property representing a vector of strings More...
#include <vtkSMStringVectorProperty.h>
enum | ElementTypes { INT, DOUBLE, STRING } |
typedef vtkSMVectorProperty | Superclass |
typedef vtkSMProperty | Superclass |
unsigned int | GetNumberOfElements () override |
Returns the size of the vector. More... | |
void | SetNumberOfElements (unsigned int num) override |
Sets the size of the vector. More... | |
int | SetElement (unsigned int idx, const char *value) |
Set the value of 1 element. More... | |
int | SetElements (const char *values[], unsigned int count) |
Sets multiple elements. More... | |
int | AppendElements (const std::vector< std::string > &newvalue) |
Append the values. More... | |
int | AppendUncheckedElements (const std::vector< std::string > &newvalue) |
Append the values to the unchecked elements. More... | |
void | GetElements (vtkStringList *list) |
Fills up the vtkStringList instance with the current value. More... | |
const char * | GetElement (unsigned int idx) |
Returns the value of 1 element. More... | |
unsigned int | GetElementIndex (const char *value, int &exists) |
Returns the index of an element with a particular value. More... | |
const char * | GetUncheckedElement (unsigned int idx) |
Returns the value of 1 unchecked element. More... | |
void | SetUncheckedElement (unsigned int idx, const char *value) |
Set the value of 1 unchecked element. More... | |
unsigned int | GetNumberOfUncheckedElements () override |
Returns the size of unchecked elements. More... | |
void | Copy (vtkSMProperty *src) override |
Copy all property values. More... | |
const char * | GetDefaultValue (int idx) |
Returns the default value, if any, specified in the XML. More... | |
void | ClearUncheckedElements () override |
API for setting unchecked element values. More... | |
bool | IsValueDefault () override |
Returns true if the property's value is different from the default value. More... | |
void | ResetToXMLDefaults () override |
For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More... | |
int | SetElements (vtkStringList *newvalue) |
int | SetElements (const std::vector< std::string > &newvalue) |
int | SetUncheckedElements (const char *values[], unsigned int count) |
Sets the values of all the unchecked elements. More... | |
int | SetUncheckedElements (const std::vector< std::string > &newvalue) |
const std::vector< std::string > & | GetElements () const |
Another API to access all elements. More... | |
const std::vector< std::string > & | GetUncheckedElements () const |
void | SetElementType (unsigned int idx, int type) |
Set the cast type used when passing a value to the stream. More... | |
int | GetElementType (unsigned int idx) |
void | GetUncheckedElements (vtkStringList *list) |
Get/Set unchecked elements. More... | |
int | SetUncheckedElements (vtkStringList *list) |
virtual void | SetInitialString (const char *) |
virtual char * | GetInitialString () |
bool | ResetToDomainDefaults (bool use_unchecked_values=false) override |
Overridden to add support to load defaults from this->GetInformationProperty(), if one exists. More... | |
virtual int | GetRepeatCommand () |
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More... | |
virtual void | SetRepeatCommand (int) |
virtual void | RepeatCommandOn () |
virtual void | RepeatCommandOff () |
virtual int | GetNumberOfElementsPerCommand () |
virtual void | SetNumberOfElementsPerCommand (int) |
virtual int | GetUseIndex () |
If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More... | |
virtual void | SetUseIndex (int) |
virtual void | UseIndexOn () |
virtual void | UseIndexOff () |
virtual void | SetCleanCommand (const char *) |
Command that can be used to remove all values. More... | |
virtual char * | GetCleanCommand () |
virtual void | SetSetNumberCommand (const char *) |
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More... | |
virtual char * | GetSetNumberCommand () |
int | IsInDomains () |
Returns true if all values are in all domains, false otherwise. More... | |
int | IsInDomains (vtkSMDomain **domain) |
Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More... | |
void | UnRegister (vtkObjectBase *obj) override |
Overloaded to break the reference loop caused by the internal domain iterator. More... | |
vtkSMDomainIterator * | NewDomainIterator () |
Creates, initializes and returns a new domain iterator. More... | |
vtkSMDomain * | GetDomain (const char *name) |
Returns a domain give a name. More... | |
