test.common.cmake
1 # TODO: Split these up and put them in the conditional which actually requires
2 # the data.
3 ExternalData_Expand_Arguments(ParaViewData _
4  "DATA{${paraview_test_data_directory_input}/Data/,REGEX:tensors_.*\\.vti}"
5  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/,REGEX:.*}"
6  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/,REGEX:.*}"
7  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/Level_0/,REGEX:.*}"
8  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/,REGEX:.*}"
9  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/Level_0/,REGEX:.*}"
10  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/,REGEX:.*}"
11  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/Level_0/,REGEX:.*}"
12  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/,REGEX:.*}"
13  "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/Level_0/,REGEX:.*}"
14  "DATA{${paraview_test_data_directory_input}/Data/AxisAlignedSliceBackwardCompat.pvsm}"
15  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/,REGEX:.*}"
16  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/Level_0/,REGEX:.*}"
17  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/,REGEX:.*}"
18  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/Level_0/,REGEX:.*}"
19  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/,REGEX:.*}"
20  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/Level_0/,REGEX:.*}"
21  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/,REGEX:.*}"
22  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/Level_0/,REGEX:.*}"
23  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/,REGEX:.*}"
24  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/Level_0/,REGEX:.*}"
25  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/,REGEX:.*}"
26  "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/Level_0/,REGEX:.*}"
27  "DATA{${paraview_test_data_directory_input}/Data/paraview_icon.svg}"
28  "DATA{${paraview_test_data_directory_input}/Data/3GQP.pdb}"
29  "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}"
30  "DATA{${paraview_test_data_directory_input}/Data/CameraWidgetViewLinkState.pvsm}"
31  "DATA{${paraview_test_data_directory_input}/Data/can-restarts/,REGEX:.*}"
32  "DATA{${paraview_test_data_directory_input}/Data/CellDataWithNan.vtu}"
33  "DATA{${paraview_test_data_directory_input}/Data/cloud_layers_1k.jpg}"
34  "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphInput.vtp}"
35  "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree/,REGEX:.*}"
36  "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree.vtm}"
37  "DATA{${paraview_test_data_directory_input}/Data/ConfigureCategories.xml}"
38  "DATA{${paraview_test_data_directory_input}/Data/convergecfd_post_5016_spray.h5}"
39  "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}"
40  "DATA{${paraview_test_data_directory_input}/Data/cube_1ts_mod.e}"
41  "DATA{${paraview_test_data_directory_input}/Data/CubeStringArray.vtk}"
42  "DATA{${paraview_test_data_directory_input}/Data/EnSight/,REGEX:.*}"
43  "DATA{${paraview_test_data_directory_input}/Data/ExRestarts/,REGEX:.*}"
44  "DATA{${paraview_test_data_directory_input}/Data/FDS/test_core/,REGEX:.*}"
45  "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/,REGEX:.*}"
46  "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/FieldDataBlocks/,REGEX:.*}"
47  "DATA{${paraview_test_data_directory_input}/Data/FileSeries/,REGEX:.*}"
48  "DATA{${paraview_test_data_directory_input}/Data/FileListPropertyWidgetPlugin.xml}"
49  "DATA{${paraview_test_data_directory_input}/Data/GenericIOReader/,REGEX:.*}"
50  "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.mhd}"
51  "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.raw}"
52  "DATA{${paraview_test_data_directory_input}/Data/hdf_fpm_simulation.erfh5}"
53  "DATA{${paraview_test_data_directory_input}/Data/Iron_Xdmf/,REGEX:.*}"
54  "DATA{${paraview_test_data_directory_input}/Data/LoadState.pvsm}"
55  "DATA{${paraview_test_data_directory_input}/Data/LoadStateDialog.pvsm}"
56  "DATA{${paraview_test_data_directory_input}/Data/LoadStateTextSourceRepresentation.pvsm}"
57  "DATA{${paraview_test_data_directory_input}/Data/MinimalTensors.vtu}"
58  "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces.vtm}"
59  "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_0_0.vtp}"
60  "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_1_0.vtp}"
61  "DATA{${paraview_test_data_directory_input}/Data/NE2_ps_bath.png}"
62  "DATA{${paraview_test_data_directory_input}/Data/OMETIFF/multi-channel-time-series.ome.tif}"
63  "DATA{${paraview_test_data_directory_input}/Data/OverridePropertyPlugin.xml}"
64  "DATA{${paraview_test_data_directory_input}/Data/PlotOverLineLegacy.pvsm}"
65  "DATA{${paraview_test_data_directory_input}/Data/PLOAD_C_xMax.bdf}"
66  "DATA{${paraview_test_data_directory_input}/Data/PNGReadersPlugin.xml}"
67  "DATA{${paraview_test_data_directory_input}/Data/PropertyLink.pvsm}"
68  "DATA{${paraview_test_data_directory_input}/Data/ReaderNamePlugin.xml}"
69  "DATA{${paraview_test_data_directory_input}/Data/RectGrid2.vtk}"
70  "DATA{${paraview_test_data_directory_input}/Data/RodPlate/,REGEX:.*}"
71  "DATA{${paraview_test_data_directory_input}/Data/SLAC/pic-example/,REGEX:.*}"
72  "DATA{${paraview_test_data_directory_input}/Data/SPCTH/,REGEX:.*}"
73  "DATA{${paraview_test_data_directory_input}/Data/SPCTH/Dave_Karelitz_Small/,REGEX:.*}"
74  "DATA{${paraview_test_data_directory_input}/Data/SPCTH/DerivedDensity/,REGEX:.*}"
75  "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.h5}"
76  "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.xmf}"
77  "DATA{${paraview_test_data_directory_input}/Data/Test1.h5}"
78  "DATA{${paraview_test_data_directory_input}/Data/Test1.xmf}"
79  "DATA{${paraview_test_data_directory_input}/Data/TestCompositePropertyWidgetDecoratorPlugin.xml}"
80  "DATA{${paraview_test_data_directory_input}/Data/TestMultipleNumberOfComponentsPlugin.xml}"
81  "DATA{${paraview_test_data_directory_input}/Data/VisItBridge/,REGEX:.*}"
82  "DATA{${paraview_test_data_directory_input}/Data/nek5000/eddy_uv/,REGEX:.*}"
83  "DATA{${paraview_test_data_directory_input}/Data/amr/,REGEX:.*}"
84  "DATA{${paraview_test_data_directory_input}/Data/amr/wavelet/,REGEX:.*}"
85  "DATA{${paraview_test_data_directory_input}/Data/artifact.dta}"
86  "DATA{${paraview_test_data_directory_input}/Data/amr_gaussian_pulse.vtkhdf}"
87  "DATA{${paraview_test_data_directory_input}/Data/blow.vtk}"
88  "DATA{${paraview_test_data_directory_input}/Data/blow_data.myvtk}"
89  "DATA{${paraview_test_data_directory_input}/Data/bluntfin.vts}"
90  "DATA{${paraview_test_data_directory_input}/Data/BoxWithFaceData.cgns}"
91  "DATA{${paraview_test_data_directory_input}/Data/can.ex2}"
92  "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.0}"
93  "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.1}"
94  "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.2}"
95  "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.3}"
96  "DATA{${paraview_test_data_directory_input}/Data/cavity/,REGEX:.*}"
97  "DATA{${paraview_test_data_directory_input}/Data/cavity/system/,RECURSE:,REGEX:.*}"
98  "DATA{${paraview_test_data_directory_input}/Data/cavity/constant/,RECURSE:,REGEX:.*}"
99  "DATA{${paraview_test_data_directory_input}/Data/cavity/0/,RECURSE:,REGEX:.*}"
100  "DATA{${paraview_test_data_directory_input}/Data/cavity/0.5/,RECURSE:,REGEX:.*}"
101  "DATA{${paraview_test_data_directory_input}/Data/cavity/1/,RECURSE:,REGEX:.*}"
102  "DATA{${paraview_test_data_directory_input}/Data/cavity/1.5/,RECURSE:,REGEX:.*}"
103  "DATA{${paraview_test_data_directory_input}/Data/cavity/2/,RECURSE:,REGEX:.*}"
104  "DATA{${paraview_test_data_directory_input}/Data/cavity/2.5/,RECURSE:,REGEX:.*}"
105  "DATA{${paraview_test_data_directory_input}/Data/cgns_np01/,REGEX:.*}"
106  "DATA{${paraview_test_data_directory_input}/Data/cgns_np04/,REGEX:.*}"
107  "DATA{${paraview_test_data_directory_input}/Data/bc_struct.cgns}"
108  "DATA{${paraview_test_data_directory_input}/Data/comb.q}"
109  "DATA{${paraview_test_data_directory_input}/Data/combxyz.bin}"
110  "DATA{${paraview_test_data_directory_input}/Data/cow.vtp}"
111  "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}"
112  "DATA{${paraview_test_data_directory_input}/Data/cube.off}"
113  "DATA{${paraview_test_data_directory_input}/Data/cube.vtu}"
114  "DATA{${paraview_test_data_directory_input}/Data/cylinder_run1.e}"
115  "DATA{${paraview_test_data_directory_input}/Data/cylinder_run2.e}"
116  "DATA{${paraview_test_data_directory_input}/Data/disk_out_ref.ex2}"
117  "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.clone.pvd}"
118  "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.pvd}"
119  "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation/,REGEX:.*}"
120  "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation4.pvd}"
121  "DATA{${paraview_test_data_directory_input}/Data/elements.vtu}"
122  "DATA{${paraview_test_data_directory_input}/Data/EngineSector.cgns}"
123  "DATA{${paraview_test_data_directory_input}/Data/ensemble-wavelet/,REGEX:.*}"
124  "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp}"
125  "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp.dir/,REGEX:.*}"
126  "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp}"
127  "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp.dir/,REGEX:.*}"
128  "DATA{${paraview_test_data_directory_input}/Data/field.vtk}"
129  "DATA{${paraview_test_data_directory_input}/Data/filters.xml}"
130  "DATA{${paraview_test_data_directory_input}/Data/glTF/AnimatedMorphCube/,REGEX:.*}"
131  "DATA{${paraview_test_data_directory_input}/Data/glTF/BoxAnimated/,REGEX:.*}"
132  "DATA{${paraview_test_data_directory_input}/Data/glTF/InterpolationTest/,REGEX:.*}"
133  "DATA{${paraview_test_data_directory_input}/Data/glTF/NestedRings/NestedRings.glb}"
134  "DATA{${paraview_test_data_directory_input}/Data/glTF/Triangle/Triangle.glb}"
135  "DATA{${paraview_test_data_directory_input}/Data/glTF/SimpleSkin/SimpleSkin.gltf}"
136  "DATA{${paraview_test_data_directory_input}/Data/glTF/WaterBottle/WaterBottle.glb}"
137  "DATA{${paraview_test_data_directory_input}/Data/HTG/binary_3D_333_mask.htg}"
138  "DATA{${paraview_test_data_directory_input}/Data/HTG/ghost.htg}"
139  "DATA{${paraview_test_data_directory_input}/Data/HTGMulti.vtm}"
140  "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_0_0.htg}"
141  "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_1_0.htg}"
142  "DATA{${paraview_test_data_directory_input}/Data/WaveletGradientLegacy.pvsm}"
143  "DATA{${paraview_test_data_directory_input}/Data/img1.png}"
144  "DATA{${paraview_test_data_directory_input}/Data/img1.mypng}"
145  "DATA{${paraview_test_data_directory_input}/Data/img2.png}"
146  "DATA{${paraview_test_data_directory_input}/Data/iron_protein.vtk}"
147  "DATA{${paraview_test_data_directory_input}/Data/linesPolydata.vtk}"
148  "DATA{${paraview_test_data_directory_input}/Data/LogoSource.png}"
149  "DATA{${paraview_test_data_directory_input}/Data/manyTypes.vtu}"
150  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces.vtm}"
151  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_0.vtu}"
152  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_1.vtu}"
153  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_0.vtu}"
154  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_1.vtu}"
155  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_0.vtu}"
156  "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_1.vtu}"
157  "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062.vtm}"
158  "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062/,REGEX:.*}"
159  "DATA{${paraview_test_data_directory_input}/Data/multicomb_0.vts}"
160  "DATA{${paraview_test_data_directory_input}/Data/multicomb_1.vts}"
161  "DATA{${paraview_test_data_directory_input}/Data/multicomb_2.vts}"
162  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece.vtm}"
163  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece1.vts}"
164  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece2.vts}"
165  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece3.vts}"
166  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece4.vts}"
167  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece5.vts}"
168  "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece6.vts}"
169  "DATA{${paraview_test_data_directory_input}/Data/non_convex_polygon.vtu}"
170  "DATA{${paraview_test_data_directory_input}/Data/office.binary.vtk}"
171  "DATA{${paraview_test_data_directory_input}/Data/OMF/test_file.omf}"
172  "DATA{${paraview_test_data_directory_input}/Data/OSPRayMaterials/materials.json}"
173  "DATA{${paraview_test_data_directory_input}/Data/pbrSpheres.vtp}"
174  "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresAlbedo.jpg}"
175  "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresORM.jpg}"
176  "DATA{${paraview_test_data_directory_input}/Data/pointSet.vtk}"
177  "DATA{${paraview_test_data_directory_input}/Data/ParaView_Mark.png}"
178  "DATA{${paraview_test_data_directory_input}/Data/ParaView_Logo.png}"
179  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_0_0.vtp}"
180  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_1_0.vtp}"
181  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_2_0.vtp}"
182  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_3_0.vtp}"
183  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_4_0.vtp}"
184  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_5_0.vtp}"
185  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_6_0.vtp}"
186  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_7_0.vtp}"
187  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_8_0.vtp}"
188  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_9_0.vtp}"
189  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_10_0.vtp}"
190  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_11_0.vtp}"
191  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_12_0.vtp}"
192  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_13_0.vtp}"
193  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_14_0.vtp}"
194  "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData.vtm}"
195  "DATA{${paraview_test_data_directory_input}/Data/PolarAxesDeprecation.pvsm}"
196  "DATA{${paraview_test_data_directory_input}/Data/porphyrin.cml}"
197  "DATA{${paraview_test_data_directory_input}/Data/quadraticTetra01.vtu}"
198  "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells.pvtu}"
199  "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_0.vtu}"
200  "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_1.vtu}"
201  "DATA{${paraview_test_data_directory_input}/Data/random_torus.vtp}"
202  "DATA{${paraview_test_data_directory_input}/Data/room.cas.h5}"
203  "DATA{${paraview_test_data_directory_input}/Data/room.dat.h5}"
204  "DATA{${paraview_test_data_directory_input}/Data/sample.h5part}"
205  "DATA{${paraview_test_data_directory_input}/Data/servers-wiki.pvsc}"
206  "DATA{${paraview_test_data_directory_input}/Data/Udirectory/coneScript.py}"
207  "DATA{${paraview_test_data_directory_input}/Data/Udirectory/simpleScript.py}"
208  "DATA{${paraview_test_data_directory_input}/Data/Udirectory/LinkRenderViewsCheckSize.py}"
209  "DATA{${paraview_test_data_directory_input}/Data/Udirectory/resetSession.py}"
210  "DATA{${paraview_test_data_directory_input}/Data/sineWaves.csv}"
211  "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation.pvd}"
212  "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation/,REGEX:.*}"
213  "DATA{${paraview_test_data_directory_input}/Data/spiaggia_di_mondello_1k.hdr}"
214  "DATA{${paraview_test_data_directory_input}/Data/SliceDeprecation.pvsm}"
215  "DATA{${paraview_test_data_directory_input}/Data/SteeringDataGeneratorPlugin.xml}"
216  "DATA{${paraview_test_data_directory_input}/Data/squareBend/,REGEX:.*}"
217  "DATA{${paraview_test_data_directory_input}/Data/squareBend/system/,RECURSE:,REGEX:.*}"
218  "DATA{${paraview_test_data_directory_input}/Data/squareBend/constant/,RECURSE:,REGEX:.*}"
219  "DATA{${paraview_test_data_directory_input}/Data/squareBend/50/,RECURSE:,REGEX:.*}"
220  "DATA{${paraview_test_data_directory_input}/Data/squareBend/100/,RECURSE:,REGEX:.*}"
221  "DATA{${paraview_test_data_directory_input}/Data/tensors.pvti}"
222  "DATA{${paraview_test_data_directory_input}/Data/test_fielddata.vtk}"
223  "DATA{${paraview_test_data_directory_input}/Data/test_transient_poly_data.vtkhdf}"
224  "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol/,REGEX:.*}"
225  "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol.vtpc}"
226  "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds/,REGEX:.*}"
227  "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds.vtpd}"
228  "DATA{${paraview_test_data_directory_input}/Data/time_source.pvsm}"
229  "DATA{${paraview_test_data_directory_input}/Data/timestep_0_15.vts}"
230  "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_htg.pio}"
231  "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_ug.pio}"
232  "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000000}"
233  "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000010}"
234  "DATA{${paraview_test_data_directory_input}/Data/tube.exo}"
235  "DATA{${paraview_test_data_directory_input}/Data/Unbalanced3DepthOctTree3x2x3.htg}"
236  "DATA{${paraview_test_data_directory_input}/Data/vehicle_data.csv}"
237  "DATA{${paraview_test_data_directory_input}/Data/viscoplastic-ring.h5}"
238  "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/pdc_multi.vtkhdf}"
239  "DATA{${paraview_test_data_directory_input}/Data/waveletElevation.vti}"
240  "DATA{${paraview_test_data_directory_input}/Data/waveletMaterial.vti}"
241  "DATA{${paraview_test_data_directory_input}/Data/WaveletThresholdLegacy.pvsm}"
242  "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_1.json}"
243  "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_2.json}"
244  "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs.vtm}"
245  "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_0.vtu}"
246  "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_1.vtu}"
247  "DATA{${paraview_test_data_directory_input}/Data/ugrid.nc}"
248  "DATA{${paraview_test_data_directory_input}/Data/UnstructuredGridWithTwoAdjacentHexahedraOfDifferentOrder.vtu}"
249  "DATA{${paraview_test_data_directory_input}/Data/DecimatePolyline.vtp}"
250
251  # Baselines
252  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAXAxis.png}"
253  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAYAxis.png}"
254  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAZAxis.png}"
255  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AnisotropyPBR.png}"
256  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid1.png}"
257  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid2.png}"
258  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid3.png}"
259  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid4.png}"
260  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid6.png}"
261  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid7.png}"
262  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid8.png}"
263  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid9.png}"
264  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid10.png}"
265  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BatchAxesGrid.png}"
266  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideOneBlock.png}"
267  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideTwoBlocks.png}"
268  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowAllBlocks.png}"
269  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowOneBlock.png}"
270  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowZeroBlock.png}"
271  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-BlockOpacity.png}"
272  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowAllBlocks.png}"
273  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowOnlyBlock.png}"
274  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-UnsetBlockOpacity.png}"
275  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MB.png}"
276  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MBWithPieces.png}"
277  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC.png}"
278  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC_1.png}"
279  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-Transform.png}"
280  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipDefault.png}"
281  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipCheckUseReferenceBounds.png}"
282  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipUncheckUseReferenceBounds.png}"
283  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable1.png}"
284  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable2.png}"
