virtual void | SetProxy (vtkSMProxy *proxy) |
| Set the proxy to be used. More...
virtual void | Begin () |
| Go to the first property. More...
virtual int | IsAtEnd () |
| Returns true if iterator points past the end of the collection. More...
virtual void | Next () |
| Move to the next property. More...
virtual const char * | GetKey () |
| Returns the key (name) at the current iterator position. More...
virtual const char * | GetPropertyLabel () |
| Returns the XMLLabel for self properties and the exposed name for sub-proxy properties. More...
virtual vtkSMProperty * | GetProperty () |
| Returns the property at the current iterator position. More...
virtual vtkSMProxy * | GetProxy () |
| Return the proxy. More...
virtual void | SetTraverseSubProxies (int) |
| If TraverseSubProxies is false, only the properties belonging to the root proxy are returned. More...
virtual int | GetTraverseSubProxies () |
virtual void | Modified () |
iterates over the properties of a proxy
vtkSMPropertyIterator is used to iterate over the properties of a proxy. The properties of the root proxies as well as sub-proxies are included in the iteration. For sub-proxies, only exposed properties are iterated over.
Definition at line 24 of file vtkSMPropertyIterator.h.
