is the representation corresponding to a scalar bar or color legend in a Render View. More...
#include <vtkSMScalarBarWidgetRepresentationProxy.h>
typedef vtkSMNewWidgetRepresentationProxy | Superclass |
typedef vtkSMNewWidgetRepresentationProxyAbstract | Superclass |
typedef vtkSMProxy | Superclass |
enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
typedef vtkSMRemoteObject | Superclass |
void | ClearRange () |
Clears all data held by the scalar bar concerning range. More... | |
void | AddRange (vtkSMRepresentationProxy *proxy) |
Add range to current scalar bar for a given representation proxy. More... | |
void | AddBlockRange (vtkSMRepresentationProxy *proxy, const std::string &blockSelector) |
void | RemoveRange (vtkSMRepresentationProxy *proxy) |
Remove range to current scalar bar for a given representation proxy. More... | |
void | RemoveBlockRange (vtkSMRepresentationProxy *proxy, const std::string &blockSelector) |
void | GetRange (double range[2], int component) |
Get the current range of the scalar bar. More... | |
void | GetRange (double range[2]) |
virtual vtkAbstractWidget * | GetWidget () |
Get the widget for the representation. More... | |
virtual vtkSMProxy * | GetRepresentationProxy () |
Get Representation Proxy. More... | |
bool | LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup) |
Called to link properties from a Widget to controlledProxy i.e. More... | |
bool | UnlinkProperties (vtkSMProxy *controlledProxy) |
Retrieve an annotation with a given key. More... | |
Remove a given annotation based on its key to the proxy. More... | |
Remove all proxy annotations. More... | |
Return true if a given annotation exists. More... | |
Return the number of available annotations. More... | |
Return the nth key of the available annotations. More... | |
Get/Set the location where the underlying VTK-objects are created. More... | |
Return the property with the given name. More... | |
Return a property of the given name from self or one of the sub-proxies. More... | |
Given a property pointer, returns the name that was used to add it to the proxy. More... | |
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
Recreate the VTK object for this proxy. More... | |
Convenience method equivalent to UpdateProperty(name, 1). More... | |
Returns a new (initialized) iterator of the properties. More... | |
Returns the number of consumers. More... | |
Returns the consumer of given index. More... | |
Returns the corresponding property of the consumer of given index. More... | |
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
Returns a proxy this proxy depends on, given index. More... | |
Returns the property holding a producer proxy given an index. More... | |
Updates all property information by calling UpdateInformation() and populating the values. More... | |
Similar to UpdatePropertyInformation() but updates only the given property. More... | |
Marks all properties as modified. More... | |
Use this method to set all properties on this proxy to their default values. More... | |
Use this method to set all properties on this proxy to their default domains. More... | |
Use this method to set all properties on this proxy to their default domain or values. More... | |
Calls MarkDirty() and invokes ModifiedEvent. More... | |
bool | IsDeprecated () |
Returns true if the proxy has a deprecation tag. More... | |
Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
Dirty means this algorithm will execute during next update. More... | |
Returns the client side object associated with the VTKObjectID (if any). More... | |
Saves the state of the proxy. More... | |
The iterator is use to filter the property available on the given proxy. More... | |
Loads the proxy state from the XML element. More... | |
This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
bool | GetIsSubProxy () |
A proxy instance can be a sub-proxy for some other proxy. More... | |
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
Allow to switch off any push of state change to the server for that particular object. More... | |
Enable the given remote object to communicate its state normally to the server location. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Returns the number of property groups that the proxy contains. More... | |
A helper that makes up an default name if none is provided. More... | |
Return the property names that have values different from the otherProxy argument. More... | |
Update the value of one property (pushed to the server) if it is modified. More... | |
Returns the type of object managed by the proxy. More... | |
the type of object created by the proxy. More... | |
Copies values of all the properties and sub-proxies from src. More... | |
Returns the documentation for this proxy. More... | |
Returns if the VTK objects for this proxy have been created. More... | |
Gathers information about this proxy. More... | |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
Log name is a name for this proxy that will be used when logging status messages. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
Get the global unique id for this object. More... | |
bool | IsPrototype () |
virtual void | Modified () |
vtkSMScalarBarWidgetRepresentationProxy () | |
~vtkSMScalarBarWidgetRepresentationProxy () override | |
void | CreateVTKObjects () override |
Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More... | |
void | ExecuteEvent (unsigned long event) override |
Called every time the user interacts with the widget. More... | |
vtkSMNewWidgetRepresentationProxy () | |
~vtkSMNewWidgetRepresentationProxy () override | |
vtkSMNewWidgetRepresentationProxyAbstract () | |
~vtkSMNewWidgetRepresentationProxyAbstract () override | |
void | ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event) |
Called everytime a controlled property's unchecked values change. More... | |
void | SetupPropertiesLinks () |
Setup all links between properties and informations. More... | |
vtkSMProxy () | |
~vtkSMProxy () override | |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
Invoke that takes a vtkClientServerStream as the argument. More... | |