285  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel.png}"
286  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel_1.png}"
287  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective.png}"
288  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective_1.png}"
289  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterA.png}"
290  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterB.png}"
291  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterC.png}"
292  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterD.png}"
293  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoriesWithNaN.png}"
294  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderCellMesh.png}"
295  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderFaceMesh.png}"
296  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsA.png}"
297  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsB.png}"
298  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsC.png}"
299  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsD.png}"
300  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsE.png}"
301  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsF.png}"
302  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsG.png}"
303  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsH.png}"
304  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_A.png}"
305  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_B.png}"
306  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA.png}"
307  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_1.png}"
308  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_2.png}"
309  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesB.png}"
310  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartsClearSelection.png}"
311  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Clamped.png}"
312  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Unchanged.png}"
313  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS6.png}"
314  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorBy.png}"
315  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing.png}"
316  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing_A.png}"
317  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles.png}"
318  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_A.png}"
319  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_B.png}"
320  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_A.png}"
321  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_B.png}"
322  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_C.png}"
323  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_D.png}"
324  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_E.png}"
325  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_F.png}"
326  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_G.png}"
327  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_M.png}"
328  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_R.png}"
329  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_T.png}"
330  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_U.png}"
331  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_V.png}"
332  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendBackground.png}"
333  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendScaledScreenshot.png}"
334  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-Default.png}"
335  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-SurfaceEdgesRepr.png}"
336  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-WithAngle.png}"
337  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountAscending.png}"
338  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountDescending.png}"
339  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour1.png}"
340  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour2.png}"
341  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3.png}"
342  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_1.png}"
343  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_2.png}"
344  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_A.png}"
345  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_B.png}"
346  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourCellData.png}"
347  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDCGNSReader.png}"
348  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh.png}"
349  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh_1.png}"
350  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderParcels.png}"
351  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConvertToMoleculeBonds.png}"
352  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenX.png}"
353  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenZ.png}"
354  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeLowerMagnitude.png}"
355  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeUpperMagnitude.png}"
356  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomTCoords.png}"
357  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints.png}"
358  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_A.png}"
359  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_B.png}"
360  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid2X.png}"
361  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-Custom.png}"
362  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-CustomWithReset.png}"
363  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineAngle.png}"
364  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldHigh.png}"
365  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldLow.png}"
366  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineDistance.png}"
367  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser0.png}"
368  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser1.png}"
369  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser2.png}"
370  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EdgeTintPBR.png}"
371  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EDLWithSubsampling.png}"
372  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource1.png}"
373  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource2.png}"
374  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource3.png}"
375  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT0.png}"
376  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT1.png}"
377  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT3.png}"
378  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutA.png}"
379  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutB.png}"
380  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_A.png}"
381  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_B.png}"
382  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType.png}"
383  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType2.png}"
384  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType3.png}"
385  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed.png}"
386  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_1.png}"
387  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_2.png}"
388  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_3.png}"
389  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExodusModeShapes.png}"
390  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EyeDomeLighting.png}"
391  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource1.png}"
392  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource2.png}"
393  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource3.png}"
394  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource4.png}"
395  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesFilterHTG.png}"
396  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTG.png}"
397  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTGNoMask.png}"
398  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesNonlinearCells.png}"
399  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesRepresentationHTG.png}"
400  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_cartesian.png}"
401  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_blocks.png}"
402  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries1.png}"
403  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries2.png}"
404  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataTrace.png}"
405  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-is.png}"
406  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-oneof.png}"
407  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-range.png}"
408  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-is.png}"
409  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-min-max-per-block.png}"
410  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge.png}"
411  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge-mean.png}"
412  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le.png}"
413  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le-mean.png}"
414  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-max.png}"
415  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-mean.png}"
416  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-min.png}"
417  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-MultipleQueries.png}"
418  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocation.png}"
419  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocationMultiblock.png}"
420  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataDialogNaN.png}"
421  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FreezeQueryMultiblock.png}"
422  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ForceTimeDiamond.png}"
423  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterNestedRings.png}"
424  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterWaterBottle.png}"
425  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderTriangle.png}"
426  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing.png}"
427  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing_IsLoaded.png}"
428  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_IsLoaded.png}"
429  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_SceneOne.png}"
430  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes.png}"
431  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_IsLoaded.png}"
432  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_ThreeAnimations.png}"
433  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations.png}"
434  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsLoaded.png}"
435  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsSkinned.png}"
436  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation.png}"
437  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageDistributed.png}"
438  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageSerial.png}"
439  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe1.png}"
440  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe2.png}"
441  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe3.png}"
442  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe4.png}"
443  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe5.png}"
444  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe6.png}"
445  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe7.png}"
446  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe8.png}"
447  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe9.png}"
448  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe10.png}"
449  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder.png}"
450  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder_1.png}"
451  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_A.png}"
452  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_B.png}"
453  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_C.png}"
454  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1.png}"
455  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1_1.png}"
456  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2.png}"
457  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2_1.png}"
458  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection3.png}"
459  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4.png}"
460  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4_1.png}"
461  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip1-Plane.png}"
462  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip2-RevPlane.png}"
463  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip3-Box.png}"
464  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisCut.png}"
465  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisReflection.png}"
466  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridCellCenters.png}"
467  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContour.png}"
468  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContour_1.png}"
469  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA.png}"
470  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA_1.png}"
471  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyB.png}"
472  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridDepthLimiter.png}"
473  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridEvaluateCoarse.png}"
474  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridExtractGhostCells.png}"
475  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGeometry.png}"
476  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGradient.png}"
477  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultiBlock.png}"
478  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultipleClip.png}"
479  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridObliquePlaneCutter.png}"
480  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridPlaneCutter.png}"
481  #"DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold.png}"
482  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthOne.png}"
483  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthTwo.png}"
484  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization.png}"
485  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization_1.png}"
486  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove1.png}"
487  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove2.png}"
488  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightWidget.png}"
489  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightToolbar.png}"
490  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection1.png}"
491  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection1_1.png}"
492  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection2.png}"
493  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection2_1.png}"
494  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection4.png}"
495  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection4_1.png}"
496  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView.png}"
497  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_1.png}"
498  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_2.png}"
499  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkViewsLinked.png}"
500  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LoadStateMultiView.png}"
501  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap1.png}"
502  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap2.png}"
503  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap3.png}"
504  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap4.png}"
505  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap5.png}"
506  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap6.png}"
507  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap7.png}"
508  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle1.png}"
509  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle2.png}"
510  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSource.png}"
511  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourceDefault.png}"
512  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourcesInChartViews.png}"
513  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MatchBoundariesIgnoringCellOrder.png}"
514  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials1.png}"
515  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials2.png}"
516  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials1.png}"
517  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials2.png}"
518  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials1.png}"
519  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials2.png}"
520  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials3.png}"
521  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene1.png}"
522  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene2.png}"
523  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene3.png}"
524  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MathTextColumn.png}"
525  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergePointBlocks.png}"
526  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergeVectorComponents.png}"
527  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-BallStick.png}"
528  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Custom.png}"
529  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Liquorice.png}"
530  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionPlotView.png}"
531  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionRenderView.png}"
532  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorMultiBlock.png}"
533  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties.png}"
534  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_A.png}"
535  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_B.png}"
536  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_C.png}"
537  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_D.png}"
538  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_E.png}"
539  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_F.png}"
540  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_G.png}"
541  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_H.png}"
542  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_I.png}"
543  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_J.png}"
544  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_K.png}"
545  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectBlock2.png}"
546  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectElementBlocks.png}"
547  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-HideBlock1.png}"
548  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorWithoutSelectOnClickSetting.png}"
549  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultipleColorOnSelectionA.png}"
550  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews.png}"
551  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews_1.png}"
552  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NetCDFUGRID.png}"
553  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display.png}"
554  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display_1.png}"
555  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display.png}"
556  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display_1.png}"
557  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display.png}"
558  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display_1.png}"
559  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display.png}"
560  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display_1.png}"
561  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display.png}"
562  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display_1.png}"
563  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EmptyInitialCompositeReader.png}"
564  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMajorAxis.png}"
565  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMediumAxis.png}"
566  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMinorAxis.png}"
567  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OffsetSliceWithPlane.png}"
568  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OMFReader.png}"
569  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OpacityWidgetRange.png}"
570  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView.png}"
571  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView_1.png}"
572  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice.png}"
573  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Surface.png}"
574  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice.png}"
575  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Surface.png}"
