A reader for XML camera configuration. More...
#include <vtkSMCameraConfigurationReader.h>
typedef vtkSMProxyConfigurationReader | Superclass |
void | SetRenderViewProxy (vtkSMProxy *rvProxy) |
Set the render view proxy to extract camera properties from. More... | |
int | ReadConfiguration (const char *filename) override |
Read the named file, and push the properties into the underying managed render view proxy. More... | |
int | ReadConfiguration (vtkPVXMLElement *x) override |
int | ReadConfiguration () override |
virtual void | SetFileDescription (const char *) |
virtual char * | GetFileDescription () |
virtual void | SetFileExtension (const char *) |
virtual char * | GetFileExtension () |
virtual const char * | GetReaderVersion () |
Return the reader version. More... | |
virtual bool | CanReadVersion (const char *version) |
Return true if the reader can read the specified version. More... | |
virtual void | SetFileName (const char *) |
Set/Get the file name. More... | |
virtual char * | GetFileName () |
virtual vtkSMProxy * | GetProxy () |
Set the proxy to write out. More... | |
virtual void | SetFileIdentifier (const char *) |
Set/get file meta data. More... | |
virtual char * | GetFileIdentifier () |
virtual void | SetValidateProxyType (int) |
Turns on/off proxy type validation. More... | |
virtual int | GetValidateProxyType () |
virtual void | Modified () |
static vtkSMCameraConfigurationReader * | SafeDownCast (vtkObject *o) |
static vtkSMCameraConfigurationReader * | New () |
static vtkSMProxyConfigurationReader * | New () |
static vtkSMProxyConfigurationReader * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
bool | Debug |
vtkTimeStamp | MTime |
A reader for XML camera configuration. Reades camera configuration files. written by the vtkSMCameraConfigurationWriter.
Definition at line 28 of file vtkSMCameraConfigurationReader.h.
Definition at line 31 of file vtkSMCameraConfigurationReader.h.
Reimplemented from vtkSMProxyConfigurationReader.
void vtkSMCameraConfigurationReader::SetRenderViewProxy | ( | vtkSMProxy * | rvProxy | ) |
This will make sure the renderview is updated after the read.
inlineoverridevirtual |
Definition at line 49 of file vtkSMCameraConfigurationReader.h.
inlineoverrideprotectedvirtual |
Definition at line 58 of file vtkSMCameraConfigurationReader.h.
