virtual char * | GetInitialString () |
virtual int | GetNumberOfElementsPerCommand () |
| If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
virtual bool | GetUseIndex () |
| If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
virtual char * | GetCleanCommand () |
| Command that can be used to remove all values. More...
virtual char * | GetSetNumberCommand () |
| If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
| The name assigned by the xml parser. More...
virtual char * | GetCommand () |
| The command name used to set the value on the server object. More...
virtual bool | GetInformationOnly () |
| Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool | GetRepeatable () |
| If repeatable, a property can have 1 or more values of the same kind. More...
virtual void | SetIsInternal (bool) |
| This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool | GetIsInternal () |
virtual void | Modified () |