vtkSMDomain * | FindDomain (const char *classname) |
Returns the first domain which is of the specified type. More... | |
template<class DomainType > | |
DomainType * | FindDomain () |
Same as FindDomain(classname), except the classname is deduced from the type. More... | |
unsigned int | GetNumberOfDomains () |
Returns the number of domains this property has. More... | |
void | AddDomain (const char *name, vtkSMDomain *dom) |
Properties can have one or more domains. More... | |
virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
Add a link to a property whose value should be synchronized with this property value. More... | |
virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
Remove a link to a property added with AddLinkedProperty() More... | |
virtual void | RemoveFromSourceLink () |
Remove a link from the source property. More... | |
void | ResetToDefault () |
Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More... | |
vtkSMProxy * | GetParent () |
Get the proxy to which this property belongs. More... | |
virtual bool | IsStateIgnored () |
bool | HasDomainsWithRequiredProperties () |
Returns true if the property has a domain with required properties. More... | |
virtual void | SetCommand (const char *) |
The command name used to set the value on the server object. More... | |
virtual char * | GetCommand () |
virtual void | SetImmediateUpdate (int) |
If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More... | |
virtual int | GetImmediateUpdate () |
virtual int | GetInformationOnly () |
Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More... | |
virtual int | GetIgnoreSynchronization () |
If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More... | |
virtual vtkSMProperty * | GetInformationProperty () |
Get the associated information property. More... | |
virtual void | SetAnimateable (int) |
Get/Set if the property is animateable. More... | |
virtual int | GetAnimateable () |
virtual void | SetIsInternal (int) |
Get/Set if the property is internal to server manager. More... | |
virtual int | GetIsInternal () |
virtual void | SetNoCustomDefault (int) |
Set/Get whether the property should ignore custom default settings. More... | |
virtual int | GetNoCustomDefault () |
virtual void | SetPanelVisibility (const char *) |
Set/Get the panel visibility for the property. More... | |
virtual char * | GetPanelVisibility () |
virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
Set/Get the panel visibility to default if the current representation type matches representation . More... | |
virtual char * | GetPanelVisibilityDefaultForRepresentation () |
virtual void | SetPanelWidget (const char *) |
Set/Get the name of the custom panel widget to use for the property. More... | |
virtual char * | GetPanelWidget () |
virtual void | SetDisableSubTrace (const char *) |
Set/Get the tracing of sub property of this property. More... | |
virtual char * | GetDisableSubTrace () |
Returns the documentation for this proxy. More... | |
The label assigned by the xml parser. More... | |
The name assigned by the xml parser. More... | |
virtual int | GetRepeatable () |
If repeatable, a property can have 1 or more values of the same kind. More... | |
The server manager configuration XML may define <Hints/> element for a property. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | Modified () override |
Overridden to support blocking of modified events. More... | |
static vtkSMStringVectorProperty * | New () |
static vtkSMStringVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSMVectorProperty * | SafeDownCast (vtkObject *o) |
static vtkSMProperty * | New () |
static vtkSMProperty * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMStringVectorProperty () | |
~vtkSMStringVectorProperty () override | |
void | SetNumberOfUncheckedElements (unsigned int num) override |
Sets the size of unchecked elements. More... | |
int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override |
Manage additional attribute from the XML -default_values_delimiter: char used to split the "default_values" into a vector. More... | |
void | WriteTo (vtkSMMessage *) override |
Let the property write its content into the stream. More... | |
void | ReadFrom (const vtkSMMessage *, int msg_offset, vtkSMProxyLocator *) override |
Let the property read and set its content from the stream. More... | |
int | LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override |
Load the XML state. More... | |
void | SaveStateValues (vtkPVXMLElement *propElement) override |
