void | Begin () override |
| Go to the first property. More...
int | IsAtEnd () override |
| Returns true if iterator points past the end of the collection. More...
void | Next () override |
| Move to the next property. More...
const char * | GetKey () override |
| Returns the key (name) at the current iterator position. More...
const char * | GetPropertyLabel () override |
| Returns the XMLLabel for self properties and the exposed name for sub-proxy properties. More...
vtkSMProperty * | GetProperty () override |
| Returns the property at the current iterator position. More...
void | SetPropertyNames (vtkStringList *names) |
| Set the names of properties to iterate over. More...
void | SetPropertyNames (const std::vector< std::string > &names) |
virtual void | SetProxy (vtkSMProxy *proxy) |
| Set the proxy to be used. More...
virtual vtkSMProxy * | GetProxy () |
| Return the proxy. More...
virtual void | SetTraverseSubProxies (int) |
| If TraverseSubProxies is false, only the properties belonging to the root proxy are returned. More...
virtual int | GetTraverseSubProxies () |
virtual void | Modified () |
