virtual int | GetNumberOfTimeSteps () |
double | GetTimeStep (int index) |
virtual bool | GetTimeRangeValid () |
virtual double * | GetTimeRange () |
virtual void | GetTimeRange (double &, double &) |
virtual void | GetTimeRange (double [2]) |
virtual vtkDataObject * | GetCurrentInputDataObject () |
void | SetComputedAnnotationValue (const char *value) |
virtual void | SetExpression (const char *) |
| Set the expression to evaluate. More...
virtual char * | GetExpression () |
virtual void | SetArrayAssociation (int) |
| Set the input array association. More...
virtual int | GetArrayAssociation () |
virtual char * | GetComputedAnnotationValue () |
| Get the value that is going to be printed to the output. More...
virtual bool | GetDataTimeValid () |
| Get methods for use in annotation.py. More...
virtual double | GetDataTime () |
vtkTableAlgorithm * | NewInstance () const |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
