79 #ifndef vtkSIDataArraySelectionProperty_h 80 #define vtkSIDataArraySelectionProperty_h 106 int NumberOfElementsPerCommand;
static vtkSIProperty * New()
virtual bool Push(vtkSMMessage *, int)
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
virtual bool ReadXMLAttributes(vtkSIProxy *proxyhelper, vtkPVXMLElement *element)
Parse the xml for the property.
supports API using vtkDataArraySelection.
Basic ServerImplementation property used to call a method with no argument on a VTK object...
virtual bool Pull(vtkSMMessage *)