576  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PBRSpheres.png}"
577  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PLYWriter.png}"
578  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlackBackground.png}"
579  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlueGrayBackground.png}"
580  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteGradientBackground.png}"
581  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteLightGrayBackground.png}"
582  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteNeutralGrayBackground.png}"
583  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWarmGrayBackground.png}"
584  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteDarkGrayBackground.png}"
585  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWhiteBackground.png}"
586  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Boundary.png}"
587  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Center.png}"
588  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Uniform.png}"
589  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}"
590  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}"
591  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes1.png}"
592  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes2.png}"
593  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes3.png}"
594  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-SingleView.png}"
595  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-AllViews.png}"
596  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmPlugin.png}"
597  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmReadersAndWriters.png}"
598  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonShellRunScript.png}"
599  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PropertyContextMenu1.png}"
600  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PropertyContextMenu2.png}"
601  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea.png}"
602  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea_1.png}"
603  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotLines.png}"
604  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGScalars.png}"
605  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGVectors.png}"
606  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnly.png}"
607  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnlyBlockColors.png}"
608  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_CellData.png}"
609  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_LoadPatches.png}"
610  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_PointData.png}"
611  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadCGNSBCDataset.png}"
612  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries0.png}"
613  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries1.png}"
614  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries2.png}"
615  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache0.png}"
616  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache1.png}"
617  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache2.png}"
618  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadFLUENTCFFFormat.png}"
619  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RectilinearVolumeRendering.png}"
620  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-AfterReload.png}"
621  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-BeforeReload.png}"
622  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-AfterReload.png}"
623  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-BeforeReload.png}"
624  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface.png}"
625  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_1.png}"
626  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_2.png}"
627  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingVolume.png}"
628  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanDefaultColor.png}"
629  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanGUIColor.png}"
630  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanPresetColor.png}"
631  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuArrayColoring.png}"
632  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuSolidColoring.png}"
633  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGridBranching_3.png}"
634  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DX.png}"
635  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DY.png}"
636  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DZ.png}"
637  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToLine.png}"
638  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_A.png}"
639  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_B.png}"
640  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_C.png}"
641  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetSession.png}"
642  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA.png}"
643  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA_1.png}"
644  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeB.png}"
645  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC.png}"
646  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_1.png}"
647  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_2.png}"
648  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeD.png}"
649  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeE.png}"
650  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionA.png}"
651  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionB.png}"
652  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC.png}"
653  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC_1.png}"
654  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionA.png}"
655  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionB.png}"
656  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionC.png}"
657  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_A.png}"
658  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_B.png}"
659  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RotateAroundOriginTransform.png}"
660  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerA.png}"
661  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerA_1.png}"
662  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerB.png}"
663  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerB_1.png}"
664  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerC.png}"
665  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerC_1.png}"
666  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerD.png}"
667  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerD_1.png}"
668  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot.png}"
669  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot_1.png}"
670  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot.png}"
671  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot_1.png}"
672  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar1.png}"
673  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar2.png}"
674  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar3.png}"
675  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar4.png}"
676  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar5.png}"
677  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar6.png}"
678  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar7.png}"
679  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar8.png}"
680  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsFrustumTrace.png}"
681  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsFrustumTrace_1.png}"
682  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsInteractiveTrace.png}"
683  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace.png}"
684  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace_1.png}"
685  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace_2.png}"
686  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectColorMapFromComboBox_A.png}"
687  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionByArray.png}"
688  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionEditor.png}"
689  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkParallelCoordinatesView.png}"
690  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingA.png}"
691  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingB.png}"
692  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsFrustumTrace.png}"
693  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsInteractiveTrace.png}"
694  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsTrace.png}"
695  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapA.png}"
696  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapB.png}"
697  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_X.png}"
698  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Y.png}"
699  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Z.png}"
700  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Magnitude.png}"
701  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPreset.png}"
702  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpNoRegexp.png}"
703  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpYD.png}"
704  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexp.png}"
705  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ShowMultiPieceFieldData.png}"
706  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Slice.png}"
707  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceDirectDoubleColoring.png}"
708  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceRepresentation.png}"
709  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneCellData.png}"
710  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneMultiBlock.png}"
711  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlane.png}"
712  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterA.png}"
713  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterB.png}"
714  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SplitViewTraceScreenshot.png}"
715  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SSAO.png}"
716  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorA.png}"
717  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorB.png}"
718  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorC.png}"
719  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StepColorSpaceA.png}"
720  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridCellBlanking.png}"
721  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridVolumeRendering.png}"
722  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT1.png}"
723  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT2.png}"
724  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthSmall.png}"
725  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthLarge.png}"
726  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestAnnotateSelectionFilter.png}"
727  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile0.png}"
728  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile1.png}"
729  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile0.png}"
730  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile1.png}"
731  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_0.png}"
732  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_1.png}"
733  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_2.png}"
734  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorMapModificationRendersAllViews.png}"
735  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestClipCylinder.png}"
736  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorHistogram.png}"
737  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCompositedGeometryCulling.png}"
738  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestGeometryBoundsClobber.png}"
739  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestERFReader.png}"
740  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries_cc.png}"
741  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries.png}"
742  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice_cc.png}"
743  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice.png}"
744  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries_cc.png}"
745  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries.png}"
746  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice_cc.png}"
747  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice.png}"
748  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_A.png}"
749  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_B.png}"
750  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_C.png}"
751  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_D.png}"
752  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold.png}"
753  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold_1.png}"
754  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume1.png}"
755  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume2.png}"
756  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume3.png}"
757  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume4.png}"
758  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume5.png}"
759  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestLineChartLabelPrefix.png}"
760  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer1.png}"
761  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer2.png}"
762  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer3.png}"
763  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer4.png}"
764  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestOFFReader.png}"
765  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale.png}"
766  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale_1.png}"
767  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView.png}"
768  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView_1.png}"
769  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonViewScript.png}"
770  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestResampleHyperTreeGridWithSphere.png}"
771  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceBorder.png}"
772  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceInteriorLines.png}"
773  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews.png}"
774  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews2.png}"
775  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews3.png}"
776  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Threshold.png}"
777  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAllComponents.png}"
778  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAnyComponent.png}"
779  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdInvert.png}"
780  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentX.png}"
781  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentY.png}"
782  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentZ.png}"
783  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedMagnitude.png}"
784  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-1x1-tile0.png}"
785  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile0.png}"
786  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile1.png}"
787  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile0.png}"
788  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile1.png}"
789  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile2.png}"
790  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile3.png}"
791  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile0.png}"
792  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile1.png}"
793  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile2.png}"
794  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TimeStepProgressBar_Inter.png}"
795  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ToneMapping.png}"
796  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceExodus.png}"
797  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews.png}"
798  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews_1.png}"
799  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceTimeControls.png}"
800  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_AllBlocks.png}"
801  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_OneBlock.png}"
802  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_TwoBlocks.png}"
803  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DEditor.png}"
804  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars.png}"
805  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_1.png}"
806  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_2.png}"
807  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditor.png}"
808  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorA.png}"
809  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB.png}"
810  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TriangleStrips.png}"
811  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_A.png}"
812  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_B.png}"
813  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_C.png}"
814  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Magnitude.png}"
815  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_X.png}"
816  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Y.png}"
817  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Z.png}"
818  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges1.png}"
819  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges2.png}"
820  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges3.png}"
821  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges4.png}"
822  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges5.png}"
823  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges6.png}"
824  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1.png}"
825  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_1.png}"
826  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_2.png}"
827  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2.png}"
828  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_1.png}"
829  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_2.png}"
830  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions3.png}"
831  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions4.png}"
832  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCellSelection.png}"
833  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCrop.png}"
834  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeOfRevolution.png}"
835  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeIsosurfaceBlendMode.png}"
836  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeNoMapScalars.png}"
837  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeSliceBlendMode.png}"
838  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VTKHDFWriter.png}"
839  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveNoFontScale.png}"
840  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveFontScale.png}"
841  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/YoungsMaterialInterface.png}"
842  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_ChangeParameters.png}"
843  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_Default.png}"
844  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_DisableBlocks.png}"
845  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_EnableBlocks.png}"
846  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_Default.png}"
847  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_Default_1.png}"
848  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX.png}"
849  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX_1.png}"
850  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult.png}"
851  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult2.png}"
852  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChanged.png}"
853  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChangedNormalized.png}"
854  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA.png}"
855  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA_1.png}"
856  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestB.png}"
857  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestC.png}"
858  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestD.png}"
859  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData.png}"
860  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_A.png}"
861  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_B.png}"
862  "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToEmptyData.png}"
863 )
864
865 # Some tests can take a long time; increase their timeouts.
