miscellaneous collection of proxy-manager utilities More...
#include <vtkSMProxyManagerUtilities.h>
void | SetProxyManager (vtkSMSessionProxyManager *pxm) |
Get/Set the proxy manager to use. More... | |
virtual vtkSMSessionProxyManager * | GetProxyManager () |
std::set< vtkSMProxy * > | GetProxiesWithAnnotations (const std::map< std::string, std::string > &annotations, bool match_all) |
Returns a collection of proxies that have the specified annotations. More... | |
std::set< vtkSMProxy * > | GetProxiesWithAllAnnotations (const std::map< std::string, std::string > &annotations) |
std::set< vtkSMProxy * > | GetProxiesWithAnyAnnotations (const std::map< std::string, std::string > &annotations) |
std::set< vtkSMProxy * > | CollectHelpersAndRelatedProxies (const std::set< vtkSMProxy *> &proxies) |
Given a set of proxies, scans for all "dependent" proxies and returns a set that includes the proxies together with all the dependent proxies. More... | |
virtual void | Modified () |
static vtkSMProxyManagerUtilities * | New () |
static vtkSMProxyManagerUtilities * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxyManagerUtilities () | |
~vtkSMProxyManagerUtilities () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMProxyManagerUtilities provides collection of APIs useful with dealing with proxies registered with the proxy manager.
Definition at line 27 of file vtkSMProxyManagerUtilities.h.
Definition at line 31 of file vtkSMProxyManagerUtilities.h.
void vtkSMProxyManagerUtilities::SetProxyManager | ( | vtkSMSessionProxyManager * | pxm | ) |
std::set<vtkSMProxy*> vtkSMProxyManagerUtilities::GetProxiesWithAnnotations | ( | const std::map< std::string, std::string > & | annotations, |
bool | match_all | ||
If multiple annotations are specified, the match_all
flag it used to determine if all the annotations are to be matched or match with any of the annotations is sufficient. Alternatively, use GetProxiesWithAllAnnotations
or GetProxiesWithAnyAnnotations
Definition at line 54 of file vtkSMProxyManagerUtilities.h.
Definition at line 59 of file vtkSMProxyManagerUtilities.h.
std::set<vtkSMProxy*> vtkSMProxyManagerUtilities::CollectHelpersAndRelatedProxies | ( | const std::set< vtkSMProxy *> & | proxies | ) |
These proxies are proxies that are used as helper proxies or proxies set on proxy properties.