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
Add a property with the given key (name). More... | |
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
void | MarkInputsAsDirty () |
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
Cleanup code. More... | |
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
Add a sub-proxy. More... | |
void | RemoveSubProxy (const char *name) |
Remove a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (const char *name) |
Returns a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
Returns the number of sub-proxies. More... | |
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of consumers. More... | |
virtual void | RemoveAllConsumers () |
Remove all consumers. More... | |
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of producers. More... | |
virtual void | PostUpdateData (bool using_cache) |
This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
void | PostUpdateDataSelfOnly (bool using_cache) |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
bool | WarnIfDeprecated () |
If a proxy is deprecated, prints a warning. More... | |
bool | LoadPluginIfEnsured () |
If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
virtual void | UpdatePipelineInformation () |
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
Parses the XML to create a new property group. More... | |
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
Adds a property groups. More... | |
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
Expose a subproxy property from the base proxy. More... | |
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
Handle events fired by subproxies. More... | |
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
Called to update the property information on the property. More... | |
void | RebuildStateForProperties () |
vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
Internal method used by SetLogName More... | |
bool | ArePropertiesModified () |
Indicates if any properties are modified. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
void | SetXMLElement (vtkPVXMLElement *element) |
vtkSMProxy (const vtkSMProxy &)=delete | |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
Get the last result. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
virtual int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
Read attributes from an XML element. More... | |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
SIClassName identifies the classname for the helper on the server side. More... | |
virtual char * | GetSIClassName () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSMProxy * | ActorProxy |
std::unordered_map< vtkSMRepresentationProxy *, vtkWeakPointer< vtkSMRepresentationProxy > > | Proxies |
Storing a list of proxies linked to this scalar bar. More... | |
std::map< std::pair< vtkSMRepresentationProxy *, std::string >, vtkWeakPointer< vtkSMRepresentationProxy > > | BlockProxies |
vtkSMProxy * | RepresentationProxy = nullptr |
vtkSMProxy * | WidgetProxy = nullptr |
vtkAbstractWidget * | Widget = nullptr |
vtkNew< vtkSMWidgetObserver > | Observer |
bool | NeedsUpdate |
char * | VTKClassName |
char * | XMLGroup |
char * | XMLName |
char * | XMLLabel |
char * | XMLSubProxyName |
int | ObjectsCreated |
int | DoNotUpdateImmediately |
int | DoNotModifyProperty |
int | InUpdateVTKObjects |
Avoids calls to UpdateVTKObjects in UpdateVTKObjects. More... | |
bool | PropertiesModified |
Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls. More... | |
vtkPVXMLElement * | XMLElement |
vtkSMDocumentation * | Documentation |
vtkPVXMLElement * | Hints = nullptr |
vtkPVXMLElement * | Deprecated = nullptr |
vtkPVXMLElement * | EnsurePluginLoaded = nullptr |
vtkSMMessage * | State |
int | InMarkModified |
vtkWeakPointer< vtkSMProxy > | ParentProxy |
vtkSMProxyInternals * | Internals |
vtkSMProxyObserver * | SubProxyObserver |
char * | SIClassName |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
static bool | UpdateComponentTitle (vtkSMProxy *proxy, vtkPVArrayInformation *dataInfo) |
Updates the scalar bar's component title using the data information to determine component names if possible. More... | |
virtual bool | UpdateComponentTitle (vtkPVArrayInformation *dataInfo) |
static bool | PlaceInView (vtkSMProxy *proxy, vtkSMProxy *view) |
Attempt to place the scalar bar in the view based on the placement of other currently shown and visible scalar bars. More... | |
virtual bool | PlaceInView (vtkSMProxy *view) |
Definition at line 25 of file vtkSMScalarBarWidgetRepresentationProxy.h.
Definition at line 30 of file vtkSMScalarBarWidgetRepresentationProxy.h.
Reimplemented from vtkSMNewWidgetRepresentationProxy.
inlinestatic |
Definition at line 39 of file vtkSMScalarBarWidgetRepresentationProxy.h.
inlinestatic |
Definition at line 53 of file vtkSMScalarBarWidgetRepresentationProxy.h.
void vtkSMScalarBarWidgetRepresentationProxy::AddRange | ( | vtkSMRepresentationProxy * | proxy | ) |
This allows to display the combined range of multiple data sets that hold the same array.
void vtkSMScalarBarWidgetRepresentationProxy::AddBlockRange | ( | vtkSMRepresentationProxy * | proxy, |
const std::string & | blockSelector | ||
void vtkSMScalarBarWidgetRepresentationProxy::RemoveRange | ( | vtkSMRepresentationProxy * | proxy | ) |
void vtkSMScalarBarWidgetRepresentationProxy::RemoveBlockRange | ( | vtkSMRepresentationProxy * | proxy, |
Definition at line 86 of file vtkSMScalarBarWidgetRepresentationProxy.h.
void vtkSMScalarBarWidgetRepresentationProxy::ClearRange | ( | ) |
overrideprotectedvirtual |
Definition at line 109 of file vtkSMScalarBarWidgetRepresentationProxy.h.
vtkSMRepresentation*
per item, as the proxy can become unused before this class is aware of it. The weak pointer helps not interfere with the life span of this proxy, and the raw pointer is used as key because of its constness: the weak pointer can become nullptr
and would invalidate the container is used as key. Definition at line 121 of file vtkSMScalarBarWidgetRepresentationProxy.h.
and would invalidate the container is used as key. Definition at line 124 of file vtkSMScalarBarWidgetRepresentationProxy.h.
