supports API using vtkDataArraySelection. More...
#include <vtkSIDataArraySelectionProperty.h>
typedef vtkSIProperty | Superclass |
The name assigned by the xml parser. More... | |
virtual char * | GetCommand () |
The command name used to set the value on the server object. More... | |
virtual bool | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual bool | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
virtual void | SetIsInternal (bool) |
This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More... | |
virtual bool | GetIsInternal () |
virtual void | Modified () |
static vtkSIDataArraySelectionProperty * | New () |
static vtkSIDataArraySelectionProperty * | SafeDownCast (vtkObject *o) |
static vtkSIProperty * | New () |
static vtkSIProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIDataArraySelectionProperty () | |
~vtkSIDataArraySelectionProperty () override | |
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
Parse the xml for the property. More... | |
bool | Push (vtkSMMessage *, int) override |
Push a new state to the underneath implementation. More... | |
bool | Pull (vtkSMMessage *) override |
Pull the current state of the underneath implementation. More... | |
vtkDataArraySelection * | GetSelection () |
vtkSIProperty () | |
~vtkSIProperty () override | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
Interprets the message. More... | |
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
char * | XMLName |
char * | Command |
bool | InformationOnly |
bool | Repeatable |
bool | IsInternal |
vtkWeakPointer< vtkSIProxy > | SIProxyObject |
bool | Debug |
vtkTimeStamp | MTime |
vtkSIDataArraySelectionProperty can be used to get/set array selection status parameters on a VTK object using vtkDataArraySelection. Readers typically offer API to get information about data array available as well as enable/disable arrays to read using a vtkDataArraySelection instance e.g. vtkXMLReader::GetPointDataArraySelection
. This si-property can be used on vtkSMStringVectorProperty instances that use such an API on the reader to both get array selection status as well as set them.
This offers a convenient replacement for vtkSIArraySelectionProperty which requires a quirky API on the VTK class to get/set similar information and is recommended over vtkSIArraySelectionProperty in new code.
To use vtkSIDataArraySelectionProperty, simply add this as the si_class
on the properties for getting and setting array selection with command
set to the method name that returns a mutable vtkDataArraySelection instance.
e.g.
vtkSIDataArraySelectionProperty can also be used for filters that use vtkDataArraySelection.
Definition at line 86 of file vtkSIDataArraySelectionProperty.h.
Definition at line 90 of file vtkSIDataArraySelectionProperty.h.
overrideprotectedvirtual |
