vtkSMProxy.h
118 #ifndef vtkSMProxy_h
119 #define vtkSMProxy_h
120
121 #include "vtkClientServerID.h" // needed for vtkClientServerID
122 #include "vtkRemotingServerManagerModule.h" //needed for exports
123 #include "vtkSMRemoteObject.h"
124
125 struct vtkSMProxyInternals;
126
128 class vtkPVInformation;
129 class vtkSMLoadStateContext;
130 class vtkPVXMLElement;
131 class vtkSMDocumentation;
132 class vtkSMProperty;
133 class vtkSMPropertyGroup;
135 class vtkSMProxyLocator;
136 class vtkSMProxyManager;
138 class vtkSMProxyObserver;
139
141 {
142 public:
143  static vtkSMProxy* New();
145  void PrintSelf(ostream& os, vtkIndent indent) override;
146
147  // Description:
148  // Set or override a key/value pair as annotation to that proxy.
149  // If the value is nullptr, this method is equivalent to RemoveAnnotation(key)
150  void SetAnnotation(const char* key, const char* value);
151
156  const char* GetAnnotation(const char* key);
157
161  void RemoveAnnotation(const char* key);
162
166  void RemoveAllAnnotations();
167
171  bool HasAnnotation(const char* key);
172
176  int GetNumberOfAnnotations();
177
181  const char* GetAnnotationKeyAt(int index);
182
187  void SetLocation(vtkTypeUInt32) override;
188
193  virtual vtkSMProperty* GetProperty(const char* name)
194  {
195  return this->GetProperty(name, /*self-only*/ 0);
196  }
197
203  virtual vtkSMProperty* GetProperty(const char* name, int selfOnly);
204
212  const char* GetPropertyName(vtkSMProperty* prop);
213
219  virtual void UpdateVTKObjects();
220
226  virtual void RecreateVTKObjects();
227
229
235  bool UpdateProperty(const char* name) { return this->UpdateProperty(name, 0); }
236  bool UpdateProperty(const char* name, int force);
238
242  void InvokeCommand(const char* name) { this->UpdateProperty(name, 1); }
243
245
248  vtkGetStringMacro(VTKClassName);
250
252
257  vtkSetStringMacro(VTKClassName);
259
263  virtual vtkSMPropertyIterator* NewPropertyIterator();
264
270  unsigned int GetNumberOfConsumers();
271
277  vtkSMProxy* GetConsumerProxy(unsigned int idx);
278
284  vtkSMProperty* GetConsumerProperty(unsigned int idx);
285
290  unsigned int GetNumberOfProducers();
291
295  vtkSMProxy* GetProducerProxy(unsigned int idx);
296
302  vtkSMProperty* GetProducerProperty(unsigned int idx);
303
305
310  vtkGetStringMacro(XMLName);
312
314
319  vtkGetStringMacro(XMLGroup);
321
323
329  vtkGetStringMacro(XMLLabel);
331
336  virtual void UpdatePropertyInformation();
337
342  virtual void UpdatePropertyInformation(vtkSMProperty* prop);
343
351  virtual void MarkAllPropertiesAsModified();
352
359  virtual void ResetPropertiesToXMLDefaults();
360
367  virtual void ResetPropertiesToDomainDefaults();
368
370  {
371  DEFAULT = 0,
372  ONLY_XML = 1,
373  ONLY_DOMAIN = 2
374  };
375
385  virtual void ResetPropertiesToDefault(ResetPropertiesMode mode = DEFAULT);