This method must be overridden by concrete class in order to save the real property data. More... | |
vtkSMVectorProperty () | |
~vtkSMVectorProperty () override | |
Set the appropriate ivars from the xml element. More... | |
vtkSMProperty () | |
~vtkSMProperty () override | |
virtual void | ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *) |
virtual void | UpdateAllInputs () |
Update all proxies referred by this property (if any). More... | |
vtkSMProperty * | NewProperty (const char *name) |
Internal. More... | |
void | AddDependent (vtkSMDomain *dom) |
void | RemoveAllDependents () |
Removes all dependents. More... | |
void | UpdateDomains () |
Calls Update() on all domains contained by the property as well as all dependent domains. More... | |
virtual void | SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1) |
Save the property state in XML. More... | |
virtual void | SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid) |
Save property domain. More... | |
virtual void | SetXMLLabel (const char *) |
virtual void | SetInformationOnly (int) |
virtual void | SetIgnoreSynchronization (int) |
void | SetInformationProperty (vtkSMProperty *ip) |
void | SetDocumentation (vtkSMDocumentation *) |
void | SetParent (vtkSMProxy *proxy) |
virtual void | SetStateIgnored (bool) |
virtual void | StateIgnoredOn () |
virtual void | StateIgnoredOff () |
bool | SetBlockModifiedEvents (bool block) |
Block/unblock modified events, returns the current state of the block flag. More... | |
virtual bool | GetPendingModifiedEvents () |
Returns if any modified evetns are pending. More... | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
vtkSMStringVectorProperty is a concrete sub-class of vtkSMVectorProperty representing a vector of strings. vtkSMStringVectorProperty can also be used to store double and int values as strings. The strings are converted to the appropriate type when they are being passed to the stream. This is generally used for calling methods that have mixed type arguments.
Definition at line 29 of file vtkSMStringVectorProperty.h.
Definition at line 33 of file vtkSMStringVectorProperty.h.
Enumerator | |
INT | |
DOUBLE | |
STRING |
Definition at line 152 of file vtkSMStringVectorProperty.h.
Reimplemented from vtkSMVectorProperty.
Reimplemented from vtkSMProperty.
Implements vtkSMVectorProperty.
If num is larger than the current number of elements, this may cause reallocation and copying.
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or the value is not in all domains. Returns 1 otherwise.
The size of the property is changed to match count.
int vtkSMStringVectorProperty::SetElements | ( | vtkStringList * | newvalue | ) |
int vtkSMStringVectorProperty::SetElements | ( | const std::vector< std::string > & | newvalue | ) |
int vtkSMStringVectorProperty::SetUncheckedElements | ( | const std::vector< std::string > & | newvalue | ) |
int vtkSMStringVectorProperty::AppendElements | ( | const std::vector< std::string > & | newvalue | ) |
Append the values.
int vtkSMStringVectorProperty::AppendUncheckedElements | ( | const std::vector< std::string > & | newvalue | ) |
void vtkSMStringVectorProperty::GetElements | ( | vtkStringList * | list | ) |
const std::vector<std::string>& vtkSMStringVectorProperty::GetElements | ( | ) | const |
const std::vector<std::string>& vtkSMStringVectorProperty::GetUncheckedElements | ( | ) | const |
exists is set to false if element does not exist.
For example, if the type is INT, the string is converted to an int (with atoi()) before being passed to stream. Note that representing scalar values as strings can result in loss of accuracy. Possible values are: INT, DOUBLE, STRING.
These are used by domains. SetElement() first sets the value of 1 unchecked element and then calls IsInDomain and updates the value of the corresponding element only if IsInDomain passes.
This can be used to check if a value is in all domains of the property. Call this and call IsInDomains().
void vtkSMStringVectorProperty::GetUncheckedElements | ( | vtkStringList * | list | ) |
int vtkSMStringVectorProperty::SetUncheckedElements | ( | vtkStringList * | list | ) |
Usually this is the same as the number of elements but can be different before a domain check is performed.
overrideprotectedvirtual |
-element_types: StringVectorProperty may be used to store non homogeneous vector, therefore we store for each element its type. [INT, DOUBLE, STRING]
Load the XML state.
