor [3] = { 1.0 }
double SecondaryPolarArcsColor [3] = { 1.0 }
double SecondaryRadialAxesColor [3] = { 1.0 }
double LastRadialAxisColor [3] = { 1.0 }
double DataBounds [6] = { 0.0 }
int RendererType = vtkPVRenderView::DEFAULT_RENDERER
bool ParentVisibility = true
vtkTimeStamp DataBoundsTime
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPolarAxesRepresentation is a representation for the Polar-Axes that shows a bounding box with labels around any input dataset.
Definition at line 25 of file vtkPolarAxesRepresentation.h.
Definition at line 29 of file vtkPolarAxesRepresentation.h.
◆ vtkPolarAxesRepresentation()
vtkPolarAxesRepresentation::vtkPolarAxesRepresentation ( )
◆ ~vtkPolarAxesRepresentation()
vtkPolarAxesRepresentation::~vtkPolarAxesRepresentation ( )
static vtkPolarAxesRepresentation* vtkPolarAxesRepresentation::New ( )
virtual const char* vtkPolarAxesRepresentation::GetClassName ( )
static int vtkPolarAxesRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPolarAxesRepresentation::IsA ( const char *  type)
static vtkPolarAxesRepresentation* vtkPolarAxesRepresentation::SafeDownCast ( vtkObject o)
void vtkPolarAxesRepresentation::PrintSelf ( ostream &  os,
◆ SetPosition() [1/2]
virtual void vtkPolarAxesRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetPosition() [2/2]
virtual void vtkPolarAxesRepresentation::SetPosition ( double  [3])
◆ GetPosition() [1/3]
virtual double* vtkPolarAxesRepresentation::GetPosition ( )
◆ GetPosition() [2/3]
virtual void vtkPolarAxesRepresentation::GetPosition ( double ,
double ,
double
◆ GetPosition() [3/3]
virtual void vtkPolarAxesRepresentation::GetPosition ( double  [3])
◆ SetOrientation() [1/2]
virtual void vtkPolarAxesRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrientation() [2/2]
virtual void vtkPolarAxesRepresentation::SetOrientation ( double  [3])
◆ GetOrientation() [1/3]
virtual double* vtkPolarAxesRepresentation::GetOrientation ( )
◆ GetOrientation() [2/3]
virtual void vtkPolarAxesRepresentation::GetOrientation ( double ,
double ,
double
◆ GetOrientation() [3/3]
virtual void vtkPolarAxesRepresentation::GetOrientation ( double  [3])
◆ SetScale() [1/2]
virtual void vtkPolarAxesRepresentation::SetScale ( double  ,
double  ,
double
◆ SetScale() [2/2]
virtual void vtkPolarAxesRepresentation::SetScale ( double  [3])
◆ GetScale() [1/3]
virtual double* vtkPolarAxesRepresentation::GetScale ( )
◆ GetScale() [2/3]
virtual void vtkPolarAxesRepresentation::GetScale ( double ,
double ,
double
◆ GetScale() [3/3]
virtual void vtkPolarAxesRepresentation::GetScale ( double  [3])
◆ GetDataBounds() [1/3]
virtual double* vtkPolarAxesRepresentation::GetDataBounds ( )
◆ GetDataBounds() [2/3]
virtual void vtkPolarAxesRepresentation::GetDataBounds ( double ,
double ,
double ,
double ,
double ,
double
◆ GetDataBounds() [3/3]
virtual void vtkPolarAxesRepresentation::GetDataBounds ( double  [6])
◆ SetCustomBounds() [1/2]
virtual void vtkPolarAxesRepresentation::SetCustomBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
When corresponding CustomBoundsActive is true, the data bounds will be ignored for that direction and CustomBounds will be used instead.
