vtkSMNewWidgetRepresentationProxy Class Reference
proxy for 3D widgets and their representations in ParaView. More...
#include <vtkSMNewWidgetRepresentationProxy.h>
Inheritance diagram for vtkSMNewWidgetRepresentationProxy:
Collaboration diagram for vtkSMNewWidgetRepresentationProxy:
typedef vtkSMNewWidgetRepresentationProxyAbstract Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxyAbstract
typedef vtkSMProxy Superclass
virtual vtkAbstractWidgetGetWidget ()
 Get the widget for the representation. More...
virtual vtkSMProxyGetRepresentationProxy ()
 Get Representation Proxy. More...
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
bool LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup)
 Called to link properties from a Widget to controlledProxy i.e. More...
bool UnlinkProperties (vtkSMProxy *controlledProxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMNewWidgetRepresentationProxyNew ()
static vtkSMNewWidgetRepresentationProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
static vtkSMNewWidgetRepresentationProxyAbstractSafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMNewWidgetRepresentationProxy ()
 ~vtkSMNewWidgetRepresentationProxy () override
 Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More...
void ExecuteEvent (unsigned long event) override
 Called every time the user interacts with the widget. More...
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
 vtkSMNewWidgetRepresentationProxyAbstract ()
 ~vtkSMNewWidgetRepresentationProxyAbstract () override
void ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event)
 Called everytime a controlled property's unchecked values change. More...
void SetupPropertiesLinks ()
 Setup all links between properties and informations. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyRepresentationProxy = nullptr
vtkSMProxyWidgetProxy = nullptr
vtkAbstractWidgetWidget = nullptr
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxyAbstract
vtkNew< vtkSMWidgetObserverObserver
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMNewWidgetRepresentationProxy is a proxy for 3D widgets and their representations. It has several responsibilities.
Definition at line 25 of file vtkSMNewWidgetRepresentationProxy.h.
Definition at line 30 of file vtkSMNewWidgetRepresentationProxy.h.
◆ vtkSMNewWidgetRepresentationProxy()
vtkSMNewWidgetRepresentationProxy::vtkSMNewWidgetRepresentationProxy ( )
◆ ~vtkSMNewWidgetRepresentationProxy()
vtkSMNewWidgetRepresentationProxy::~vtkSMNewWidgetRepresentationProxy ( )
static vtkSMNewWidgetRepresentationProxy* vtkSMNewWidgetRepresentationProxy::New ( )
virtual const char* vtkSMNewWidgetRepresentationProxy::GetClassName ( )
static int vtkSMNewWidgetRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMNewWidgetRepresentationProxy::IsA ( const char *  type)
static vtkSMNewWidgetRepresentationProxy* vtkSMNewWidgetRepresentationProxy::SafeDownCast ( vtkObject o)
void vtkSMNewWidgetRepresentationProxy::PrintSelf ( ostream &  os,
◆ GetWidget()
virtual vtkAbstractWidget* vtkSMNewWidgetRepresentationProxy::GetWidget ( )
◆ GetRepresentationProxy()
virtual vtkSMProxy* vtkSMNewWidgetRepresentationProxy::GetRepresentationProxy ( )
◆ CreateVTKObjects()
void vtkSMNewWidgetRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Reimplemented in vtkSMScalarBarWidgetRepresentationProxy, and vtkSMTextWidgetRepresentationProxy.
◆ ExecuteEvent()
void vtkSMNewWidgetRepresentationProxy::ExecuteEvent ( unsigned long  event)
Implements vtkSMNewWidgetRepresentationProxyAbstract.
Reimplemented in vtkSMScalarBarWidgetRepresentationProxy.
◆ RepresentationProxy
vtkSMProxy* vtkSMNewWidgetRepresentationProxy::RepresentationProxy = nullptr
Definition at line 57 of file vtkSMNewWidgetRepresentationProxy.h.
◆ WidgetProxy
vtkSMProxy* vtkSMNewWidgetRepresentationProxy::WidgetProxy = nullptr
Definition at line 58 of file vtkSMNewWidgetRepresentationProxy.h.
◆ Widget
vtkAbstractWidget* vtkSMNewWidgetRepresentationProxy::Widget = nullptr
Definition at line 59 of file vtkSMNewWidgetRepresentationProxy.h.
