const vtkRectd & | GetBox () |
| Returns the current box as [x0, y0, width, height]. More...
void | SetBox (double x, double y, double width, double height) |
| Set position and width with respect to corner 0 (BOTTOM_LEFT). More...
vtkSmartPointer< vtkImageData > | GetTexture () const |
| Get access to the texture of this box item. More...
void | SetValidBounds (double x0, double x1, double y0, double y1) override |
virtual void | SetSelected (bool) |
| Set/Get whether the box should be drawn selected. More...
virtual bool | GetSelected () |
virtual void | SelectedOn () |
virtual void | SelectedOff () |
virtual void | SetBoxColor (double r, double g, double b, double a) |
| Set/Get the color to be used for this box. More...
virtual void | SetBoxColor (const double c[4]) |
double * | GetBoxColor () VTK_SIZEHINT(4) |
virtual void | GetBoxColor (double &r, double &g, double &b, double &a) |
virtual void | GetBoxColor (double c[4]) |
void | SetTransferFunctionBox (vtkPVTransferFunction2DBox *b) |
| Set/Get the internal transfer function control box. More...
vtkPVTransferFunction2DBox * | GetTransferFunctionBox () |
virtual void | SetID (int) |
| Set/Get an ID used to reference this item. More...
virtual int | GetID () |
vtkControlPointsItem * | NewInstance () const |
virtual void | GetBounds (double bounds[4]) |
void | SelectPoint (vtkIdType pointId) |
void | SelectPoint (double *currentPoint) |
void | SelectAllPoints () |
void | DeselectPoint (vtkIdType pointId) |
void | DeselectPoint (double *currentPoint) |
void | DeselectAllPoints () |
void | ToggleSelectPoint (vtkIdType pointId) |
void | ToggleSelectPoint (double *currentPoint) |
virtual bool | SelectPoints (const vtkVector2f &min, const vtkVector2f &max) |
vtkIdType | GetNumberOfSelectedPoints () const |
vtkIdType | FindPoint (double *pos) |
bool | IsOverPoint (double *pos, vtkIdType pointId) |
vtkIdType | GetControlPointId (double *pos) |
vtkIdType | RemovePoint (vtkIdType pointId) |
void | RemoveCurrentPoint () |
void | MovePoints (const vtkVector2f &translation, vtkIdTypeArray *pointIds) |
void | MovePoints (const vtkVector2f &translation, bool dontMoveFirstAndLast=false) |
void | SpreadPoints (float factor, vtkIdTypeArray *pointIds) |
void | SpreadPoints (float factor, bool dontSpreadFirstAndLast=false) |
vtkIdType | GetCurrentPoint () const |
void | SetCurrentPoint (vtkIdType index) |
void | ResetBounds () |
virtual void | SetUserBounds (double, double, double, double) |
virtual void | SetUserBounds (double[4]) |
virtual double * | GetUserBounds () |
virtual void | GetUserBounds (double &, double &, double &, double &) |
virtual void | GetUserBounds (double[4]) |
virtual void | SetValidBounds (double[4]) |
virtual double * | GetValidBounds () |
virtual void | GetValidBounds (double &, double &, double &, double &) |
virtual void | GetValidBounds (double[4]) |
virtual float | GetScreenPointRadius () |
virtual void | SetScreenPointRadius (float) |
void | GetControlPointsIds (vtkIdTypeArray *ids, bool excludeFirstAndLast=false) const |
virtual bool | GetStrokeMode () |
virtual void | SetSwitchPointsMode (bool) |
virtual bool | GetSwitchPointsMode () |
virtual void | SetEndPointsXMovable (bool) |
virtual bool | GetEndPointsXMovable () |
virtual void | SetEndPointsYMovable (bool) |
virtual bool | GetEndPointsYMovable () |
virtual bool | GetEndPointsMovable () |
virtual void | SetEndPointsRemovable (bool) |
virtual bool | GetEndPointsRemovable () |
virtual void | SetShowLabels (bool) |
virtual bool | GetShowLabels () |
virtual void | SetLabelFormat (const char *) |
virtual char * | GetLabelFormat () |
virtual vtkPen * | GetSelectedPointPen () |
virtual vtkBrush * | GetSelectedPointBrush () |
vtkPlot * | NewInstance () const |
virtual bool | SelectPointsInPolygon (const vtkContextPolygon &polygon) |
virtual void | SetWidth (float width) |
virtual float | GetWidth () |
virtual void | SetLabel (const vtkStdString &label) |
virtual vtkStdString | GetLabel () |
virtual void | SetLabels (vtkStringArray *labels) |
virtual vtkStringArray * | GetLabels () |
virtual int | GetNumberOfLabels () |
vtkStdString | GetLabel (vtkIdType index) |
void | SetIndexedLabels (vtkStringArray *labels) |
