collection of utilities. More...
#include <vtkSMCoreUtilities.h>
virtual void | Modified () |
static vtkSMCoreUtilities * | New () |
static vtkSMCoreUtilities * | SafeDownCast (vtkObject *o) |
static const char * | GetFileNameProperty (vtkSMProxy *) |
Given a proxy (or proxy prototype), returns the name of the property that ParaView application will be use as the default FileName property. More... | |
static std::vector< std::string > | GetFileNameProperties (vtkSMProxy *proxy) |
Returns list of all properties that accept filenames in order that they are defined. More... | |
static std::string | SanitizeName (const char *) |
Sanitize a label/name to be remove spaces, delimiters etc. More... | |
static std::string | SanitizeName (const std::string &name) |
static const char * | GetStringForCellType (int cellType) |
Given a VTK cell type value from the enum in vtkCellTypes.h, returns a string describing that cell type for use if ParaView's GUI. More... | |
static void | ReplaceReaderFileName (vtkSMProxy *proxy, const std::vector< std::string > &files, const char *propName) |
Replaces input proxy, which should be a reader proxy, by a new proxy in the pipeline. More... | |
static std::string | FindLargestPrefix (const std::vector< std::string > &files) |
Find the largest prefix that matches all file names in files, and then append a '*' to signify that it is a collection of files. More... | |
static bool | AdjustRangeForLog (double range[2]) |
Given a range, converts it to be a valid range to switch to log space. More... | |
static bool | AdjustRangeForLog (double &rmin, double &rmax) |
static bool | AdjustRange (double range[2]) |
Adjust the given range to make it suitable for use with color maps. More... | |
static bool | AdjustRange (double &rmin, double &rmax) |
static bool | AlmostEqual (const double range[2], int ulpsDiff) |
Compares val1 and val2 and returns true is the two numbers are within ulpsDiff ULPs (units in last place) from each other. More... | |
static bool | AlmostEqual (double rmin, double rmax, int ulpsDiff) |
static const char * | GetInputPropertyName (vtkSMProxy *proxy, int port=0) |
Given a proxy and a port number get the name of the input. More... | |
static vtkObject * | New () |
vtkSMCoreUtilities () | |
~vtkSMCoreUtilities () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMCoreUtilities provides miscellaneous utility functions.
Definition at line 21 of file vtkSMCoreUtilities.h.
Definition at line 25 of file vtkSMCoreUtilities.h.
Returns the name of the property or nullptr when no such property is found.
inlinestatic |
Definition at line 45 of file vtkSMCoreUtilities.h.
If the range is changed, returns true, otherwise returns false.
Definition at line 56 of file vtkSMCoreUtilities.h.
The current logic (which may change in future) does the following:
false
and keeps the range unchanged.true
if the range was changed, false
is the range was left unchanged. Adjust the given range to make it suitable for use with color maps.
false
is the range was left unchanged. Definition at line 82 of file vtkSMCoreUtilities.h.
Compares val1
and val2
Compares val1
and val2
Definition at line 98 of file vtkSMCoreUtilities.h.
For example it pasesd VTK_TRIANGLE it will return "Triangle". If an unknown cell type is passed to this it returns the string "Unknown".
The new input files are stored in files, and propName
should be the file name property in the reader (usually "FileName" or "FileNames").
If they all start with something different, this returns '*'.