866 # Really very long (300 seconds):
867 set(SeparateOpacityArray_TIMEOUT 300)
868 set(TransferFunction2DYScalars_TIMEOUT 300)
869 set(UndoRedo1_TIMEOUT 300)
870
871 # Very long (200 seconds):
872 set(EqualizeLayout_TIMEOUT 200)
873
874 # Somewhat long (150 seconds):
875 set(AMReXParticlesReader_TIMEOUT 150)
876 set(Clip_TIMEOUT 150)
877 set(ColorOpacityEditorFreehandDrawing_TIMEOUT 150)
878 set(ColorOpacityTableEditorHistogram_TIMEOUT 150)
879 set(ComparativeVisPanel_TIMEOUT 150)
880 set(Ensemble_TIMEOUT 150)
881 set(HelpWindowHistory_TIMEOUT 150)
882 set(ImageVolumeRendering_TIMEOUT 150)
883 set(LagrangianIntegrationModel_TIMEOUT 150)
884 set(LagrangianParticleTrackerReseeding_TIMEOUT 150)
885 set(LagrangianParticleTracker_TIMEOUT 150)
886 set(MemoryInspectorPanel_TIMEOUT 150)
887 set(MultiBlockVolumeRendering_TIMEOUT 150)
888 set(MultiServer3_TIMEOUT 150)
889 set(PropertyContextMenu_TIMEOUT 150)
890 set(ProxyCategoriesConfiguration_TIMEOUT 150)
891 set(ProxyCategoriesDialog_TIMEOUT 150)
892 set(SaveTSV_TIMEOUT 150)
893 set(ScalarBarRange_TIMEOUT 150)
894 set(SeparatedColorMapOpacity_TIMEOUT 150)
895 set(SliceRepresentation_TIMEOUT 150)
896 set(SplitViewTrace_TIMEOUT 150)
897 set(SpreadSheet3_TIMEOUT 150)
898 set(TemporalParticleKeepDeadTrails_TIMEOUT 150)
899 set(TraceExportAndSaveData_TIMEOUT 150)
900 set(TransferFunction2D_TIMEOUT 150)
901 set(ZoomToData_TIMEOUT 150)
902
903 list (APPEND TESTS_WITHOUT_BASELINES
904  AboutDialog.xml
905  AddFieldArrays.xml
906  ArrayBoundsScaleDomain.xml
907  ArraySelectionWidget.xml
908  AnimateProperty.xml
909  ComputeArrayMagnitudeSetting.xml
910  CustomOutputFormat.xml
911  DefaultReadersSetting.xml
912  DelimitedTextReader.xml
913  DynamicFieldDataDomain.xml
914  ExportFilteredColumnsSpreadsheet.xml
915  ExportSpreadsheetFormatting.xml
916  ExpressionsDialog.xml
917  ExpressionsExporter.xml
918  ExpressionsSettings.xml
919  ExtractParticlesOverTime.xml
920  FieldDataToAttribute.xml
921  FileDialogOpenInteractClose.xml
922  ForceStaticMesh.xml
923  GradientBackwardsCompatibility.xml
924  ImportCustomPresets.xml
925  InformationPanel.xml
926  LogViewer.xml
927  MergeTime.xml
928  ModifyGUIWindowTitle.xml
929  OpacityWidgetRange.xml
930  OpenHelp.xml
931  OverrideProperty.xml
932  PartialArrayInLineChart.xml
933  PlotOverLineLegacy.xml
934  PointCellDataConversion.xml
935  PolarAxesBackwardsCompatibility.xml
936  ProxyCategoriesConfiguration.xml
937  ProxyCategoriesDialog.xml
938  ProxyCategoriesDialogDefault.xml
939  ProxyCategoriesDialogSettings.xml
940  ProxyCategoriesFavorites.xml
941  ProxyCategoriesMenusDefault.xml
942  ProxyCategoriesToolbar.xml
943  QuickLaunchCreateProxy.xml
944  QuickLaunchNavigation.xml
945  QuickLaunchRequest.xml
946  ReadIOHDFAMRMaxLevels.xml
947  ReaderRegistrationName.xml
948  ReloadCGNSFile.xml
949  SearchBox.xml
950  ServerConnectDialog.xml
951  SliceBackwardsCompatibility.xml
952  SpatioTemporalHarmonicsAttribute.xml
953  SpatioTemporalHarmonicsSource.xml
954  SpreadSheetFieldData.xml
955  SpreadSheetSelectedCellConnectivity.xml
956  StringInLineChartView.xml
957  TableHistogram.xml
958  TensorPrincipalInvariants.xml
959  TestCompositePropertyWidgetDecorator.xml
960  TestFileListPropertyWidget.xml
961  TextSource.xml
962  ThresholdBackwardsCompatibility.xml
963  ThresholdTable.xml
964  TimeKeeper.xml
965  TimeManagerPanel.xml
966  TimeManagerSequence.xml
967  WriteXMLTimeValue.xml
968  YieldCriteria.xml
969 )
970
971 if (PARAVIEW_PLUGIN_ENABLE_EULATestPlugin)
972  list(APPEND TESTS_WITHOUT_BASELINES
973  PluginEULA.xml)
974 endif ()
975
976 if (PARAVIEW_ENABLE_OPENVDB)
977  list (APPEND TESTS_WITHOUT_BASELINES
978  OpenVDBReader.xml
979  )
980 endif ()
981
983  list(APPEND TESTS_WITHOUT_BASELINES
984  HelpWindowHistory.xml)
985 endif()
986
987 if (WIN32)
988  list(APPEND TESTS_WITHOUT_BASELINES
989  AVIWriter.xml
990  MP4Writer.xml)
991 endif()
992
993 list (APPEND TESTS_WITH_INLINE_COMPARES
994  AxesGrid.xml
995  BoundingRuler.xml
996  BoxWidget.xml
997  BlockContextMenu.xml
998  BlockLinkedSelection.xml
999  CalculatorQuotedVariable.xml
1000  CameraLink.xml
1001  CGNSReaderDataLocation.xml
1002  ChartDefaultSettings.xml
1003  ChartLoadNoVariables.xml
1004  ClampAndUpdateColorMap.xml
1005  ColorOpacityTableEditorHistogram.xml
1006  ComputeNormalsInRepresentation.xml
1007  Connectivity.xml
1008  Contour.xml
1009  ContourRange.xml
1010  CriticalTime.xml
1011  DataAxesGrid2X.xml
1012  DecimatePolyline.xml
1013  DeleteSubtreePipelineBrowser.xml
1014  EllipseSource.xml
1015  Ensemble.xml
1016  EqualizeLayout.xml
1017  ExtractSubsetWithSeed.xml
1018  FastUniformGridSource.xml
1019  FeatureEdgesHTG.xml
1020  FeatureEdgesHTGNoMask.xml
1021  FileSeries.xml
1022  FontScalingInScreenshots.xml
1023  HyperTreeGridAxisClip.xml
1024  HyperTreeGridAxisCut.xml
1025  HyperTreeGridAxisReflection.xml
1026  HyperTreeGridCellCenters.xml
1027  HyperTreeGridContour.xml
1028  HyperTreeGridContourStrategy.xml
1029  HyperTreeGridDepthLimiter.xml
1030  HyperTreeGridEvaluateCoarse.xml
1031  HyperTreeGridExtractGhostCells.xml
1032  HyperTreeGridGeometry.xml
1033  HyperTreeGridGradient.xml
1034  HyperTreeGridMultiBlock.xml
1035  HyperTreeGridMultipleClip.xml
1036  HyperTreeGridObliquePlaneCutter.xml
1037  HyperTreeGridPlaneCutter.xml
1038  HyperTreeGridThreshold.xml
1039  LightAddRemove.xml
1040  LightToolbar.xml
1041  LineChartSelection.xml
1042  LoadStateMultiView.xml
1043  LogColorMap.xml
1044  LogColorMapToggle.xml
1045  LogoSourcesInChartViews.xml
1046  MemoryInspectorPanel.xml
1047  Molecule.xml
1048  MultiBlockInspectorMultiBlock.xml
1049  MultiBlockInspectorProperties.xml
1050  MultiBlockInspectorSelection.xml
1051  MultiBlockChartSelection.xml
1052  MultipleColorOnSelection.xml
1053  NestedViews.xml
1054  NonlinearSubdivisionDisplay.xml
1055  PaletteBackgrounds.xml
1056  ParallelCoordinatesView.xml
1057  PartitionedDataSet.xml
1058  PartitionedDataSetCollection.xml
1059  PlotOverLine_3d.xml
1060  Preview.xml
1061  PreviewFontScaling.xml
1062  PropertyContextMenu.xml
1063  QuartilePlot.xml
1064  ReadPartitionedCGNS.xml
1065  ReadCGNSBCDataset.xml
1066  ReadIOHDFFileSeries.xml
1067  ReadIOHDFWithCache.xml
1068  ReadFLUENTCFFFormat.xml
1069  RectilinearFractal.xml
1070  ReloadAMReXGrid.xml
1071  ReloadExodusFile.xml
1072  RemoteRendering.xml
1073  RenameArrays.xml
1074  RenderNan.xml
1075  RenderViewContextMenu.xml
1076  ResetToVisibleRange.xml
1077  Ruler.xml
1078  SaveExodus.xml
1079  SaveLargeScreenshot.xml
1080  ScalarBarRange.xml
1081  SelectColorMapFromComboBox.xml
1082  SelectionEditor.xml
1083  SelectionLinkParallelCoordinatesView.xml
1084  SeparateOpacityArray.xml
1085  SliceRepresentation.xml
1086  SteeringDataGenerator.xml
1087  TemporalSmoothing.xml
1088  TestCleanGridPointDataStrategies.xml
1089  TestColorMapModificationRendersAllViews.xml
1090  TestERFReader.xml
1091  TestHTGSelection.xml
1092  TestHTGThreshold.xml
1093  TestIsoVolume.xml
1094  TextSourceBorder.xml
1095  Threshold.xml
1096  ThresholdComponentModes.xml
1097  TransferFunctionResetOnVisibilityChange.xml
1098  UnstructuredVolumeRenderingVectorComponent.xml
1099  UpdateTransferFunctionRanges.xml
1100  XYChart.xml
1101  XYHistogram.xml
1102  ZoomClosest.xml
1103 )
1104
1105 # Image data delivery to render server not supported.
1106 set(SeparateOpacityArray_DISABLE_CRS TRUE)
1107
1108 if(NOT APPLE)
1109  # Workaround to avoid testing failures on high-res Retina displays on Macs
1110  list(APPEND TESTS_WITH_INLINE_COMPARES
1111  ColorLegendScaledScreenshot.xml
1112  )
1113 endif()
1114
1115 list(APPEND TESTS_WITH_BASELINES
1116  AxisAlignedCutterAMR.xml
1117  AxisAlignedCutterHTG.xml
1118  AxisAlignedCutterMBHierarchy.xml
1119  AxisAlignedCutterPDCNoHierarchy.xml
1120  BDFReader.xml
1121  BoxWidgetVisibleBlock.xml
1122  CameraOrientationWidget.xml
1123  ChartsClearSelection.xml
1124  CleanToGridRemovePoints.xml
1125  ConstantShadingPerObject.xml
1126  CONVERGECFDCGNSReader.xml
1127  DataAxesGrid.xml
1128  EmptyInitialCompositeReader.xml # Issue #21293
1129  FeatureEdgesFilterHTG.xml
1130  FeatureEdgesRepresentationHTG.xml
1131  IOSSMergeExodusEntityBlocks.xml
1132  ImageChartView.xml
1133  IntegrateVariablesPDC.xml
1134  LogoSource.xml
1135  MergeVectorComponents.xml
1136  MissingPartialArraysColoredByNaN.xml
1137  MoleculeScalarBar.xml
1138  MultiSliceHTG.xml
1139  NetCDFUGRID.xml
1140  QuadraturePointsDS.xml
1141  PartialFieldDataMultiBlock.xml
1142  ParticleTracerGlyph.xml
1143  PassArrays.xml
1144  PerlinNoise.xml
1145  PickCenter.xml
1146  PointAndCellIdsHTG.xml
1147  Protractor.xml
1148  RemoveGhostInformationHTG.xml
1149  ResampleToLine.xml
1150  ReverseSense.xml
1151  SaveLoadScreenShotWithEmbedState.xml
1152  SelectionBlocksThrough.xml
1153  SelectionByArray.xml
1154  SeriesPreset.xml
1155  SeriesPresetRegexp.xml
1156  ShowMultiPieceFieldData.xml
1157  TemporalParticleKeepDeadTrails.xml
1158  TestHiddenLineRemoval.xml
1159  TestOpenFOAMWeighByCell.xml
1160  TestResampleHyperTreeGridWithSphere.xml
1161  TransferFunction2D.xml
1162  TransferFunction2DYScalars.xml
1163  VolumeOfRevolution.xml
1164  ZoomClosestOffsetRatio.xml
1165  ZoomToBox.xml
1166  ZoomToData.xml
1167  ZoomToEmptyData.xml
1168 )
1169
1170 if(PARAVIEW_ENABLE_VISITBRIDGE)
1171  list(APPEND TESTS_WITH_BASELINES
1172  VisItBridgeChombo.xml
1173  VisItBridgeLAMMPSDump.xml
1174  VisItBridgeLAMMPSDump2.xml
1175  VisItBridgeNas.xml
1176  VisItBridgeNek.xml
1177  VisItBridgeMoleculeColoring.xml
1178  VisItBridgePdb.xml
1179  VisItBridgePFLOTRAN.xml
1180  # disabling this test for now, not sure why it fails
1181  # even with 5.7 binarie
1182  #VisItBridgePixie.xml
1183  VisItBridgeSamrai.xml
1184  TruchasReaderWithVisItBridge.xml)
1185  list(APPEND TESTS_WITH_INLINE_COMPARES
1186  CONVERGECFDReaderWithVisItBridge.xml
1187  )
1188 else()
1189  # A number of VisIt readers support reading of .pdb and
1190  # of .h5 files, so when the VisItBridge is enabled,
1191  # the test must take extra steps to select the correct reader.