◆ SetCustomBounds() [2/2]
virtual void vtkPolarAxesRepresentation::SetCustomBounds ( double  [6])
◆ GetCustomBounds() [1/3]
virtual double* vtkPolarAxesRepresentation::GetCustomBounds ( )
◆ GetCustomBounds() [2/3]
virtual void vtkPolarAxesRepresentation::GetCustomBounds ( double ,
double ,
double ,
double ,
double ,
double
◆ GetCustomBounds() [3/3]
virtual void vtkPolarAxesRepresentation::GetCustomBounds ( double  [6])
◆ SetEnableCustomBounds() [1/2]
virtual void vtkPolarAxesRepresentation::SetEnableCustomBounds ( int  ,
int  ,
int
◆ SetEnableCustomBounds() [2/2]
virtual void vtkPolarAxesRepresentation::SetEnableCustomBounds ( int  [3])
◆ GetEnableCustomBounds() [1/3]
virtual int* vtkPolarAxesRepresentation::GetEnableCustomBounds ( )
◆ GetEnableCustomBounds() [2/3]
virtual void vtkPolarAxesRepresentation::GetEnableCustomBounds ( int ,
int ,
int
◆ GetEnableCustomBounds() [3/3]
virtual void vtkPolarAxesRepresentation::GetEnableCustomBounds ( int  [3])
◆ SetEnableCustomRange()
virtual void vtkPolarAxesRepresentation::SetEnableCustomRange ( bool  )
◆ GetEnableCustomRange()
virtual bool vtkPolarAxesRepresentation::GetEnableCustomRange ( )
◆ SetCustomRange() [1/2]
virtual void vtkPolarAxesRepresentation::SetCustomRange ( double  ,
double
The data bounds will be ignored for that direction and CustomRange will be used instead.
◆ SetCustomRange() [2/2]
void vtkPolarAxesRepresentation::SetCustomRange ( double  [2])
◆ GetCustomRange() [1/3]
virtual double* vtkPolarAxesRepresentation::GetCustomRange ( )
◆ GetCustomRange() [2/3]
virtual void vtkPolarAxesRepresentation::GetCustomRange ( double ,
double
◆ GetCustomRange() [3/3]
virtual void vtkPolarAxesRepresentation::GetCustomRange ( double  [2])
◆ SetEnableAutoPole()
virtual void vtkPolarAxesRepresentation::SetEnableAutoPole ( bool  )
If on, pole is placed at the center of the bounding box.
◆ GetEnableAutoPole()
virtual bool vtkPolarAxesRepresentation::GetEnableAutoPole ( )
◆ SetEnableCustomAngle()
virtual void vtkPolarAxesRepresentation::SetEnableCustomAngle ( bool  )
If off, min/max angles are computed relatively to pole position.
◆ GetEnableCustomAngle()
virtual bool vtkPolarAxesRepresentation::GetEnableCustomAngle ( )
◆ SetMinAngle()
virtual void vtkPolarAxesRepresentation::SetMinAngle ( double  )
◆ GetMinAngle()
virtual double vtkPolarAxesRepresentation::GetMinAngle ( )
◆ SetMaxAngle()
virtual void vtkPolarAxesRepresentation::SetMaxAngle ( double  )
◆ GetMaxAngle()
virtual double vtkPolarAxesRepresentation::GetMaxAngle ( )
◆ SetEnableCustomRadius()
virtual void vtkPolarAxesRepresentation::SetEnableCustomRadius ( bool  enabled)
If off, min radius is computed relatively to pole position.
◆ GetEnableCustomRadius()
virtual bool vtkPolarAxesRepresentation::GetEnableCustomRadius ( )
◆ SetEnableCustomMinRadius()
void vtkPolarAxesRepresentation::SetEnableCustomMinRadius ( bool  enabled)
◆ GetEnableCustomMinRadius()
virtual double vtkPolarAxesRepresentation::GetEnableCustomMinRadius ( )
◆ SetMinRadius()
virtual void vtkPolarAxesRepresentation::SetMinRadius ( double  )
Default to 0.
◆ GetMinRadius()
virtual double vtkPolarAxesRepresentation::GetMinRadius ( )
Default to 0.
◆ SetEnableCustomMaxRadius()
virtual void vtkPolarAxesRepresentation::SetEnableCustomMaxRadius ( bool  )
If off, max radius is computed relatively to pole position.
◆ GetEnableCustomMaxRadius()
virtual bool vtkPolarAxesRepresentation::GetEnableCustomMaxRadius ( )
◆ SetMaxRadius()
virtual void vtkPolarAxesRepresentation::SetMaxRadius ( double  )
Default to 1.
◆ GetMaxRadius()
virtual double vtkPolarAxesRepresentation::GetMaxRadius ( )
Default to 1.