386
390  enum
391  {
392  COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0,
393
394  COPY_PROXY_PROPERTY_VALUES_BY_CLONING // < No longer supported!!!
395  };
396
398
411  void Copy(vtkSMProxy* src);
412  void Copy(vtkSMProxy* src, const char* exceptionClass);
413  virtual void Copy(vtkSMProxy* src, const char* exceptionClass, int proxyPropertyCopyFlag);
415
419  virtual void MarkModified(vtkSMProxy* modifiedProxy);
420
422
425  vtkGetObjectMacro(Documentation, vtkSMDocumentation);
427
429
437  vtkGetObjectMacro(Hints, vtkPVXMLElement);
439
441
444  vtkGetMacro(ObjectsCreated, int);
446
450  bool IsDeprecated() { return this->Deprecated != nullptr; }
451
460  void InitializeAndCopyFromProxy(vtkSMProxy* source);
461
466  virtual void MarkDirty(vtkSMProxy* modifiedProxy);
467
472  vtkObjectBase* GetClientSideObject();
473
475
480  bool GatherInformation(vtkPVInformation* information);
481  bool GatherInformation(vtkPVInformation* information, vtkTypeUInt32 location);
483
492  virtual vtkPVXMLElement* SaveXMLState(vtkPVXMLElement* root);
496  virtual vtkPVXMLElement* SaveXMLState(vtkPVXMLElement* root, vtkSMPropertyIterator* iter);
497
505  virtual int LoadXMLState(vtkPVXMLElement* element, vtkSMProxyLocator* locator);
506
508
513  void PrototypeOn() override;
514  void PrototypeOff() override;
515  void SetPrototype(bool undo) override;
517
523  void UpdateSelfAndAllInputs();
524
529  bool GetIsSubProxy();
530
535  vtkSMProxy* GetParentProxy();
536
542  vtkSMProxy* GetTrueParentProxy();
543
551  void EnableLocalPushOnly() override;
552
557  void DisableLocalPushOnly() override;
558
563  const vtkSMMessage* GetFullState() override;
564
572  void LoadState(const vtkSMMessage* msg, vtkSMProxyLocator* locator) override;
573
577  vtkSMPropertyGroup* GetPropertyGroup(size_t index) const;
578
582  size_t GetNumberOfPropertyGroups() const;
583
585
600  void SetLogName(const char* name);
601  vtkGetStringMacro(LogName);
603
607  const char* GetLogNameOrDefault();
608
609  bool GetPropertiesModified() { return this->PropertiesModified; }
610
614  virtual std::vector<std::string> GetPropertiesWithDifferentValues(vtkSMProxy* otherProxy);
615
616 protected:
617  vtkSMProxy();
618  ~vtkSMProxy() override;
619
623  void ExecuteStream(
624  const vtkClientServerStream& msg, bool ignore_errors = false, vtkTypeUInt32 location = 0);
625
626  // Any method changing the annotations will trigger this method that will
627  // update the local full state as well as sending the annotation state part
628  // to the session.
629  virtual void UpdateAndPushAnnotationState();
630
632
635  virtual const vtkClientServerStream& GetLastResult();
636  virtual const vtkClientServerStream& GetLastResult(vtkTypeUInt32 location);
638
645  virtual void AddProperty(const char* name, vtkSMProperty* prop);
646
650  virtual void MarkConsumersAsDirty(vtkSMProxy* modifiedProxy);
651
660  virtual void MarkDirtyFromProducer(
661  vtkSMProxy* modifiedProxy, vtkSMProxy* producer, vtkSMProperty* property);
662
673  void MarkInputsAsDirty();
674
676
682  friend class vtkSMCameraLink;
683  friend class vtkSMCompoundProxy;
686  friend class vtkSMInputProperty;
691  friend class vtkSMProperty;
692  friend class vtkSMPropertyIterator;
693  friend class vtkSMProxyObserver;
694  friend class vtkSMProxyProperty;
695  friend class vtkSMProxyRegisterUndoElement;
696  friend class vtkSMProxyUnRegisterUndoElement;
698  friend class vtkSMSourceProxy;
699  friend class vtkSMStateLoader;
700  friend class vtkSMStateLocator;
701  friend class vtkSMUndoRedoStateLoader;
702  friend class vtkSMViewProxy;
704
706
711  vtkSetStringMacro(XMLName);
713
715
720  vtkSetStringMacro(XMLGroup);
722
724