1192  #
1193  # When the VisItBridge is not enabled, there is no need to select
1194  # a reader.
1195  list(APPEND TESTS_WITH_BASELINES
1196  MoleculeColoring.xml
1197  TruchasReader.xml
1198  Nek5000Reader.xml)
1199  list(APPEND TESTS_WITH_INLINE_COMPARES
1200  CONVERGECFDReader.xml)
1201 endif()
1202
1203 if(PARAVIEW_ENABLE_RAYTRACING)
1204  list(APPEND TESTS_WITH_BASELINES
1205  OSPRay.xml)
1206 endif()
1207
1208 if(PARAVIEW_ENABLE_OPENTURNS)
1209  list(APPEND TESTS_WITH_BASELINES
1210  HistogramKernelSmoothing.xml)
1211  list(APPEND TESTS_WITH_BASELINES
1212  PlotMatrixViewDensityMaps.xml)
1213 endif()
1214
1215 # hits OSX bug with FileDialog so exclude test on APPLE
1216 if (NOT APPLE)
1217  list (APPEND TESTS_WITH_INLINE_COMPARES
1218  HistogramSelection.xml)
1219 endif()
1220
1221 # TODO: Port to the new API.
1222 macro(ADD_CATALYST_LIVE_TEST test_name duration command_line_connect_command)
1223  # These tests are too complex to run in parallel.
1224  set (CATALYST_SIMULATION CatalystWaveletDriver.py)
1225  set (INSITU_SCRIPT CatalystWaveletCoprocessing)
1226
1227  set ("${test_name}_FORCE_SERIAL" TRUE)
1228  add_pv_test("pv" "_DISABLE_C"
1229  COMMAND
1230  --script-ignore-output-errors --script $<TARGET_FILE:ParaView::pvbatch> --sym
1231  ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1232  ${INSITU_SCRIPT} "${duration}"
1233
1234  --client ${CLIENT_EXECUTABLE}
1235  --enable-bt
1236  ${command_line_connect_command}
1237  --dr
1238  --test-directory=${PARAVIEW_TEST_DIR}
1239  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1240  TEST_SCRIPTS ${test_name}.xml
1241  EXTRA_LABELS "catalyst")
1242
1243  add_pv_test(pvcs "_DISABLE_CS"
1244  COMMAND
1245  --script-np 5 --script-ignore-output-errors
1246  --script $<TARGET_FILE:ParaView::pvbatch> --sym
1247  ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1248  ${INSITU_SCRIPT} "${duration}"
1249
1250  --server $<TARGET_FILE:ParaView::pvserver>
1251  --enable-bt
1252
1253  --client ${CLIENT_EXECUTABLE}
1254  --enable-bt
1255  ${command_line_connect_command}
1256  --dr
1257  --test-directory=${PARAVIEW_TEST_DIR}
1258  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1259  TEST_SCRIPTS ${test_name}.xml
1260  EXTRA_LABELS "catalyst")
1261
1262 endmacro(ADD_CATALYST_LIVE_TEST)
1263
1264 if (PARAVIEW_ENABLE_XDMF2 AND NOT PARAVIEW_ENABLE_XDMF3)
1265  # Xdmf2 is optional.
1266  # And when both Xdmf2 and Xdmf3 are enabled, the SelectReader dialog
1267  # confuses these tests. So, we'll disable them for now.
1268  # We need a better mechanism to handle such cases in the testing framework.
1269  list(APPEND TESTS_WITH_BASELINES
1270  ExtractBlock.xml
1271  XdmfRead.xml
1272  XdmfReadImageData.xml
1273  XdmfReadImageDataCollection.xml
1274  XdmfReadRectilinearGrid.xml
1275  XdmfReadRectilinearGridCollection.xml
1276  XdmfReadStructuredGrid.xml
1277  XdmfReadStructuredGridCollection.xml
1278  XdmfGridAttributes.xml
1279  ZLibXDMF.xml
1280  )
1281 endif()
1282
1283 list(APPEND TESTS_WITH_BASELINES
1284  4AxesContextView.xml
1285  AccentuatedFilename.xml
1286  AdaptiveResampleToImage.xml
1287  AMRArraySelection.xml
1288  AMRContour.xml
1289  AMRCutPlane.xml
1290  AMReXParticlesReader.xml
1291  AxisAlignedSliceBackwardCompat.xml
1292  AnimationCache.xml
1293  AnimationCameraExportImport.xml
1294  AnimationFollowPath.xml
1295  AnimationSetTimeCursor.xml
1296  AnimationUseCamera.xml
1297  AnisotropyPBR.xml
1298  Annotations.xml
1299  ClearCoatPBR.xml
1300  ConvertToMolecule.xml
1301  ContourCellData.xml
1302  CopyPasteFilters.xml
1303  CopyPasteProperties.xml
1304  CustomTCoords.xml
1305  CTHAMRBaseline.xml
1306  CTHAMRClip.xml
1307  CTHAMRContour.xml
1308  CTHAMRDualClip.xml
1309  CTHAMRMaterialInterfaceFilter.xml
1310  CTHDerivedDensity2DCylinder.xml
1311  AddActiveValuesFromVisibleObjects.xml
1312  AnimatePipelineTime.xml
1313  AngularPeriodicFilter.xml
1314  3DWidgetInCustomFilter.xml
1315  BlockOpacities.xml
1316  CalcParens.xml
1317  Calculator.xml
1318  CalculatorInput.xml
1319  CameraWidgetViewLink.xml
1320  CameraWidgetViewLinkState.xml
1321  CategoriesWithNaN.xml
1322  CGNSIOSSReader.xml
1323  # Disabled due to #20508
1324  # ChangeGlyphRepVisibility.xml
1325  ChangingTimestepsInStateFiles.xml
1326  ChartAxisRangeAndLabels.xml
1327  CheckableHeader.xml
1328  Clip.xml
1329  CrinkleClip.xml
1330  ColorAnnotationsVisibilitiesAndOpacities.xml
1331  ColorEditorControls.xml
1332  ColorEditorVolumeControls.xml
1333  ColorLegendMinMaxLabels.xml
1334  ColorLegendBackground.xml
1335  ColorOpacityTableEditing.xml
1336  ColorOpacityEditorFreehandDrawing.xml
1337  ColorOpacityEditorRangeHandles.xml
1338  CombineFrustumSelections.xml
1339  CategoricalAutomaticAnnotations.xml
1340  CategoricalColors.xml
1341  CategoricalOpacities.xml
1342  ColorByCellDataStringArray.xml
1343  ComparativeVisPanel.xml
1344  ComparativeViewOverlay.xml
1345  # disabling overlay test for now. It has issues with Time 0.
1346  # ComparativeOverlay.xml
1347  CompositeSurfaceSelection.xml
1348  ComputeConnectedSurfaceProperties.xml
1349  CustomFilter.xml
1350  CustomSourceProbe.xml
1351  CustomViewpoints.xml
1352  DataOutlines.xml
1353  DisableResetDisplayEmptyViews.xml
1354  DualSphereAnimation.xml
1355  EdgeOpacity.xml
1356  EdgeTintPBR.xml
1357  EnSight.xml
1358  EnSightTensorInversion.xml
1359  EnSightTensorInversionBin.xml
1360  ExodusGlobalDataWithRestarts.xml
1361  ExodusSingleTimeStep.xml
1362  ExpandSelection.xml
1363  ExportLinePlotToCSV.xml
1364  ExportLinePlotToTSV.xml
1365  ExportSceneSpreadSheetView2.xml
1366  ExportX3dPOVVRML.xml
1367  ExTimeseries.xml
1368  ExTimeseries2.xml
1369  ExtractCellsByType.xml
1370  ExtractComponentFilter.xml
1371  ExtractLevel.xml
1372  ExtractTimeSteps.xml
1373  EyeDomeLighting.xml
1374  FeatureEdges.xml
1375  FeatureEdgesNonlinearCells.xml
1376  FFTOverTime.xml
1377  FieldDataBlocks.xml
1378  FileDialogOpenFile.xml
1379  Flagpole.xml
1380  Flow.xml
1381  Flow2.xml
1382  FollowHiddenData.xml
1383  ForceTime.xml
1384  Fractal2D.xml
1385  GenerateTimeSteps.xml
1386  GenerateTimeStepsData.xml
1387  GhostCellsGeneratorImageSerial.xml
1388  Glyph3DCullingAndLOD.xml
1389  Glyph3DRepresentation.xml
1390  GlyphUseCellCenters.xml
1391  GlyphWithEmptyCells.xml
1392  GroupDataSetOutputType.xml
1393  glTFImporterNestedRings.xml
1394  glTFImporterWaterBottle.xml
1395  glTFReaderAnimatedMorphing.xml
1396  glTFReaderMultipleAnimations.xml
1397  glTFReaderMultipleScenes.xml
1398  glTFReaderToggleDeformation.xml
1399  glTFReaderTriangle.xml
1400  H5PartReader.xml
1401  HideAll.xml
1402  HorizontalColorLegendTitle.xml
1403  HyperTreeGridGhostCellsGenerator.xml
1404  IgnoreLogAxisWarning.xml
1405  ImageDataToUniformGrid.xml
1406  ImageVolumeRendering.xml
1407  InteractiveSelection.xml
1408  InteractiveViewLinkOffscreen.xml
1409  InteractiveViewLinkOnscreen.xml
1410  InteractiveViewLinkState.xml
1411  LegendGridActor.xml
1412  LightWidget.xml
1413  LinearCellExtrusion.xml
1414  LinesAsTubes.xml
1415  LinkRepresentationProperties.xml
1416  LoadPartiallyUpdatedStateFiles.xml
1417  LoadSaveStateAnimation.xml
1418  LoadState.xml
1419  LoadStateChooseDirectory.xml
1420  LoadStateChooseFiles.xml
1421  LoadStateTextSourceRepresentation.xml
1422  LoadStateUseExisting.xml
1423  LoadSaveStateVolume.xml
1424  ManyTypesXMLWriterReader.xml
1425  MatchBoundariesIgnoringCellOrder.xml
1426  MergePointBlocks.xml
1427  MergePiecesOnly.xml
1428  MoleculeBonds.xml
1429  MoleculeToLines.xml
1430  # MultiBlockAttributes1.xml
1431  MultiBlockInspector.xml
1432  MultiBlockInspectorAssembly.xml
1433  MultiBlockInspectorAssemblyExtractBlocks.xml
1434  MultiBlockInspectorAssemblyWithoutSelectOnClickSetting.xml
1435  MultiBlockInspectorExtractBlocks.xml
1436  MultiBlockSingleBlock.xml
1437  MultiBlockVolumeRendering.xml
1438  MultiBlockInspectorWithoutSelectOnClickSetting.xml
1439  MultiSliceMultiBlock.xml
1440  MultiSliceWavelet.xml
1441  NormalGlyphs.xml
1442  NumberOfComponentsDomain.xml
1443  NonConvexPolygon.xml
1444  OctreeImageFilters.xml
1445  OMETIFFChannelCalculator.xml
1446  OpenSaveData.xml
1447  OrderedGroupDatasets.xml
1448  OrthographicView.xml
1449  OutOfRangeColors.xml
1450  PBRSpheres.xml
1451  PlotDataOverTime-NonDistributed.xml
1452  PlotEdges2.xml
1453  # PlotEdges.xml see paraview/paraview#20659
1454  PlotGlobalVariablesOverTime.xml
1455  PlotOverTimeAutoApply.xml
1456  PolygonCellSelection.xml
1457  PolygonPointSelection.xml
1458  PointChartView.xml
1459  PointGaussianMultiBlockDataSet.xml
1460  PointGaussianNoScaleTransferFunction.xml
1461  PointGaussianScaleOpacityArray.xml
1462  PointInterpolator.xml
1463  PointVolumeInterpolator.xml
1464  PolarAxes.xml
1465  PolarAxesRemoteRendering.xml
1466  PolarAxes2D.xml