◆ GetEnableOverallColor()
virtual bool vtkPolarAxesRepresentation::GetEnableOverallColor ( )
◆ SetEnableOverallColor()
virtual void vtkPolarAxesRepresentation::SetEnableOverallColor ( bool  enable)
◆ SetOverallColor()
virtual void vtkPolarAxesRepresentation::SetOverallColor ( double  r,
double  g,
double  b
◆ SetPolarAxisColor()
virtual void vtkPolarAxesRepresentation::SetPolarAxisColor ( double  r,
double  g,
double  b
◆ SetPolarArcsColor()
virtual void vtkPolarAxesRepresentation::SetPolarArcsColor ( double  r,
double  g,
double  b
◆ SetSecondaryPolarArcsColor()
virtual void vtkPolarAxesRepresentation::SetSecondaryPolarArcsColor ( double  r,
double  g,
double  b
◆ SetSecondaryRadialAxesColor()
virtual void vtkPolarAxesRepresentation::SetSecondaryRadialAxesColor ( double  r,
double  g,
double  b
◆ SetLastRadialAxisColor()
virtual void vtkPolarAxesRepresentation::SetLastRadialAxisColor ( double  r,
double  g,
double  b
◆ SetPolarAxisTitleTextProperty()
virtual void vtkPolarAxesRepresentation::SetPolarAxisTitleTextProperty ( vtkTextProperty prop)
◆ SetPolarAxisLabelTextProperty()
virtual void vtkPolarAxesRepresentation::SetPolarAxisLabelTextProperty ( vtkTextProperty prop)
◆ SetLastRadialAxisTextProperty()
virtual void vtkPolarAxesRepresentation::SetLastRadialAxisTextProperty ( vtkTextProperty prop)
◆ SetSecondaryRadialAxesTextProperty()
virtual void vtkPolarAxesRepresentation::SetSecondaryRadialAxesTextProperty ( vtkTextProperty prop)
◆ MarkModified()
void vtkPolarAxesRepresentation::MarkModified ( )
inlineoverridevirtual
Definition at line 187 of file vtkPolarAxesRepresentation.h.
◆ ProcessViewRequest()
int vtkPolarAxesRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering
◆ SetVisibility()
void vtkPolarAxesRepresentation::SetVisibility ( bool  visible)
◆ SetParentVisibility()
virtual void vtkPolarAxesRepresentation::SetParentVisibility ( bool  visible)
◆ SetLog()
virtual void vtkPolarAxesRepresentation::SetLog ( bool  active)
◆ SetNumberOfRadialAxes()
virtual void vtkPolarAxesRepresentation::SetNumberOfRadialAxes ( vtkIdType  val)
◆ SetNumberOfPolarAxes()
virtual void vtkPolarAxesRepresentation::SetNumberOfPolarAxes ( vtkIdType  val)
◆ SetDeltaAngleRadialAxes()
virtual void vtkPolarAxesRepresentation::SetDeltaAngleRadialAxes ( double  angle)
◆ SetDeltaRangePolarAxes()
virtual void vtkPolarAxesRepresentation::SetDeltaRangePolarAxes ( double  range)
◆ SetSmallestVisiblePolarAngle()
virtual void vtkPolarAxesRepresentation::SetSmallestVisiblePolarAngle ( double  angle)
◆ SetTickLocation()
virtual void vtkPolarAxesRepresentation::SetTickLocation ( int  location)
◆ SetRadialUnits()
virtual void vtkPolarAxesRepresentation::SetRadialUnits ( bool  use)
◆ SetScreenSize()
virtual void vtkPolarAxesRepresentation::SetScreenSize ( double  size)
◆ SetPolarAxisTitle()
virtual void vtkPolarAxesRepresentation::SetPolarAxisTitle ( const char *  title)
◆ SetPolarLabelFormat()
virtual void vtkPolarAxesRepresentation::SetPolarLabelFormat ( const char *  format)
◆ SetExponentLocation()
virtual void vtkPolarAxesRepresentation::SetExponentLocation ( int  location)
◆ SetRadialAngleFormat()
virtual void vtkPolarAxesRepresentation::SetRadialAngleFormat ( const char *  format)
◆ SetEnableDistanceLOD()
virtual void vtkPolarAxesRepresentation::SetEnableDistanceLOD ( int  enable)