virtual vtkStringArray * | GetIndexedLabels () |
vtkContextMapper2D * | GetData () |
virtual vtkTable * | GetInput () |
virtual void | SetInputArray (int index, const vtkStdString &name) |
virtual void | UpdateCache () |
virtual void | SetLegendVisibility (bool) |
virtual bool | GetLegendVisibility () |
virtual void | LegendVisibilityOn () |
virtual void | LegendVisibilityOff () |
virtual bool | PaintLegend (vtkContext2D *painter, const vtkRectf &rect, int legendIndex) |
virtual void | SetTooltipLabelFormat (const vtkStdString &label) |
virtual vtkStdString | GetTooltipLabelFormat () |
virtual void | SetTooltipNotation (int notation) |
virtual int | GetTooltipNotation () |
virtual void | SetTooltipPrecision (int precision) |
virtual int | GetTooltipPrecision () |
virtual vtkStdString | GetTooltipLabel (const vtkVector2d &plotPos, vtkIdType seriesIndex, vtkIdType segmentIndex) |
virtual vtkIdType | GetNearestPoint (const vtkVector2f &point, const vtkVector2f &tolerance, vtkVector2f *location) |
virtual void | SetColor (unsigned char r, unsigned char g, unsigned char b, unsigned char a) |
virtual void | SetColor (double r, double g, double b) |
virtual void | GetColor (double rgb[3]) |
void | GetColor (unsigned char rgb[3]) |
void | SetPen (vtkPen *pen) |
vtkPen * | GetPen () |
void | SetBrush (vtkBrush *brush) |
vtkBrush * | GetBrush () |
void | SetSelectionPen (vtkPen *pen) |
vtkPen * | GetSelectionPen () |
void | SetSelectionBrush (vtkBrush *brush) |
vtkBrush * | GetSelectionBrush () |
virtual bool | GetUseIndexForXSeries () |
virtual void | SetUseIndexForXSeries (bool) |
virtual void | SetInputData (vtkTable *table) |
virtual void | SetInputData (vtkTable *table, const vtkStdString &xColumn, const vtkStdString &yColumn) |
void | SetInputData (vtkTable *table, vtkIdType xColumn, vtkIdType yColumn) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
virtual void | SetSelection (vtkIdTypeArray *id) |
virtual vtkIdTypeArray * | GetSelection () |
virtual vtkAxis * | GetXAxis () |
virtual void | SetXAxis (vtkAxis *axis) |
virtual vtkAxis * | GetYAxis () |
virtual void | SetYAxis (vtkAxis *axis) |
void | SetShiftScale (const vtkRectd &scaling) |
vtkRectd | GetShiftScale () |
virtual void | GetUnscaledInputBounds (double bounds[4]) |
virtual void | SetProperty (const vtkStdString &property, const vtkVariant &var) |
virtual vtkVariant | GetProperty (const vtkStdString &property) |
vtkContextItem * | NewInstance () const |
virtual double | GetOpacity () |
virtual void | SetOpacity (double) |
vtkAbstractContextItem * | NewInstance () const |
virtual void | Update () |
virtual bool | PaintChildren (vtkContext2D *painter) |
virtual void | ReleaseGraphicsResources () |
unsigned int | AddItem (vtkAbstractContextItem *item) |
bool | RemoveItem (vtkAbstractContextItem *item) |
bool | RemoveItem (unsigned int index) |
vtkAbstractContextItem * | GetItem (unsigned int index) |
unsigned int | GetItemIndex (vtkAbstractContextItem *item) |
unsigned int | GetNumberOfItems () |
void | ClearItems () |
unsigned int | Raise (unsigned int index) |
unsigned int | Lower (unsigned int index) |
virtual vtkAbstractContextItem * | GetPickedItem (const vtkContextMouseEvent &mouse) |
virtual bool | MouseEnterEvent (const vtkContextMouseEvent &mouse) |
virtual bool | MouseLeaveEvent (const vtkContextMouseEvent &mouse) |
virtual bool | MouseWheelEvent (const vtkContextMouseEvent &mouse, int delta) |
virtual void | SetScene (vtkContextScene *scene) |
virtual void | SetParent (vtkAbstractContextItem *parent) |
virtual vtkVector2f | MapToParent (const vtkVector2f &point) |
virtual vtkVector2f | MapFromParent (const vtkVector2f &point) |
virtual vtkVector2f | MapToScene (const vtkVector2f &point) |
virtual vtkVector2f | MapFromScene (const vtkVector2f &point) |
virtual unsigned int | StackAbove (unsigned int index, unsigned int under) |
virtual unsigned int | StackUnder (unsigned int child, unsigned int above) |
vtkContextScene * | GetScene () |
vtkAbstractContextItem * | GetParent () |
virtual bool | GetVisible () |
virtual void | SetVisible (bool) |
virtual bool | GetInteractive () |
virtual void | SetInteractive (bool) |
virtual void | Modified () |
