Abstract class for SIProperty that hold an array of values. More...
#include <vtkSIVectorProperty.h>
typedef vtkSIProperty | Superclass |
virtual char * | GetInitialString () |
virtual int | GetNumberOfElementsPerCommand () |
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More... | |
virtual bool | GetUseIndex () |
If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More... | |
virtual char * | GetCleanCommand () |
Command that can be used to remove all values. More... | |
virtual char * | GetSetNumberCommand () |
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More... | |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
static vtkSIVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProperty * | New () |
static vtkSIProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIVectorProperty () | |
~vtkSIVectorProperty () override | |
virtual void | SetCleanCommand (const char *) |
virtual void | SetSetNumberCommand (const char *) |
virtual void | SetInitialString (const char *) |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual bool | Push (vtkSMMessage *, int) |
Push a new state to the underneath implementation. More... | |
virtual bool | Pull (vtkSMMessage *) |
Pull the current state of the underneath implementation. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
char * | SetNumberCommand |
char * | CleanCommand |
bool | UseIndex |
int | NumberOfElementsPerCommand |
char * | InitialString |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
Define the array management API
Definition at line 16 of file vtkSIVectorProperty.h.
Definition at line 19 of file vtkSIVectorProperty.h.
Reimplemented in vtkSIDoubleVectorProperty, vtkSIIdTypeVectorProperty, vtkSIIntVectorProperty, vtkSIStringVectorProperty, and vtkSIVectorPropertyTemplate< T, force_idtype >.
Reimplemented in vtkSIVectorPropertyTemplate< T, force_idtype >.
For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo 1 2 * * Invoke obj SetFoo 3 4 * * Invoke obj SetFoo 5 6 *
For example, if UseIndex and RepeatCommand are true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 5 6 7 8 9 10, the resulting stream will have:
* * Invoke obj SetFoo 0 5 6 * * Invoke obj SetFoo 1 7 8 * * Invoke obj SetFoo 2 9 10 *
Typically used when RepeatCommand = 1. If set, the clean command is called before the main Command.
protectedvirtual |
protectedvirtual |
protectedvirtual |
overrideprotectedvirtual |
Definition at line 78 of file vtkSIVectorProperty.h.
Definition at line 81 of file vtkSIVectorProperty.h.
Definition at line 82 of file vtkSIVectorProperty.h.
Definition at line 83 of file vtkSIVectorProperty.h.
Definition at line 84 of file vtkSIVectorProperty.h.