◆ SetDistanceLODThreshold()
virtual void vtkPolarAxesRepresentation::SetDistanceLODThreshold ( double  val)
◆ SetEnableViewAngleLOD()
virtual void vtkPolarAxesRepresentation::SetEnableViewAngleLOD ( int  enable)
◆ SetViewAngleLODThreshold()
virtual void vtkPolarAxesRepresentation::SetViewAngleLODThreshold ( double  val)
◆ SetPolarAxisVisibility()
virtual void vtkPolarAxesRepresentation::SetPolarAxisVisibility ( int  visible)
◆ SetDrawRadialGridlines()
virtual void vtkPolarAxesRepresentation::SetDrawRadialGridlines ( int  draw)
◆ SetDrawPolarArcsGridlines()
virtual void vtkPolarAxesRepresentation::SetDrawPolarArcsGridlines ( int  draw)
◆ SetPolarTitleVisibility()
virtual void vtkPolarAxesRepresentation::SetPolarTitleVisibility ( int  visible)
◆ SetRadialAxisTitleLocation()
virtual void vtkPolarAxesRepresentation::SetRadialAxisTitleLocation ( int  location)
◆ SetPolarAxisTitleLocation()
virtual void vtkPolarAxesRepresentation::SetPolarAxisTitleLocation ( int  location)
◆ SetRadialTitleOffset()
virtual void vtkPolarAxesRepresentation::SetRadialTitleOffset ( double  offsetX,
double  offsetY
◆ SetPolarTitleOffset()
virtual void vtkPolarAxesRepresentation::SetPolarTitleOffset ( double  offsetX,
double  offsetY
◆ SetPolarLabelOffset()
virtual void vtkPolarAxesRepresentation::SetPolarLabelOffset ( double  offsetY)
◆ SetPolarExponentOffset()
virtual void vtkPolarAxesRepresentation::SetPolarExponentOffset ( double  offsetY)
◆ SetPolarLabelVisibility()
virtual void vtkPolarAxesRepresentation::SetPolarLabelVisibility ( int  visible)
◆ SetArcTicksOriginToPolarAxis()
virtual void vtkPolarAxesRepresentation::SetArcTicksOriginToPolarAxis ( int  use)
◆ SetRadialAxesOriginToPolarAxis()
virtual void vtkPolarAxesRepresentation::SetRadialAxesOriginToPolarAxis ( int  use)
◆ SetPolarTickVisibility()
virtual void vtkPolarAxesRepresentation::SetPolarTickVisibility ( int  visible)
◆ SetAxisTickVisibility()
virtual void vtkPolarAxesRepresentation::SetAxisTickVisibility ( int  visible)
◆ SetAxisMinorTickVisibility()
virtual void vtkPolarAxesRepresentation::SetAxisMinorTickVisibility ( int  visible)
◆ SetAxisTickMatchesPolarAxes()
virtual void vtkPolarAxesRepresentation::SetAxisTickMatchesPolarAxes ( int  enable)
◆ SetArcTickVisibility()
virtual void vtkPolarAxesRepresentation::SetArcTickVisibility ( int  visible)
◆ SetArcMinorTickVisibility()
virtual void vtkPolarAxesRepresentation::SetArcMinorTickVisibility ( int  visible)
◆ SetArcTickMatchesRadialAxes()
virtual void vtkPolarAxesRepresentation::SetArcTickMatchesRadialAxes ( int  enable)
◆ SetTickRatioRadiusSize()
virtual void vtkPolarAxesRepresentation::SetTickRatioRadiusSize ( double  ratio)
◆ SetArcMajorTickSize()
virtual void vtkPolarAxesRepresentation::SetArcMajorTickSize ( double  size)
◆ SetPolarAxisMajorTickSize()
virtual void vtkPolarAxesRepresentation::SetPolarAxisMajorTickSize ( double  size)
◆ SetLastRadialAxisMajorTickSize()
virtual void vtkPolarAxesRepresentation::SetLastRadialAxisMajorTickSize ( double  size)
◆ SetPolarAxisTickRatioSize()
virtual void vtkPolarAxesRepresentation::SetPolarAxisTickRatioSize ( double  size)
◆ SetLastAxisTickRatioSize()
virtual void vtkPolarAxesRepresentation::SetLastAxisTickRatioSize ( double  size)
◆ SetArcTickRatioSize()
virtual void vtkPolarAxesRepresentation::SetArcTickRatioSize ( double  size)