1467  PolyLineAndSplineSources.xml
1468  PropertyConversion.xml
1469  PropertyConversion1.xml
1470  PropertyConversion2.xml
1471  PropertyConversion3.xml
1472  PropertyConversion4.xml
1473  PropertyLink.xml
1474  QuadraticGhostCells.xml
1475  RandomHyperTreeGridSource.xml
1476  ReadPIOWithHTG.xml
1477  ReadXMLPolyDataFileSeries.xml
1478  RecentFiles.xml
1479  RecentFilesHardFilename.xml
1480  RectilinearVolumeRendering.xml
1481  RedistributeDataSetFilter.xml
1482  RepresentationSelector.xml
1483  ResampleWithDataset.xml
1484  RescaleToTemporal.xml
1485  ReverseLegend.xml
1486  RotateAroundOriginTransform.xml
1487  RotateCamera90.xml
1488  RotationalExtrusionFilter.xml
1489  # SaveAnimationGeometry.xml # see #20236
1490  SaveColorMap.xml
1491  SaveCSV.xml
1492  SaveFileSeries.xml
1493  SaveMultiBlockCSV.xml
1494  SaveOBJ.xml
1495  SaveTSV.xml
1496  SaveTXT.xml
1497  SelectedProxyPanelVisibility.xml
1498  SelectionBlocks.xml
1499  SelectionModifiersCells.xml
1500  SelectionModifiersPoints.xml
1501  SelectionModifiersBlocks.xml
1502  SetCustomBasicPresets.xml
1503  ShaderReplacements.xml
1504  ShowAll.xml
1505  SimpleInteraction.xml
1506  Slice.xml
1507  SliceAlongPolyline.xml
1508  SliceAlongSpline.xml
1509  SolidColorSource.xml
1510  SpherePointSource.xml
1511  SpreadSheet1.xml
1512  SpreadSheet2.xml
1513  SpreadSheet3.xml
1514  SPTimeseries.xml
1515  SpyPlotHistoryReader.xml
1516  SelectionLinkBasic.xml
1517  SelectionLinkConverted.xml
1518  SelectionLinkHistogram.xml
1519  SelectionLinkInitial.xml
1520  SelectionLinkMultiple.xml
1521  SelectionLinkRemove.xml
1522  SelectionLinkReaction.xml
1523  SelectionLinkReactionNonConverted.xml
1524  SeparatedColorMap.xml
1525  SeparatedColorMapOpacity.xml
1526  SliceWithPlane.xml
1527  SliceWithPlaneMultiBlock.xml
1528  SortLineChartData.xml
1529  ScrollAreaNativeWidget.xml
1530  SSAO.xml
1531  StepColorSpace.xml
1532  StockColors.xml
1533  StreamTracerSurface.xml
1534  StreamTracerUpdates.xml
1535  TabbedViews.xml
1536  TensorGlyph.xml
1537  TemporalInterpolator.xml
1538  TemporalShiftScale.xml
1539  TestAnnotateSelectionFilter.xml
1540  TestBoundaryMeshQuality.xml
1541  TestGroupDataFromTimeSeries.xml
1542  TestSelectionOnMultipiece.xml
1543  TimeStepProgressBar.xml
1544  Tessellate.xml
1545  TestOFFReader.xml
1546  Text2D.xml
1547  TextBillboard3D.xml
1548  TextureUsages.xml
1549  ToneMapping.xml
1550  TriangleStrips.xml
1551  UndoRedo.xml
1552  UndoRedo1.xml
1553  UndoRedo2.xml
1554  UndoRedo3.xml
1555  UndoRedo5.xml
1556  UndoRedo6.xml
1557  UndoRedo7.xml
1558  UndoRedo8.xml
1559  UnstructuredOutline.xml
1560  UniformInverseTransformSamplingGlyph.xml
1561  VectorComponentHistogram.xml
1562  VolumeIsosurfaceBlendMode.xml
1563  VolumeRenderingWithContour.xml
1564  VolumeReprTwoIndepComp.xml
1565  VolumeSliceBlendMode.xml
1566  VariableSelector.xml
1567  VariableSelector1.xml
1568  ViewSettingsDialog.xml
1569  VTPSeriesFile.xml
1570  RandomAttributes.xml
1571  XYBarChart.xml
1572  YoungsMaterialInterface.xml
1573 )
1574
1575 if (TARGET VTK::IOParallelLSDyna)
1576  list(APPEND TESTS_WITH_BASELINES
1577  Plot3DReader.xml
1578  SelectReader.xml
1579  )
1580 endif ()
1581
1582 if (TARGET VTK::IOFides)
1583  if (PARAVIEW_ENABLE_ADIOS2)
1584  list(APPEND TESTS_WITH_INLINE_COMPARES
1585  FidesReaderADIOS2.xml
1586  )
1587  else()
1588  list(APPEND TESTS_WITH_INLINE_COMPARES
1589  FidesReader.xml
1590  )
1591  endif()
1592 endif()
1593
1594 if (TARGET VTK::IOOMF)
1595  list(APPEND TESTS_WITH_INLINE_COMPARES
1596  OMFReader.xml
1597  )
1598 endif()
1599
1600 if(VTK_USE_LARGE_DATA)
1601  ExternalData_Expand_Arguments(ParaViewData _
1602  "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}")
1603  list(APPEND TESTS_WITH_BASELINES
1604  RestoreBlockColorDefaultTransferFunction.xml
1605  )
1606 endif()
1607
1608 if (NOT PARAVIEW_USE_MPI)
1609  list(APPEND TESTS_WITH_BASELINES
1610  VolumeCrop.xml
1611  )
1612 endif()
1613
1614 # VTKHDFWriter does not work with MPI yet
1615 # See issue https://gitlab.kitware.com/vtk/vtk/-/issues/19231
1616 if (TARGET VTK::IOHDF)
1618  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1619  TEST_SCRIPTS VTKHDFWriter.xml
1620  )
1621 endif()
1622
1623 # The color dialog is different on MacOS X which makes this test fail.
1624 if(NOT APPLE)
1625  list(APPEND TESTS_WITH_BASELINES
1626  BackgroundLights.xml
1627  )
1628 endif()
1629
1630 list(APPEND TESTS_WITH_BASELINES
1631  # This test makes use of "Point Gaussian" representation, only available with OpenGL2
1632  BackgroundColorCheck.xml
1633
1634  # PlotMatrixView is bugging in OpenGL1
1635  PlotMatrixViewArraySelection.xml
1636
1637  # Composite Glyph Trees are only implemented in OpenGL2
1638  CompositeGlyphTree.xml
1639  )
1640
1641 #------------------------------------------------------------------------------
1642 # Add streaming tests.
1643 # We need to locate smooth.flash since it's not included in the default testing
1644 # datasets.
1645 find_file(smooth_flash NAMES smooth.flash
1646  DOC "Path to smooth.flash data file."
1647  NO_DEFAULT_PATH)
1648 mark_as_advanced(smooth_flash)
1649 if (EXISTS "${smooth_flash}")
1650  # we configure the file since we need to point to smooth_flash.
1651  configure_file("AMRStreaming.xml.in"
1652  "${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml" @ONLY)
1653  configure_file("AMRVolumeRendering.xml.in"
1654  "${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml" @ONLY)
1655
1656  set (streaming_tests
1657  ${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml)
1658
1659  # AMRVolumeRendering is a non-streaming test.
1660  list(APPEND TESTS_WITH_BASELINES
1661  ${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml)
1662
1663  foreach (tname ${streaming_tests})
1664  add_pv_test("pv" "_DISABLE_C"
1665  COMMAND --client ${CLIENT_EXECUTABLE}
1666  --enable-bt
1667  --dr
1668  --enable-streaming
1669  --test-directory=${PARAVIEW_TEST_DIR}
1670
1671  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1672  TEST_SCRIPTS ${tname})
1673
1674  add_pv_test(pvcs "_DISABLE_CS"
1675  COMMAND
1676  --server $<TARGET_FILE:ParaView::pvserver>
1677  --enable-bt
1678  --enable-streaming
1679  --client ${CLIENT_EXECUTABLE}
1680  --enable-bt
1681  --dr
1682  --enable-streaming
1683  --test-directory=${PARAVIEW_TEST_DIR}
1684  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1685  TEST_SCRIPTS ${tname})
1686  endforeach()
1687 endif()
1688
1689 #------------------------------------------------------------------------------
1690
1691 # Add tests for OSPRay material editor
1692 if (paraview_use_materialeditor)
1693  list(APPEND TESTS_WITH_INLINE_COMPARES
1694  MaterialEditorCreateMaterials.xml
1695  MaterialEditorLoadMaterials.xml
1696  MaterialEditorSaveMaterials.xml
1697  MaterialEditorShaderBallScene.xml
1698  )
1699 endif ()
1700
1701 # Probe picking does not work in render server mode
1702
1703 # Selection is not available in CRS mode
1704 set(BlockContextMenu_DISABLE_CRS TRUE)
1705 set(BlockLinkedSelection_DISABLE_CRS TRUE)
1706 set(MultipleColorOnSelection_DISABLE_CRS TRUE)
1707 set(MultiSliceWavelet_DISABLE_CRS TRUE)
1708 set(MultiSliceMultiBlock_DISABLE_CRS TRUE)
1709 set(PolygonCellSelection_DISABLE_CRS TRUE)
1710 set(PolygonPointSelection_DISABLE_CRS TRUE)
1711 set(NonlinearSubdivisionDisplay_DISABLE_CRS TRUE)
1712 set(InteractiveSelection_DISABLE_CRS TRUE)
1713 set(NonConvexPolygon_DISABLE_CRS TRUE)
1714 set(QuartilePlot_DISABLE_CRS TRUE)
1715 set(TestSelectionOnMultipiece_DISABLE_CRS TRUE)
1716 set(TestHTGSelection_DISABLE_CRS TRUE)
1717 set(SelectionBlocks_DISABLE_CRS TRUE)
1718 set(SelectionEditor_DISABLE_CRS TRUE)
1719 set(SelectionModifiersCells_DISABLE_CRS TRUE)
1720 set(SelectionModifiersBlocks_DISABLE_CRS TRUE)
1721 set(SelectionModifiersPoints_DISABLE_CRS TRUE)
1722 set(SelectionLinkBasic_DISABLE_CRS TRUE)
1723 set(SelectionLinkInitial_DISABLE_CRS TRUE)
1724 set(SelectionLinkMultiple_DISABLE_CRS TRUE)
1725 set(SelectionLinkRemove_DISABLE_CRS TRUE)
1726 set(SelectionLinkReaction_DISABLE_CRS TRUE)
1727 set(SelectionLinkScripting_DISABLE_CRS TRUE)
1728 set(TestAnnotateSelectionFilter_DISABLE_CRS TRUE)
1729 set(ExpandSelection_DISABLE_CRS TRUE)
1730 set(ExportSelectionToCSV_DISABLE_CRS TRUE)
1731 set(BlockOpacities_DISABLE_CRS TRUE)
1732 set(SaveExodus_DISABLE_CRS TRUE) # yes, this test does a selection
1733 set(CombineFrustumSelections_DISABLE_CRS TRUE) # yes, this test does a selection
1734 set(RenderViewContextMenu_DISABLE_CRS TRUE)
1735
1736 # BoxWidgetVisibleBlock and ZoomToData are not working as well in crs
1737 set(BoxWidgetVisibleBlock_DISABLE_CRS TRUE)
1738 set(ZoomToData_DISABLE_CRS TRUE)
1739 # These tests cannot be run using ctest -j since they are affected by focus
1740 # changed events.
