baseclass for all proxy-objects that have counter parts on server as well as client processes. More...
#include <vtkSMRemoteObject.h>
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
virtual const vtkSMMessage * | GetFullState () |
This method return the full object state that can be used to create that object from scratch. More... | |
virtual void | EnableLocalPushOnly () |
Allow to switch off any push of state change to the server for that particular object. More... | |
virtual void | DisableLocalPushOnly () |
Enable the given remote object to communicate its state normally to the server location. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
virtual void | SetLocation (vtkTypeUInt32) |
Get/Set the location where the underlying VTK-objects are created. More... | |
Get the global unique id for this object. More... | |
virtual void | PrototypeOn () |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
virtual void | PrototypeOff () |
bool | IsPrototype () |
virtual void | SetPrototype (bool) |
virtual void | LoadState (const vtkSMMessage *msg, vtkSMProxyLocator *locator) |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
virtual void | Modified () |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSMStateHelper |
class | vtkSMStateLoader |
Abstract class involved in ServerManager class hierarchy that has a corresponding SIObject which can be local or remote.
Definition at line 25 of file vtkSMRemoteObject.h.
Definition at line 32 of file vtkSMRemoteObject.h.
Destructor.
Reimplemented from vtkSMSessionObject.
Reimplemented in vtkSMProxy, vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMCollaborationManager, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMLoadStateOptionsProxy, vtkSMOutputPort, vtkSMPVRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMDataDeliveryManagerProxy, vtkSMPipelineState, vtkSMProxySelectionModel, vtkSMRenderViewProxy, vtkSMSaveAnimationProxy, vtkSMImporterProxy, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMProxyDefinitionManager, vtkSMProxyLink, vtkSMComparativeViewProxy, vtkSMLink, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMViewLink, vtkSMPythonViewProxy, vtkSMVRInteractorStyleProxy, vtkSMVRStylusStyleProxy, vtkSMExtractTriggerProxy, vtkSMCameraLink, vtkSMComparativeAnimationCueProxy, vtkSMVRPythonInteractorStyleProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMDataSourceProxy, vtkSMPropertyLink, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMVRMovePointStyleProxy, vtkSMMultiServerSourceProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRSpaceNavigatorGrabWorldStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRVirtualHandStyleProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMContextItemWidgetProxy, vtkSMMaterialLibraryProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMAnimationSceneProxy, vtkSMEnsembleDataReaderProxy, vtkSMDataExtractWriterProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMNullProxy, vtkSMTimeKeeperProxy, vtkSMVRControlSlicePositionStyleProxy, vtkSMOrthographicSliceViewProxy, and vtkSMVRControlSliceOrientationStyleProxy.
Reimplemented in vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMPVRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMDataDeliveryManagerProxy, vtkSMRenderViewProxy, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMComparativeViewProxy, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMViewLink, vtkSMPythonViewProxy, vtkSMCameraLink, vtkSMComparativeAnimationCueProxy, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMContextItemWidgetProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMTimeKeeperProxy, and vtkSMOrthographicSliceViewProxy.
The value can be constructed by or-ing vtkSMSession::ServerFlags
Reimplemented in vtkSMProxy.
If none is set and the session is valid, a new global id will be assigned automatically.
Reimplemented in vtkSMSourceProxy, vtkSMRepresentationProxy, and vtkSMCollaborationManager.
const char* vtkSMRemoteObject::GetGlobalIDAsString | ( | ) |
bool vtkSMRemoteObject::HasGlobalID | ( | ) |
By default, any remote object is Undoable.
Definition at line 71 of file vtkSMRemoteObject.h.
inlinevirtual |
This method will be used to fill the undo stack. If not overridden this will return nullptr.
Reimplemented in vtkSMProxy, vtkSMCollaborationManager, vtkSMProxySelectionModel, vtkSMLink, and vtkSMPipelineState.
Definition at line 81 of file vtkSMRemoteObject.h.
inlinevirtual |
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMProxy, vtkSMViewLayoutProxy, vtkSMProxyDefinitionManager, vtkSMCollaborationManager, vtkSMMultiplexerSourceProxy, vtkSMProxySelectionModel, vtkSMProxyLink, vtkSMPropertyLink, vtkSMLink, vtkSMCameraLink, vtkSMSelectionLink, vtkSMLiveInsituLinkProxy, vtkSMMultiServerSourceProxy, and vtkSMPipelineState.
Definition at line 91 of file vtkSMRemoteObject.h.
This is used when we load a state based on a server notification. In that particular case, the server is already aware of that new state, so we keep those changes local.
inlinevirtual |
Definition at line 117 of file vtkSMRemoteObject.h.
Returns true on successful fetch. The message is updated with the fetched state.
friend |
Definition at line 28 of file vtkSMRemoteObject.h.
friend |
Definition at line 29 of file vtkSMRemoteObject.h.
Definition at line 153 of file vtkSMRemoteObject.h.
Definition at line 157 of file vtkSMRemoteObject.h.
Definition at line 161 of file vtkSMRemoteObject.h.
Definition at line 164 of file vtkSMRemoteObject.h.