◆ SetPolarAxisMajorTickThickness()
virtual void vtkPolarAxesRepresentation::SetPolarAxisMajorTickThickness ( double  thickness)
◆ SetLastRadialAxisMajorTickThickness()
virtual void vtkPolarAxesRepresentation::SetLastRadialAxisMajorTickThickness ( double  thickness)
◆ SetArcMajorTickThickness()
virtual void vtkPolarAxesRepresentation::SetArcMajorTickThickness ( double  thickness)
◆ SetPolarAxisTickRatioThickness()
virtual void vtkPolarAxesRepresentation::SetPolarAxisTickRatioThickness ( double  thickness)
◆ SetLastAxisTickRatioThickness()
virtual void vtkPolarAxesRepresentation::SetLastAxisTickRatioThickness ( double  thickness)
◆ SetArcTickRatioThickness()
virtual void vtkPolarAxesRepresentation::SetArcTickRatioThickness ( double  thickness)
◆ SetDeltaAngleMajor()
virtual void vtkPolarAxesRepresentation::SetDeltaAngleMajor ( double  delta)
◆ SetDeltaAngleMinor()
virtual void vtkPolarAxesRepresentation::SetDeltaAngleMinor ( double  delta)
◆ SetRadialAxesVisibility()
virtual void vtkPolarAxesRepresentation::SetRadialAxesVisibility ( int  visible)
◆ SetRadialTitleVisibility()
virtual void vtkPolarAxesRepresentation::SetRadialTitleVisibility ( int  visible)
◆ SetPolarArcsVisibility()
virtual void vtkPolarAxesRepresentation::SetPolarArcsVisibility ( int  visible)
◆ SetUse2DMode()
virtual void vtkPolarAxesRepresentation::SetUse2DMode ( int  use)
◆ SetRatio()
virtual void vtkPolarAxesRepresentation::SetRatio ( double  ratio)
◆ SetPolarArcResolutionPerDegree()
virtual void vtkPolarAxesRepresentation::SetPolarArcResolutionPerDegree ( double  resolution)
◆ SetDeltaRangeMinor()
virtual void vtkPolarAxesRepresentation::SetDeltaRangeMinor ( double  delta)
◆ SetDeltaRangeMajor()
virtual void vtkPolarAxesRepresentation::SetDeltaRangeMajor ( double  delta)
◆ SetRendererType()
virtual void vtkPolarAxesRepresentation::SetRendererType ( int  )
Default is to use the vtkPVRenderView::DEFAULT_RENDERER.
◆ GetRendererType()
virtual int vtkPolarAxesRepresentation::GetRendererType ( )
◆ FillInputPortInformation()
int vtkPolarAxesRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestData()
int vtkPolarAxesRepresentation::RequestData ( vtkInformation ,
◆ InitializeDataBoundsFromData()
virtual void vtkPolarAxesRepresentation::InitializeDataBoundsFromData ( vtkDataObject data)
protectedvirtual
◆ UpdateBounds()
virtual void vtkPolarAxesRepresentation::UpdateBounds ( )
protectedvirtual
◆ AddToView()
bool vtkPolarAxesRepresentation::AddToView ( vtkView view)
This is called from vtkView::AddRepresentation(). Returns true if the addition succeeds.
Subclasses should override this method.
◆ RemoveFromView()
bool vtkPolarAxesRepresentation::RemoveFromView ( vtkView view)
This is called from vtkView::RemoveRepresentation(). Returns true if the removal succeeds.
◆ OutlineGeometry
vtkNew<vtkPolyData> vtkPolarAxesRepresentation::OutlineGeometry
Definition at line 309 of file vtkPolarAxesRepresentation.h.
◆ PolarAxesActor
vtkNew<vtkPolarAxesActor> vtkPolarAxesRepresentation::PolarAxesActor
Definition at line 310 of file vtkPolarAxesRepresentation.h.
◆ RenderView
vtkWeakPointer<vtkPVRenderView> vtkPolarAxesRepresentation::RenderView
Definition at line 311 of file vtkPolarAxesRepresentation.h.
◆ Position
double vtkPolarAxesRepresentation::Position[3] = { 0.0 }
Definition at line 312 of file vtkPolarAxesRepresentation.h.