1741 set (AnimatePipelineTime_FORCE_SERIAL TRUE)
1742 set (AnimateProperty_FORCE_SERIAL TRUE) # since this uses popup window
1743 set (AnimationFollowPath_FORCE_SERIAL TRUE) # since this uses popup window
1744 set (BlockContextMenu_FORCE_SERIAL TRUE) # requires context menu
1745 set (CGNSReaderDataLocation_FORCE_SERIAL TRUE) # since this uses popup-menu
1746 set (CTHAMRBaseline_FORCE_SERIAL TRUE) # since this uses popup-menu
1747 set (CTHAMRContour_FORCE_SERIAL TRUE) # since this uses popup-menu
1748 set (CTHAMRDualClip_FORCE_SERIAL TRUE) # since this uses popup-menu
1749 set (CTHAMRMaterialInterfaceFilter_FORCE_SERIAL TRUE) # since this uses popup-menu
1750 set (CTHDerivedDensity2DCylinder_FORCE_SERIAL TRUE) # since this uses popup-menu
1751 set (Calculator_FORCE_SERIAL TRUE) # since this uses popup-menu
1752 set (CategoricalAutomaticAnnotations_FORCE_SERIAL TRUE) # Seems to works better in serial
1753 set (CategoricalColors_FORCE_SERIAL TRUE) # Uses inline edit popups
1754 set (CategoricalOpacities_FORCE_SERIAL TRUE) # Seems to works better in serial
1755 set (ChartAxisRangeAndLabels_FORCE_SERIAL TRUE) # Uses inline edit popups
1756 set (ColorOpacityTableEditing_FORCE_SERIAL TRUE) # since this uses popup-menu
1757 set (ComparativeViewOverlay_FORCE_SERIAL TRUE) # Seems to works better in serial
1758 set (ComputeArrayMagnitudeSetting_FORCE_SERIAL TRUE) # Seems to works better in serial
1759 set (ConfigurableCategories_FORCE_SERIAL TRUE) # since this uses popup-menu
1760 set (Contour_FORCE_SERIAL TRUE) # since this uses popup-menu
1761 set (CustomViewpoints_FORCE_SERIAL TRUE)
1762 set (DefaultReadersSetting_FORCE_SERIAL TRUE) # since this uses popup-menu
1763 set (ExodusModeShapes_FORCE_SERIAL TRUE)
1764 set (ExportFilteredColumnsSpreadsheet_FORCE_SERIAL TRUE) # since this uses popup-menu
1765 set (ExpressionChooser_FORCE_SERIAL TRUE) # since this uses popup-menu
1766 set (ExpressionsDialog_FORCE_SERIAL TRUE) # since this uses popup-menu
1767 set (ExpressionsExporter_FORCE_SERIAL TRUE) # since this uses popup-menu
1768 set (ExpressionsSettings_FORCE_SERIAL TRUE) # since this uses combo-box popup-menu
1769 set (LoadSaveStateAnimation_FORCE_SERIAL TRUE)
1770 set (LoadSaveStateVolume_FORCE_SERIAL TRUE)
1771 set (LogColorMapToggle_FORCE_SERIAL TRUE) # since this pops up output window
1772 set (LogColorMap_FORCE_SERIAL TRUE) # since this uses popup-menu
1773 set (MathTextColumn_FORCE_SERIAL TRUE) # since this uses popup-menu
1774 set (PolygonCellSelection_FORCE_SERIAL TRUE)
1775 set (PolygonPointSelection_FORCE_SERIAL TRUE)
1776 set (PropertyLink_FORCE_SERIAL TRUE)
1777 set (PropertyContextMenu_FORCE_SERIAL TRUE)
1778 set (ProxyCategoriesConfiguration_FORCE_SERIAL TRUE) # since this uses popup-line edit
1779 set (ProxyCategoriesToolbar_FORCE_SERIAL TRUE)
1780 set (QuickLaunchCreateProxy_FORCE_SERIAL TRUE)
1781 set (QuickLaunchNavigation_FORCE_SERIAL TRUE)
1782 set (QuickLaunchRequest_FORCE_SERIAL TRUE)
1783 set (ReadPartitionedCGNS_FORCE_SERIAL TRUE) # since this uses popup-menu
1784 set (RecentFiles_FORCE_SERIAL TRUE) # use key events
1785 set (RecentFilesHardFilename_FORCE_SERIAL TRUE) # use key events
1786 set (SPTimeseries_FORCE_SERIAL TRUE) # since this uses popup-menu
1787 set (SaveColorMap_FORCE_SERIAL TRUE) # Uses inline edit popups
1788 set (SeriesPresetRegexp_FORCE_SERIAL TRUE) # since this uses popup-menu
1789 set (SeriesPreset_FORCE_SERIAL TRUE) # since this uses popup-menu
1790 set (ShaderReplacements_FORCE_SERIAL TRUE)
1791 set (SimpleInteraction_FORCE_SERIAL TRUE) # since this uses popup-menu
1792 set (TestHTGHoverOnCell_FORCE_SERIAL TRUE) # since this uses QTooltip and QShortcut
1793 set (TestIsoVolume_FORCE_SERIAL TRUE) # since this uses popup-menu
1794 set (TestPythonView_FORCE_SERIAL TRUE) # Seems to work better in serial.
1795 set (TimeKeeper_FORCE_SERIAL TRUE) # since this uses popup window
1796 set (TooltipCopy_FORCE_SERIAL TRUE) # since this uses QTooltip and QShortcut
1797 set (TraceMultiViews_FORCE_SERIAL TRUE) # Seems to works better in serial
1798 set (glTFReaderAnimatedMorphing_FORCE_SERIAL TRUE) # since this uses popup-menu
1799 set (glTFReaderToggleDeformation_FORCE_SERIAL TRUE) # since this uses popup-menu
1800
1801 # those tests load and remove macros. Serial avoid side effects
1802 set(MacroEditor_FORCE_SERIAL TRUE)
1803 set(IconBrowser_FORCE_SERIAL TRUE)
1804 set(PythonResetSessionMacro_FORCE_SERIAL TRUE)
1805
1806 # We don't support volume rendering of image data in data server & render server mode
1807 set(AdaptiveResampleToImage_DISABLE_CRS TRUE)
1808 set(LoadSaveStateVolume_DISABLE_CRS TRUE)
1809 set(SeparatedColorMapOpacity_DISABLE_CRS TRUE)
1810 set(VolumeReprTwoIndepComp_DISABLE_CRS TRUE)
1811 set(VolumeCrop_DISABLE_CRS TRUE)
1812 set(VolumeSliceBlendMode_DISABLE_CRS TRUE)
1813 set(VolumeIsosurfaceBlendMode_DISABLE_CRS TRUE)
1814 set(PointVolumeInterpolator_DISABLE_CRS TRUE)
1815
1816 # Set properties for CTH tests
1817 set(CTHAMRContour_DISABLE_CS TRUE)
1818 set(CTHAMRContour_DISABLE_CRS TRUE)
1819 set(CTHAMRDualClip_DISABLE_CS TRUE)
1820 set(CTHAMRDualClip_DISABLE_CRS TRUE)
1821 set(CTHAMRClip_DISABLE_CS TRUE)
1822 set(CTHAMRClip_DISABLE_CRS TRUE)
1823 set(CTHAMRMaterialInterfaceFilter_DISABLE_CS TRUE)
1824 set(CTHAMRMaterialInterfaceFilter_DISABLE_CRS TRUE)
1825
1826 # Add image threshold overrides for tests.
1827 # Generally all tests with wireframes need higher thresholds.
1828 SET (Flow2_THRESHOLD 15)
1829 SET (UndoRedo1_THRESHOLD 15)
1830 SET (UndoRedo4_THRESHOLD 15)
1831
1832 # Differences between systems on whether the lines are anti-aliased or not
1833 SET (SortLineChartData_THRESHOLD 50)
1834
1835 # Since often there are issues with fonts etc.
1836 SET (XYChart_THRESHOLD 150)
1837 SET (CheckableHeader_THRESHOLD 150)
1838 # Since the test uses surface-selection, it cannot work in render-server mode.
1839 set(XYChart_DISABLE_CRS TRUE)
1840 # this uses charts: nb of points changes in client server, so graphs differs
1841 set(LinkViews_DISABLE_CS TRUE)
1842 set(LinkViews_DISABLE_CRS TRUE)
1843
1844 SET (XYHistogram_THRESHOLD 150)
1845 set (ChartAxisRangeAndLabels_THRESHOLD 5)
1846
1847 # The color and opacity are often different on different machines.
1848 SET (ColorEditorControls_THRESHOLD 60)
1849 SET (ColorEditorVolumeControls_THRESHOLD 300)
1850
1851 # PlotDataOverTime produces different block labels in parallel
1852 # This leeway helps that.
1853 set (PlotDataOverTime-NonDistributed_THRESHOLD 25)
1854
1855 # Test needs to load a plugin, the test only records that for the
1856 # client side.
1857 set (SteeringDataGenerator_DISABLE_CS TRUE)
1858 set (SteeringDataGenerator_DISABLE_CRS TRUE)
1859
1860 # Plot image leeway.
1861 set (SpreadSheet2_THRESHOLD 50)
1862 set (PlotOverTimeAutoApply_THRESHOLD 50)
1863 set (ExportLinePlotToCSV_THRESHOLD 30)
1864 set (ExportLinePlotToTSV_THRESHOLD 30)
1865 set (PlotOverTimeAutoApply_DISABLE_CRS TRUE) # since this uses surface selection.
1866 set (QuartilePlot_THRESHOLD 20)
1867 # The ExportLinePlotToTSV test uses the same image baseline as the ExportLinePlotToCSV test
1868 set (ExportLinePlotToTSV_BASELINE ExportLinePlotToCSV.png)
1869
1870 # ExportSceneSpreadSheetView2 won't work in parallel CS because of ghost cells
1871 # than cannot be processed by TableToStructuredGrid.
1872 set(ExportSceneSpreadSheetView2_DISABLE_CS TRUE)
1873 set(ExportSceneSpreadSheetView2_DISABLE_CRS TRUE)
1874
1875 # Cannot support CRS since we do volume rendering of image data
1876 # in this test.
1877 set (RemoteRendering_DISABLE_CRS TRUE)
1878 set (RemoteRendering_THRESHOLD 50)
1879 set (VolumeRenderingWithContour_DISABLE_CRS TRUE)
1880 set (VolumeRenderingWithContour_THRESHOLD 50)
1881 set (VolumeNoMapScalars_DISABLE_CRS TRUE)
1882 set (VolumeNoMapScalars_THRESHOLD 50)
1883 set (MultiBlockVolumeRendering_DISABLE_CRS TRUE)
1884 set (ColorOpacityEditorFreehandDrawing_DISABLE_CRS TRUE)
1885
1886 # Composite Surface Selection is currently broken in everything but builtin
1887 SET (CompositeSurfaceSelection_DISABLE_CS TRUE)
1888 SET (CompositeSurfaceSelection_DISABLE_CRS TRUE)
1889
1890 # Clip test has object picking which is not supported in client-render-server
1891 # mode.
1892 SET (Clip_DISABLE_CRS TRUE)
1893
1894 # Image and rectilinear grid volume rendering not supported in CRS mode.
1895 set (ImageVolumeRendering_DISABLE_CRS TRUE)
1896 set (RectilinearVolumeRendering_DISABLE_CRS TRUE)
1897
1898 # These Xdmf tests have wireframes, hence the increased thresholds.
1899 SET (XdmfReadImageData_THRESHOLD 20)
1900 SET (XdmfReadRectilinearGrid_THRESHOLD 20)
1901 SET (XdmfReadRectilinearGridCollection_THRESHOLD 20)
1902 SET (XdmfReadStructuredGrid_THRESHOLD 20)
1903 SET (XdmfReadStructuredGridCollection_THRESHOLD 20)
1904 SET (XdmfReadImageDataCollection_THRESHOLD 20)
1905
1906 # This test renders points and they are offsetted a bit differently on
1907 # different platforms so just increase the threshold
1908 SET (SaveCSV_THRESHOLD 40)
1909 SET (SaveTSV_THRESHOLD 40)
1910 SET (SaveTXT_THRESHOLD 40)
1911 # The SaveTXT and SaveTSV tests use the same image baseline as the SaveCSV test
1912 SET (SaveTSV_BASELINE SaveCSV.png)
1913 SET (SaveTXT_BASELINE SaveCSV.png)
1914
1915 # Disable some testing configurations for these tests.
1916
1917 ## Disable ClientRenderServer tests for FFTOverTime. This is done since
1918 ## selection is not supported in render server mode esp. when number of render
1919 ## server processes is not the same as the data server processes
1920 set (FFTOverTime_DISABLE_CRS TRUE)
1921 set (FFTOverTime_THRESHOLD 70) # since there's a plot, account for minor
1922  # rendering differences.
