vtkSMViewProxyInteractorHelper Class Reference
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy. More...
#include <vtkSMViewProxyInteractorHelper.h>
Inheritance diagram for vtkSMViewProxyInteractorHelper:
Collaboration diagram for vtkSMViewProxyInteractorHelper:
void SetViewProxy (vtkSMViewProxy *proxy)
 Set the view proxy. More...
vtkSMViewProxyGetViewProxy ()
void SetupInteractor (vtkRenderWindowInteractor *iren)
 Set the interactor to "help" the view with. More...
vtkRenderWindowInteractorGetInteractor ()
void CleanupInteractor ()
static vtkSMViewProxyInteractorHelperNew ()
static vtkSMViewProxyInteractorHelperSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMViewProxyInteractorHelper ()
 ~vtkSMViewProxyInteractorHelper () override
void Execute (vtkObject *caller, unsigned long event, void *calldata)
 Handle event. More...
void Render ()
void CleanupTimer ()
void Resize ()
vtkCommandObserver
vtkWeakPointer< vtkSMViewProxyViewProxy
vtkWeakPointer< vtkRenderWindowInteractorInteractor
int DelayedRenderTimerId
bool Interacting
bool Interacted
int EndWindowResizeTimerId = -1
vtkSMViewProxyInteractorHelper is a helper class designed to make it easier to hook up vtkRenderWindowInteractor to call methods on a vtkSMViewProxy (or subclass). It's primarily designed to work with vtkSMRenderViewProxy (and subclasses), but it should work with other types of views too.
To use this helper, the view typically creates an instance for itself as register itself (using vtkSMViewProxyInteractorHelper::SetViewProxy) and then calls vtkSMViewProxyInteractorHelper::SetupInteractor(). This method will initialize the interactor (potentially changing some ivars on the interactor to avoid automatic rendering, using vtkRenderWindowInteractor::EnableRenderOff(), etc.) and setup event observer to monitor interaction.
vtkSMViewProxyInteractorHelper only using vtkSMViewProxy::StillRender() and vtkSMViewProxy::InteractiveRender() APIs directly. However several properties can be optionally present on the view proxy to dictate this class' behaviour. These are as follows:
Definition at line 51 of file vtkSMViewProxyInteractorHelper.h.
Definition at line 55 of file vtkSMViewProxyInteractorHelper.h.
◆ vtkSMViewProxyInteractorHelper()
vtkSMViewProxyInteractorHelper::vtkSMViewProxyInteractorHelper ( )
◆ ~vtkSMViewProxyInteractorHelper()
vtkSMViewProxyInteractorHelper::~vtkSMViewProxyInteractorHelper ( )
static vtkSMViewProxyInteractorHelper* vtkSMViewProxyInteractorHelper::New ( )
virtual const char* vtkSMViewProxyInteractorHelper::GetClassName ( )
static int vtkSMViewProxyInteractorHelper::IsTypeOf ( const char *  type)
virtual int vtkSMViewProxyInteractorHelper::IsA ( const char *  type)
static vtkSMViewProxyInteractorHelper* vtkSMViewProxyInteractorHelper::SafeDownCast ( vtkObject o)
void vtkSMViewProxyInteractorHelper::PrintSelf ( ostream &  os,
◆ SetViewProxy()
void vtkSMViewProxyInteractorHelper::SetViewProxy ( vtkSMViewProxy proxy)
Set the view proxy.
This is a weak reference i.e. the view proxy's reference count will be unchanged by this call.
◆ GetViewProxy()
vtkSMViewProxy* vtkSMViewProxyInteractorHelper::GetViewProxy ( )
Set the view proxy.
◆ SetupInteractor()
void vtkSMViewProxyInteractorHelper::SetupInteractor ( vtkRenderWindowInteractor iren)
This is a weak reference i.e. the interactor's reference count will be unchanged by this call.
◆ GetInteractor()
vtkRenderWindowInteractor* vtkSMViewProxyInteractorHelper::GetInteractor ( )
◆ CleanupInteractor()
void vtkSMViewProxyInteractorHelper::CleanupInteractor ( )
inline
Definition at line 76 of file vtkSMViewProxyInteractorHelper.h.
◆ Execute()
void vtkSMViewProxyInteractorHelper::Execute ( vtkObject caller,
void *  calldata
Handle event.
◆ Render()
void vtkSMViewProxyInteractorHelper::Render ( )
Handle event.
◆ CleanupTimer()
void vtkSMViewProxyInteractorHelper::CleanupTimer ( )
Handle event.
◆ Resize()
void vtkSMViewProxyInteractorHelper::Resize ( )
Handle event.
◆ Observer
vtkCommand* vtkSMViewProxyInteractorHelper::Observer
Definition at line 93 of file vtkSMViewProxyInteractorHelper.h.
◆ ViewProxy
vtkWeakPointer<vtkSMViewProxy> vtkSMViewProxyInteractorHelper::ViewProxy
Definition at line 94 of file vtkSMViewProxyInteractorHelper.h.
◆ Interactor
vtkWeakPointer<vtkRenderWindowInteractor> vtkSMViewProxyInteractorHelper::Interactor
Definition at line 95 of file vtkSMViewProxyInteractorHelper.h.
◆ DelayedRenderTimerId
int vtkSMViewProxyInteractorHelper::DelayedRenderTimerId
Definition at line 96 of file vtkSMViewProxyInteractorHelper.h.
◆ Interacting
bool vtkSMViewProxyInteractorHelper::Interacting
Definition at line 97 of file vtkSMViewProxyInteractorHelper.h.
◆ Interacted
bool vtkSMViewProxyInteractorHelper::Interacted
Definition at line 98 of file vtkSMViewProxyInteractorHelper.h.
◆ EndWindowResizeTimerId
int vtkSMViewProxyInteractorHelper::EndWindowResizeTimerId = -1
Definition at line 100 of file vtkSMViewProxyInteractorHelper.h.