◆ Scale
double vtkPolarAxesRepresentation::Scale[3] = { 1.0 }
Definition at line 313 of file vtkPolarAxesRepresentation.h.
◆ Orientation
double vtkPolarAxesRepresentation::Orientation[3] = { 0.0 }
Definition at line 314 of file vtkPolarAxesRepresentation.h.
◆ CustomBounds
double vtkPolarAxesRepresentation::CustomBounds[6] = { 0.0, 1.0, 0.0, 1.0, 0.0, 1.0 }
Definition at line 315 of file vtkPolarAxesRepresentation.h.
◆ EnableCustomBounds
int vtkPolarAxesRepresentation::EnableCustomBounds[3] = { 0 }
Definition at line 316 of file vtkPolarAxesRepresentation.h.
◆ CustomRange
double vtkPolarAxesRepresentation::CustomRange[2] = { 0.0, 1.0 }
Definition at line 317 of file vtkPolarAxesRepresentation.h.
◆ EnableCustomRange
bool vtkPolarAxesRepresentation::EnableCustomRange = false
Definition at line 318 of file vtkPolarAxesRepresentation.h.
◆ EnableAutoPole
bool vtkPolarAxesRepresentation::EnableAutoPole = true
Definition at line 319 of file vtkPolarAxesRepresentation.h.
◆ EnableCustomAngle
bool vtkPolarAxesRepresentation::EnableCustomAngle = true
Definition at line 320 of file vtkPolarAxesRepresentation.h.
◆ MinAngle
double vtkPolarAxesRepresentation::MinAngle = 0.0
Definition at line 321 of file vtkPolarAxesRepresentation.h.
◆ MaxAngle
double vtkPolarAxesRepresentation::MaxAngle = 90.0
Definition at line 322 of file vtkPolarAxesRepresentation.h.
◆ EnableCustomRadius
bool vtkPolarAxesRepresentation::EnableCustomRadius = true
Definition at line 324 of file vtkPolarAxesRepresentation.h.
◆ MinRadius
double vtkPolarAxesRepresentation::MinRadius = 0.0
Definition at line 325 of file vtkPolarAxesRepresentation.h.
◆ EnableOverallColor
bool vtkPolarAxesRepresentation::EnableOverallColor = true
Definition at line 326 of file vtkPolarAxesRepresentation.h.
◆ OverallColor
double vtkPolarAxesRepresentation::OverallColor[3] = { 1.0 }
Definition at line 327 of file vtkPolarAxesRepresentation.h.
◆ PolarAxisColor
double vtkPolarAxesRepresentation::PolarAxisColor[3] = { 1.0 }
Definition at line 328 of file vtkPolarAxesRepresentation.h.
◆ PolarArcsColor
double vtkPolarAxesRepresentation::PolarArcsColor[3] = { 1.0 }
Definition at line 329 of file vtkPolarAxesRepresentation.h.
◆ SecondaryPolarArcsColor
double vtkPolarAxesRepresentation::SecondaryPolarArcsColor[3] = { 1.0 }
Definition at line 330 of file vtkPolarAxesRepresentation.h.
◆ SecondaryRadialAxesColor
double vtkPolarAxesRepresentation::SecondaryRadialAxesColor[3] = { 1.0 }
Definition at line 331 of file vtkPolarAxesRepresentation.h.
◆ LastRadialAxisColor
double vtkPolarAxesRepresentation::LastRadialAxisColor[3] = { 1.0 }
Definition at line 332 of file vtkPolarAxesRepresentation.h.
◆ DataBounds
double vtkPolarAxesRepresentation::DataBounds[6] = { 0.0 }
Definition at line 333 of file vtkPolarAxesRepresentation.h.
◆ RendererType
int vtkPolarAxesRepresentation::RendererType = vtkPVRenderView::DEFAULT_RENDERER
Definition at line 334 of file vtkPolarAxesRepresentation.h.
◆ ParentVisibility
bool vtkPolarAxesRepresentation::ParentVisibility = true
Definition at line 335 of file vtkPolarAxesRepresentation.h.
◆ DataBoundsTime
vtkTimeStamp vtkPolarAxesRepresentation::DataBoundsTime
Definition at line 336 of file vtkPolarAxesRepresentation.h.