1923
1924 # ColorEditorVolumeControls does volume rendering of structrued data which required remote
1925 # rendering in client-serve mode.
1926 SET (ColorEditorVolumeControls_DISABLE_CS TRUE)
1927 SET (ColorEditorVolumeControls_DISABLE_CRS TRUE)
1928
1929 # ViewSettingsDialog, TextureUsages, LogoSourcesInChartViews and LogoSource use texture which are not supported in pvcrs mode.
1930 SET (ViewSettingsDialog_DISABLE_CRS TRUE)
1931 SET (TextureUsages_DISABLE_CRS TRUE)
1932 SET (LogoSourcesInChartViews_DISABLE_CRS TRUE)
1933 SET (LogoSource_DISABLE_CRS TRUE)
1934
1935 # MultiBlockAttributes1 requires selection which doesn't work on pvcrs
1936 SET (MultiBlockAttributes1_DISABLE_CRS TRUE)
1937
1938 # Due to issue #20657, the tangents are not sent in pvcrs mode
1939 # event using remote rendering
1940 # We can remove this when issue #20657 is resolved
1941 SET (AnisotropyPBR_DISABLE_CRS TRUE)
1942
1943 ## Disable ClientRenderServer tests for TransferFunction2D. This is done since
1944 ## image data delivery is not supported in render server mode
1945 SET (TransferFunction2D_DISABLE_CRS TRUE)
1946 SET (TransferFunction2DYScalars_DISABLE_CRS TRUE)
1947 SET (TransferFunction2DYScalarsEditor_DISABLE_CRS TRUE)
1948 SET (TransferFunction2DYScalarsEditorA_DISABLE_CRS TRUE)
1949 SET (TransferFunction2DYScalarsEditorB_DISABLE_CRS TRUE)
1950 ## The 2D transfer function editor baselines are different on different machines
1951 SET (TransferFunction2D_THRESHOLD 300)
1952 SET (TransferFunction2DYScalars_THRESHOLD 500)
1953 SET (TransferFunction2DYScalarsEditor_THRESHOLD 500)
1954 SET (TransferFunction2DYScalarsEditorA_THRESHOLD 500)
1955 SET (TransferFunction2DYScalarsEditorB_THRESHOLD 500)
1956
1957 # Plugins are only built as shared libraries.
1958 IF (NOT BUILD_SHARED_LIBS)
1959  SET (NiftiReaderWriterPlugin_DISABLE_C TRUE)
1960 ENDIF ()
1961 # There should be a client server specific version of this test.
1962 SET (NiftiReaderWriterPlugin_DISABLE_CS TRUE)
1963 SET (NiftiReaderWriterPlugin_DISABLE_CRS TRUE)
1964
1965 # Set image threshold overrides for the tests.
1966 SET(SaveLargeScreenshot_THRESHOLD 40)
1967
1968 # Make these tests use reverse connection.
1969 SET (CutMulti_REVERSE_CONNECT TRUE)
1970
1971 # Since this involves charts.
1972 SET(HistogramSelection_THRESHOLD 40)
1973 SET(LineChartSelection_THRESHOLD 40)
1974 SET(MultiBlockChartSelection_THRESHOLD 40)
1975
1976 # Increate threshold for this one since the chart axes
1977 # tends to render slightly differently.
1978 set (LoadStateMultiView_THRESHOLD 20)
1979
1980 # Selection not supported in CRS and is needed for this test.
1981 set (ResetToVisibleRange_DISABLE_CRS TRUE)
1982
1983 # Molecules are not supported in client-serve modes, currently.
1984 #set (Molecule_DISABLE_CS TRUE)
1985 #set (Molecule_DISABLE_CRS TRUE)
1986 #set (MoleculeColoring_DISABLE_CS TRUE)
1987 #set (MoleculeColoring_DISABLE_CRS TRUE)
1988
1989 # some glTF tests are not working in CS currently
1990 # https://gitlab.kitware.com/paraview/paraview/-/issues/20572
1991 set (glTFReaderToggleDeformation_DISABLE_CS TRUE)
1992 set (glTFReaderToggleDeformation_DISABLE_CRS TRUE)
1993 set (glTFReaderMultipleScenes_DISABLE_CS TRUE)
1994 set (glTFReaderMultipleScenes_DISABLE_CRS TRUE)
1995 set (glTFReaderMultipleAnimations_DISABLE_CS TRUE)
1996 set (glTFReaderMultipleAnimations_DISABLE_CRS TRUE)
1997
1998 # pvd writer/reader has issues creating directories or filenames with punctuation
1999 # https://gitlab.kitware.com/paraview/paraview/-/issues/22361
2000 if (NOT APPLE)
2001  set (RecentFilesHardFilename_DISABLE_CS TRUE)
2002  set (RecentFilesHardFilename_DISABLE_CRS TRUE)
2003 endif()
2004
2005 # tests involve pointCount checks, so not reliable in CS modes.
2006 set (PlotOverLine_3d_DISABLE_CS TRUE)
2007 set (PlotOverLine_3d_DISABLE_CRS TRUE)
2008 set (PlotOverLine_htg_DISABLE_CS TRUE)
2009 set (PlotOverLine_htg_DISABLE_CRS TRUE)
2010 set (PlotOverLine_surface_DISABLE_CS TRUE)
2011 set (PlotOverLine_surface_DISABLE_CRS TRUE)
2012
2013 # CGNS BC patches not supported in parallel
2014 set(ReadCGNSBCDataset_DISABLE_CS TRUE)
2015 set(ReadCGNSBCDataset_DISABLE_CRS TRUE)
2016 set(CONVERGECFDCGNSReader_DISABLE_CS TRUE)
2017 set(CONVERGECFDCGNSReader_DISABLE_CRS TRUE)
2018
2019 set(TESTS_WITH_MULTI_SERVERS_3
2020  TestMultiServer3.xml
2021 )
2022
2023 # ResampleToHyperTreeGrid only works in client mode
2025  TEST_SCRIPTS ResampleToHyperTreeGrid.xml
2026 )
2027
2028 # RandomAttributes generate different results depending on the data
2029 # distribution so we enable it on client mode only for now
2030 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22596
2032  TEST_SCRIPTS RandomAttributesHTG.xml
2033 )
2034
2035 # FDS Reader has issues in client-server mode.
2036 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22687
2038  TEST_SCRIPTS TestFDSReader.xml
2039 )
2040
2041 # TODO: remote rendering tests and reverse connect tests.
2042
2044  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2045  TEST_SCRIPTS ${TESTS_WITH_MULTI_SERVERS_3})
2046
2048  TEST_SCRIPTS TileDisplaySplitView.xml)
2050  TEST_SCRIPTS LinkCameraFromView.xml)
2051 if (PARAVIEW_USE_MPI)
2053  TEST_SCRIPTS TileDisplaySplitView.xml)
2055  TEST_SCRIPTS TileDisplaySplitView.xml)
2057  TEST_SCRIPTS TileDisplaySplitView.xml)
2058 endif()
2059
2060 paraview_add_cave_tests(2 "${CMAKE_CURRENT_SOURCE_DIR}/LeftRight.pvx"
2061  TEST_SCRIPTS TestCAVE.xml TestCAVEVolumeRendering.xml)
2062
2063 #------------------------------------------------------------------
2064 # Add tests that test command line arguments (among other things).
2065 #------------------------------------------------------------------
2066 if (TARGET ParaView::paraview)
2067  # The state file need to point to the correct data file. We do that by
2068  # configuring the state file.
2070  ARGS "--state=${CMAKE_CURRENT_SOURCE_DIR}/exodusStateFile.3.14.1.pvsm"
2071  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2072  TEST_SCRIPTS LoadExodusStateFile.xml
2073  ENVIRONMENT
2074  PARAVIEW_DATA_ROOT=${paraview_test_data_directory_output}
2075  )
2076
2078  ARGS "--state=${CMAKE_CURRENT_SOURCE_DIR}/boxClip.5.6.pvsm"
2079  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2080  TEST_SCRIPTS BoxClipStateBackwardsCompatibility.xml)
2081
2083  ARGS "--data=${paraview_test_data_directory_output}/Testing/Data/FileSeries/blow..vtk"
2084  TEST_SCRIPTS CheckDataArgumentsWithFileSeries.xml
2085  )
2086
2088  ARGS " ${paraview_test_data_directory_output}/Testing/Data/FileSeries/blow..vtk"
2089  TEST_SCRIPTS CheckPositionalArgumentsWithFileSeries.xml
2090  )
2091
2092  if (PARAVIEW_USE_PYTHON)
2093  # Test whether or not we can load a Python state file with the --state
2094  # command line option as well as loading a Python state file that was
2095  # generated with PV 5.4.1. Loading the 5.4.1 Python state file checks
2096  # on backwards compatibility.
2097  set (Calculator54State_THRESHOLD 100)
2099  ARGS "--state=${CMAKE_CURRENT_SOURCE_DIR}/Calculator54State.py"
2100  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2101  TEST_SCRIPTS Calculator54State.xml)
2102  endif()
2103
2104  #----------------------------------------------------------------------
2105  # Add test to test stereo rendering modes.
2107  CLIENT_ARGS --stereo --stereo-type=Interlaced
2108  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2109  TEST_SCRIPTS StereoInterlaced.xml)
2111  CLIENT_ARGS --stereo --stereo-type=Interlaced
2112  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2113  TEST_SCRIPTS StereoInterlaced.xml)
2115  CLIENT_ARGS --stereo --stereo-type=Interlaced
2116  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2117  TEST_SCRIPTS StereoInterlaced.xml)
2119  CLIENT_ARGS --stereo --stereo-type=SplitViewportHorizontal
2120  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2121  TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2123  CLIENT_ARGS --stereo --stereo-type=SplitViewportHorizontal
2124  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2125  TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2127  CLIENT_ARGS --stereo --stereo-type=SplitViewportHorizontal
2128  BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2129  TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2130 endif()
2131
2132 #----------------------------------------------------------------------
2133 # Very small texture size limits on mesa cause error messages for some tests that
2134 # include coloring by cell data. Let's skip those.
2135 set(texture_buffer_exceeding_hardware_tests
2136  CONVERGECFDReader
2137  CONVERGECFDReaderWithVisItBridge
2138  TestGroupDataFromTimeSeries
2139  OMFReader
2140 )
2141
2142 foreach(test_name IN LISTS texture_buffer_exceeding_hardware_tests)
2143  foreach(prefix IN ITEMS pv pvcs pvcrs)
2144  if (TEST "${prefix}.${test_name}")
2145  set_property(TEST "${prefix}.${test_name}" APPEND PROPERTY
2146  SKIP_REGULAR_EXPRESSION "Attempt to use a texture buffer exceeding your hardware")
2147  endif()
2148  endforeach()
2149 endforeach()
2150
2151 # Server Connection specific tests
2152
2153 if(NOT WIN32) # On windows, QtTesting is not able to press the connection dialog buttons
2155  SMTESTING_ALLOW_ERRORS
2156  FORCE_SERIAL
2157  TEST_SCRIPTS ServerConnectTimeout.xml)
2158 endif()
2159
2160 configure_file (
2161  "${CMAKE_CURRENT_SOURCE_DIR}/configuredServer.pvsc.in"
2162  "${CMAKE_CURRENT_BINARY_DIR}/configuredServer.pvsc" @ONLY)
2163
2164 configure_file (
2165  "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectConfigured.xml.in"
2166  "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml" @ONLY)
2167
2169  FORCE_SERIAL
2170  TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml)
2171
2172 if (PARAVIEW_PLUGIN_ENABLE_ArrowGlyph)
2173  configure_file (
2174  "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectPluginLoad.xml.in"
2175  "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml" @ONLY)
2176
2178  FORCE_SERIAL
2179  TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml)
2180 endif ()
data
macro ADD_CATALYST_LIVE_TEST(test_name, duration, command_line_connect_command)
function paraview_add_client_server_render_tests()
type
on
function paraview_add_client_server_tests()
function paraview_add_cave_tests(num_ranks, config)
function paraview_add_tile_display_tests(width, height)
#define BUILD_SHARED_LIBS
Definition: config.h:45
mode
function paraview_add_multi_server_tests(count)
function paraview_add_client_tests()
#define PARAVIEW_USE_QTHELP
Definition: pqQtConfig.h:8
#define PARAVIEW_USE_PYTHON
Definition: moc_predefs.h:262
key
