17 #ifndef vtkSMStringVectorProperty_h 18 #define vtkSMStringVectorProperty_h 52 int SetElement(
unsigned int idx,
const char* value);
57 int SetElements(
const char* values[],
unsigned int count);
64 int SetElements(
const std::vector<std::string>& newvalue);
71 int SetUncheckedElements(
72 int SetUncheckedElements(
78 int AppendElements(
83 int AppendUncheckedElements(
94 const std::vector<std::string>& GetElements()
const;
95 const std::vector<std::string>& GetUncheckedElements()
const;
101 const char* GetElement(
unsigned int idx);
107 unsigned int GetElementIndex(
const char* value,
int& exists);
118 void SetElementType(
unsigned int idx,
int type);
119 int GetElementType(
unsigned int idx);
128 const char* GetUncheckedElement(
unsigned int idx);
135 void SetUncheckedElement(
unsigned int idx,
const char* value);
167 const char* GetDefaultValue(
int idx);
224 vtkInternals* Internals;
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
API for setting unchecked element values.
property representing a vector of strings
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
abstract superclass for all vector properties
static vtkSMProperty * New()
virtual unsigned int GetNumberOfUncheckedElements()=0
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
void ClearUncheckedElements() override=0
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
virtual bool IsValueDefault()
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
Manages allocation and freeing for a string list.
Class used to retrieve a given message state based on its GlobalID.