730  vtkSetStringMacro(XMLLabel);
732
734
741  vtkSetStringMacro(XMLSubProxyName);
743
749  virtual void CreateVTKObjects();
750
756  void RemoveAllObservers();
757
779  virtual void SetPropertyModifiedFlag(const char* name, int flag);
780
786  void AddSubProxy(const char* name, vtkSMProxy* proxy, int overrideOK = 0);
787
791  void RemoveSubProxy(const char* name);
792
796  vtkSMProxy* GetSubProxy(const char* name);
797
801  vtkSMProxy* GetSubProxy(unsigned int index);
802
807  const char* GetSubProxyName(unsigned int index);
808
813  const char* GetSubProxyName(vtkSMProxy*);
814
818  unsigned int GetNumberOfSubProxies();
819
824  virtual void AddConsumer(vtkSMProperty* property, vtkSMProxy* proxy);
825
829  virtual void RemoveConsumer(vtkSMProperty* property, vtkSMProxy* proxy);
830
834  virtual void RemoveAllConsumers();
835
840  void AddProducer(vtkSMProperty* property, vtkSMProxy* proxy);
841
845  void RemoveProducer(vtkSMProperty* property, vtkSMProxy* proxy);
846
856  virtual void PostUpdateData(bool using_cache);
857
862  void PostUpdateDataSelfOnly(bool using_cache);
863
867  bool WarnIfDeprecated();
868
872  bool LoadPluginIfEnsured();
873
879  virtual void UpdatePipelineInformation();
880
881  // When an algorithm proxy is marked modified, NeedsUpdate is
882  // set to true. In PostUpdateData(), NeedsUpdate is set to false.
883  // This is used to keep track of data information validity.
885
887
891  vtkSMProperty* NewProperty(const char* name);
892  vtkSMProperty* NewProperty(const char* name, vtkPVXMLElement* propElement);
894
899  void LinkProperty(vtkSMProperty* inputProperty, vtkSMProperty* outputProperty);
900
907
912
914
918  void SetupExposedProperties(const char* subproxy_name, vtkPVXMLElement* element);
919  void SetupSharedProperties(vtkSMProxy* subproxy, vtkPVXMLElement* element);
921
929  void ExposeSubProxyProperty(const char* subproxy_name, const char* property_name,
930  const char* exposed_name, int overrideOK = 0);
931
935  virtual void ExecuteSubProxyEvent(vtkSMProxy* o, unsigned long event, void* data);
936
938
945  virtual void UpdatePropertyInformationInternal(vtkSMProperty* prop = nullptr);
946
956
960  virtual void SetLogNameInternal(
961  const char* name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains);
962
964
967  vtkSetStringMacro(SIClassName);
968  vtkGetStringMacro(SIClassName);
969  char* SIClassName;
971
973  char* XMLGroup;
974  char* XMLName;
975  char* XMLLabel;
980
987
993
997  bool ArePropertiesModified();
998
999  void SetHints(vtkPVXMLElement* hints);
1000  void SetDeprecated(vtkPVXMLElement* deprecated);
1001
1006  void SetEnsurePluginLoaded(vtkPVXMLElement* ensurePluginLoaded);
1007
1008  void SetXMLElement(vtkPVXMLElement* element);
1010
1015
1016  // Cached version of State
1018
1019  // Flag used to break consumer loops.
1021
1023
1026  vtkSMProxy(const vtkSMProxy&) = delete;
1027  void operator=(const vtkSMProxy&) = delete;
1028
1029 private:
1030  vtkSMProperty* SetupExposedProperty(vtkPVXMLElement* propertyElement, const char* subproxy_name);
1031
1032  friend class vtkSMProxyInfo;
1033
1034  char* LogName;
1035  std::string DefaultLogName;
1036 };
1037
1052 {
1053 public:
1055  : SIOBJECT(proxy)
1056  {
1057  }
1058 };
1059
1075 {
1076  vtkSMProxy* Reference;
1078  vtkClientServerStream& stream, const VTKOBJECT& manipulator);
1079
1080 public:
1082  : Reference(proxy)
1083  {
1084  }
1085 };
1087  vtkClientServerStream& stream, const VTKOBJECT& manipulator);
1088
1089 #endif
This method is called after the algorithm(s) (if any) associated with this proxy execute.
bool UpdateProperty(const char *name)
Update the value of one property (pushed to the server) if it is modified.
