vtkSMProxyLocator Class Reference
is used to locate proxies referred to in state xmls while loading state files. More...
#include <vtkSMProxyLocator.h>
Inheritance diagram for vtkSMProxyLocator:
Collaboration diagram for vtkSMProxyLocator:
virtual vtkSMProxyLocateProxy (vtkTypeUInt32 globalID)
 Locate a proxy with the given "name". More...
virtual void Clear ()
 Clear the locator. More...
virtual void GetLocatedProxies (vtkCollection *collectionToFill)
 Copy all the Located proxy into the collection. More...
virtual void UseSessionToLocateProxy (bool useSessionToo)
virtual void AssignProxy (vtkTypeUInt32 id, vtkSMProxy *proxy)
 For custom applications managing custom state loading, one can use this method to register proxies with locator to use when LocateProxy() before attempting the standard route i.e. More...
void SetDeserializer (vtkSMDeserializer *)
 Get/Set the de-serializer to used to locate XMLs/Protobuf for unknown proxies requested to be located using LocateProxy(). More...
virtual vtkSMDeserializerGetDeserializer ()
 Get/Set the session. More...
virtual void SetSession (vtkSMSession *s)
static vtkSMProxyLocatorNew ()
static vtkSMProxyLocatorSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMProxyLocator ()
 ~vtkSMProxyLocator () override
virtual vtkSMProxyNewProxy (vtkTypeUInt32 globalID)
 Create new proxy with the given id. More...
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMDeserializerDeserializer
bool LocateProxyWithSessionToo
vtkSMProxyLocator is used to locate proxies referred to in state xmls (and otherwise) when loading state files.
Definition at line 24 of file vtkSMProxyLocator.h.
Definition at line 28 of file vtkSMProxyLocator.h.
◆ vtkSMProxyLocator()
vtkSMProxyLocator::vtkSMProxyLocator ( )
◆ ~vtkSMProxyLocator()
vtkSMProxyLocator::~vtkSMProxyLocator ( )
static vtkSMProxyLocator* vtkSMProxyLocator::New ( )
virtual const char* vtkSMProxyLocator::GetClassName ( )
static int vtkSMProxyLocator::IsTypeOf ( const char *  type)
virtual int vtkSMProxyLocator::IsA ( const char *  type)
static vtkSMProxyLocator* vtkSMProxyLocator::SafeDownCast ( vtkObject o)
void vtkSMProxyLocator::PrintSelf ( ostream &  os,
◆ LocateProxy()
virtual vtkSMProxy* vtkSMProxyLocator::LocateProxy ( vtkTypeUInt32  globalID)
If none can be found returns nullptr. If a proxy with the name was not previously located, it will ask the Deserializer (if any) to create a new proxy is possible.
◆ SetDeserializer()
void vtkSMProxyLocator::SetDeserializer ( vtkSMDeserializer )
◆ GetDeserializer()
virtual vtkSMDeserializer* vtkSMProxyLocator::GetDeserializer ( )
◆ GetSession()
virtual vtkSMSession* vtkSMProxyLocator::GetSession ( )
◆ SetSession()
virtual void vtkSMProxyLocator::SetSession ( vtkSMSession s)
◆ Clear()
virtual void vtkSMProxyLocator::Clear ( )
Clear the locator.
◆ GetLocatedProxies()
virtual void vtkSMProxyLocator::GetLocatedProxies ( vtkCollection collectionToFill)
This allow to keep a reference to them outside of the current locator. This is needed if we don't want to delete those proxy and if we want to Clear() the current ProxyLocator.
◆ UseSessionToLocateProxy()
virtual void vtkSMProxyLocator::UseSessionToLocateProxy ( bool  useSessionToo)
inlinevirtual
Definition at line 68 of file vtkSMProxyLocator.h.
◆ AssignProxy()
virtual void vtkSMProxyLocator::AssignProxy ( vtkTypeUInt32  id,
vtkSMProxy proxy
using the deserializer or session.
◆ NewProxy()
virtual vtkSMProxy* vtkSMProxyLocator::NewProxy ( vtkTypeUInt32  globalID)
protectedvirtual
Default implementation asks the Deserializer, if any, to create a new proxy.
◆ Deserializer
vtkSMDeserializer* vtkSMProxyLocator::Deserializer
Definition at line 91 of file vtkSMProxyLocator.h.
◆ Session
vtkWeakPointer<vtkSMSession> vtkSMProxyLocator::Session
Definition at line 92 of file vtkSMProxyLocator.h.
◆ LocateProxyWithSessionToo
bool vtkSMProxyLocator::LocateProxyWithSessionToo
Definition at line 93 of file vtkSMProxyLocator.h.
