#include <vtkSIVectorPropertyTemplate.h>
typedef vtkSIVectorProperty | Superclass |
typedef vtkSIProperty | Superclass |
virtual bool | GetArgumentIsArray () |
If ArgumentIsArray is true, multiple elements are passed in as array arguments. More... | |
virtual char * | GetInitialString () |
virtual int | GetNumberOfElementsPerCommand () |
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More... | |
virtual bool | GetUseIndex () |
If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More... | |
virtual char * | GetCleanCommand () |
Command that can be used to remove all values. More... | |
virtual char * | GetSetNumberCommand () |
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More... | |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
static vtkSIVectorPropertyTemplate * | SafeDownCast (vtkObject *o) |
static vtkSIVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProperty * | New () |
static vtkSIProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIVectorPropertyTemplate () | |
~vtkSIVectorPropertyTemplate () override | |
bool | Push (vtkSMMessage *, int) override |
Push a new state to the underneath implementation. More... | |
bool | Pull (vtkSMMessage *) override |
Pull the current state of the underneath implementation. More... | |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Parse the xml for the property. More... | |
bool | Push (T *values, int number_of_elements) |
Implements the actual push. More... | |
vtkSIVectorProperty () | |
~vtkSIVectorProperty () override | |
virtual void | SetCleanCommand (const char *) |
virtual void | SetSetNumberCommand (const char *) |
virtual void | SetInitialString (const char *) |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | ArgumentIsArray |
char * | SetNumberCommand |
char * | CleanCommand |
bool | UseIndex |
int | NumberOfElementsPerCommand |
char * | InitialString |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 16 of file vtkSIVectorPropertyTemplate.h.
typedef vtkSIVectorProperty vtkSIVectorPropertyTemplate< T, force_idtype >::Superclass |
Definition at line 19 of file vtkSIVectorPropertyTemplate.h.
Reimplemented from vtkSIVectorProperty.
For example, For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo array(1, 2) * * Invoke obj SetFoo array(3, 4) * * Invoke obj SetFoo array(5, 6) *
overrideprotectedvirtual |
Definition at line 62 of file vtkSIVectorPropertyTemplate.h.