Definition: vtkSMProxy.h:235
This defines a stream manipulator for the vtkClientServerStream that can be used to indicate to the i...
Definition: vtkSMProxy.h:1074
vtkSMProperty * NewProperty(const char *name)
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element...
virtual void RemoveConsumer(vtkSMProperty *property, vtkSMProxy *proxy)
Remove the property,proxy pair from the list of consumers.
virtual int CreateSubProxiesAndProperties(vtkSMSessionProxyManager *pm, vtkPVXMLElement *element)
iterates over a subset of a proxy&#39;s properties
location
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them...
void CreateVTKObjects() override
Called at the end of CreateVTKObjects().
virtual void PrototypeOff()
Allow user to set the remote object to be discard for Undo/Redo action.
void AppendPropertyGroup(vtkSMPropertyGroup *group)
Adds a property groups.
virtual void AddConsumer(vtkSMProperty *property, vtkSMProxy *proxy)
Called by a proxy property, this adds the property,proxy pair to the list of consumers.
vtkSMProxy * GetSubProxy(const char *name)
Returns a sub-proxy.
property representing pointer(s) to vtkObject(s)
void ExposeSubProxyProperty(const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0)
Expose a subproxy property from the base proxy.
VTKOBJECT(vtkSMProxy *proxy)
Definition: vtkSMProxy.h:1081
virtual void LoadState(const vtkSMMessage *msg, vtkSMProxyLocator *locator)
This method is used to initialise the object to the given state If the definitionOnly Flag is set to ...
void SetupSharedProperties(vtkSMProxy *subproxy, vtkPVXMLElement *element)
Read attributes from an XML element.
virtual void PrototypeOn()
virtual void EnableLocalPushOnly()
Allow to switch off any push of state change to the server for that particular object.
virtual void SetLocation(vtkTypeUInt32)
Get/Set the location where the underlying VTK-objects are created.
Superclass for all view proxies.
Definition: vtkSMProxy.h:1051
Definition: vtkSMProxy.h:609
vtkPVXMLElement * EnsurePluginLoaded
Definition: vtkSMProxy.h:1014
char * XMLGroup
Definition: vtkSMProxy.h:973
virtual void SetPropertyModifiedFlag(const char *name, int flag)
Note on property modified flags: The modified flag of each property associated with a proxy is stored...
iterates over the properties of a proxy
void RemoveProducer(vtkSMProperty *property, vtkSMProxy *proxy)
Remove the property,proxy pair from the list of producers.
Store messages for the interpreter.
Indicates if any properties are modified.
void AddSubProxy(const char *name, vtkSMProxy *proxy, int overrideOK=0)
Add a sub-proxy.
bool IsDeprecated()
Returns true if the proxy has a deprecation tag.
Definition: vtkSMProxy.h:450
singleton/facade to vtkSMSessionProxyManager
char * XMLSubProxyName
Definition: vtkSMProxy.h:976
int InMarkModified
Definition: vtkSMProxy.h:1020
SIPROXY(vtkSMProxy *proxy)
Definition: vtkSMProxy.h:1054
If a proxy is deprecated, prints a warning.
int DoNotUpdateImmediately
Definition: vtkSMProxy.h:978
name
int ReadXMLAttributes(vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override
vtkSMMessage * State
Definition: vtkSMProxy.h:1017
vtkSMDocumentation * Documentation
Definition: vtkSMProxy.h:1011
virtual void SetLogNameInternal(const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains)
Internal method used by SetLogName
void RebuildStateForProperties()
vtkSMProxy tracks state of properties on this proxy in an internal State object.
This defines a manipulator for the vtkClientServerStream that can be used to indicate to the interpre...
virtual void DisableLocalPushOnly()
Enable the given remote object to communicate its state normally to the server location.
If a proxy need to ensure a plugin is loaded, make sure it is.
int ObjectsCreated
Definition: vtkSMProxy.h:977
void AddProducer(vtkSMProperty *property, vtkSMProxy *proxy)
Called by an proxy/input property to add property, proxy pair to the list of producers.
VTKREMOTINGSERVERMANAGER_EXPORT vtkClientServerStream & operator<<(vtkClientServerStream &stream, const VTKOBJECT &manipulator)
Preselection enables the user to inspect cells/points without actually selecting them.
proxy for a VTK source on a server
virtual void UpdatePropertyInformationInternal(vtkSMProperty *prop=nullptr)
Called to update the property information on the property.
void LinkProperty(vtkSMProperty *inputProperty, vtkSMProperty *outputProperty)
Links properties such that when inputProperty&#39;s checked or unchecked values are changed, the outputProperty&#39;s corresponding values are also changed.
void SetDeprecated(vtkPVXMLElement *deprecated)
vtkWeakPointer< vtkSMProxy > ParentProxy
Definition: vtkSMProxy.h:1022
deserializes proxies from their Protobuf states.
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
char * XMLName
Definition: vtkSMProxy.h:974
source
void SetupExposedProperties(const char *subproxy_name, vtkPVXMLElement *element)
const char * GetSubProxyName(unsigned int index)
Returns the name used to store sub-proxy.
a proxy excapsulation a pipeline of proxies.
Definition: vtkSMProxy.h:140
int InUpdateVTKObjects
Avoids calls to UpdateVTKObjects in UpdateVTKObjects.
Definition: vtkSMProxy.h:986
void InvokeCommand(const char *name)
Convenience method equivalent to UpdateProperty(name, 1).
Definition: vtkSMProxy.h:242
virtual const vtkSMMessage * GetFullState()
This method return the full object state that can be used to create that object from scratch...
vtkSMProxyObserver * SubProxyObserver
Definition: vtkSMProxy.h:1025
bool NeedsUpdate
Definition: vtkSMProxy.h:884
int DoNotModifyProperty
Definition: vtkSMProxy.h:979
virtual void ExecuteSubProxyEvent(vtkSMProxy *o, unsigned long event, void *data)
Handle events fired by subproxies.
class providing access to the documentation for a vtkSMProxy.
virtual vtkSMProperty * GetProperty(const char *name)
Return the property with the given name.
Definition: vtkSMProxy.h:193
void SetEnsurePluginLoaded(vtkPVXMLElement *ensurePluginLoaded)
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured.
vtkPVXMLElement * XMLElement
Definition: vtkSMProxy.h:1009
vtkSMProxyInternals * Internals
Definition: vtkSMProxy.h:1024
char * VTKClassName
Definition: vtkSMProxy.h:972
Remove all consumers.
Utility class to load state from XML.
baseclass for all proxy-objects that have counter parts on server as well as client processes...
void SetXMLElement(vtkPVXMLElement *element)
index
virtual void SetPrototype(bool)
Returns the number of sub-proxies.
static vtkSMSessionObject * New()
These classes have been declared as friends to minimize the public interface exposed by vtkSMProxy...
Definition: vtkSMProxy.h:693
void SetHints(vtkPVXMLElement *hints)
bool PropertiesModified
Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls.
Definition: vtkSMProxy.h:992
Superclass for information objects.
char * XMLLabel
Definition: vtkSMProxy.h:975
void RemoveSubProxy(const char *name)
Remove a sub-proxy.
proxy representing inputs to a filter
vtkPVXMLElement * Deprecated
Definition: vtkSMProxy.h:1013
Class used to retrieve a given message state based on its GlobalID.
char * SIClassName
SIClassName identifies the classname for the helper on the server side.
Definition: vtkSMProxy.h:968
This is called by PostUpdateData to only update state for this proxy without iterative over producers...
vtkSMPropertyGroup * NewPropertyGroup(vtkPVXMLElement *propElement)
Parses the XML to create a new property group.
vtkPVXMLElement * Hints
Definition: vtkSMProxy.h:1012
