superclass for any server manager classes that are related to a session More...
#include <vtkSMSessionObject.h>
class | vtkScopedMonitorProgress |
Helper class designed to call session->PrepareProgress() in constructor and session->CleanupPendingProgress() in destructor. More... | |
virtual void | Modified () |
static vtkObject * | New () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMSessionObject provides methods to set and get the relative session
Definition at line 21 of file vtkSMSessionObject.h.
Definition at line 25 of file vtkSMSessionObject.h.
Reimplemented in vtkSMProxy, vtkSMSessionProxyManager, vtkSMMultiplexerSourceProxy, vtkSMDataAssemblyDomain, vtkSMArrayListDomain, vtkSMCompositeTreeDomain, vtkSMRepresentationProxy, vtkSMEnumerationDomain, vtkSMInputArrayDomain, vtkSMBoundsDomain, vtkSMSettingsProxy, vtkSMFieldDataDomain, vtkSMDataTypeDomain, vtkSMRangeDomainTemplate< T >, vtkSMRegistrationNamesDomain, vtkSMViewProxy, vtkSMCollaborationManager, vtkSMChartSeriesSelectionDomain, vtkSMProxyListDomain, vtkSMDataTypeQueryDomain, vtkSMViewLayoutProxy, vtkSMDomain, vtkSMSourceProxy, vtkSMLoadStateOptionsProxy, vtkSMOutputPort, vtkSMPVRepresentationProxy, vtkSMChartSeriesListDomain, vtkSMDataAssemblyListDomain, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMStringListDomain, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMDoubleRangeDomain, vtkSMFileUtilities, vtkSMRangedTransferFunctionDomain, vtkSMDimensionsDomain, vtkSMIntRangeDomain, vtkSMDataDeliveryManagerProxy, vtkSMPipelineState, vtkSMProxyGroupDomain, vtkSMProxySelectionModel, vtkSMRemoteObject, vtkSMArraySelectionDomain, vtkSMRenderViewProxy, vtkSMRepresentationTypeDomain, vtkSMSaveAnimationProxy, vtkSMImporterProxy, vtkSMDiscreteDoubleDomain, vtkSMChartUseIndexForAxisDomain, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMRepresentedArrayListDomain, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMNumberOfComponentsDomain, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMAMRLevelsDomain, vtkSMFixedTypeDomain, vtkSMProxyDefinitionManager, vtkSMProxyLink, vtkSMComparativeViewProxy, vtkSMMaterialDomain, vtkSMArrayRangeDomain, vtkSMExtentDomain, vtkSMLink, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMViewLink, vtkSMPythonViewProxy, vtkSMVRInteractorStyleProxy, vtkSMVRStylusStyleProxy, vtkSMAnimationSceneGeometryWriter, vtkSMAnimationSceneWebWriter, vtkSMExtractTriggerProxy, vtkSMInputFileNameDomain, vtkSMTimeStepIndexDomain, vtkSMCameraLink, vtkSMComparativeAnimationCueProxy, vtkSMVRPythonInteractorStyleProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMBooleanDomain, vtkSMDataSourceProxy, vtkSMPropertyLink, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMVRMovePointStyleProxy, vtkSMAnimationSceneWriter, vtkSMMultiServerSourceProxy, vtkSMTimeStepsDomain, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRSpaceNavigatorGrabWorldStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRVirtualHandStyleProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMContextItemWidgetProxy, vtkSMMaterialLibraryProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMAnimationFrameWindowDomain, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMMultiplexerInputDomain, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMViewResolutionDomain, vtkSMAnimationSceneProxy, vtkSMEnsembleDataReaderProxy, vtkSMDataExtractWriterProxy, vtkSMIndexSelectionDomain, vtkSMSelectionQueryDomain, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMFileListDomain, vtkSMNullProxy, vtkSMTimeKeeperProxy, vtkSMRendererDomain, vtkSMVRControlSlicePositionStyleProxy, vtkSMOrthographicSliceViewProxy, and vtkSMVRControlSliceOrientationStyleProxy.
Reimplemented in vtkSMSessionProxyManager, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMChartSeriesSelectionDomain, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMPVRepresentationProxy, vtkSMChartSeriesListDomain, vtkSMPVMoleculeRepresentationProxy, vtkSMStringListDomain, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMRangedTransferFunctionDomain, vtkSMDataDeliveryManagerProxy, vtkSMRenderViewProxy, vtkSMRepresentationTypeDomain, vtkSMChartUseIndexForAxisDomain, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMRepresentedArrayListDomain, vtkSMScalarBarWidgetRepresentationProxy, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMComparativeViewProxy, vtkSMMaterialDomain, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMViewLink, vtkSMPythonViewProxy, vtkSMTimeStepIndexDomain, vtkSMCameraLink, vtkSMComparativeAnimationCueProxy, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMContextItemWidgetProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMViewResolutionDomain, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMTimeKeeperProxy, vtkSMRendererDomain, and vtkSMOrthographicSliceViewProxy.
Note that session is not reference counted.
Reimplemented in vtkSMCollaborationManager, vtkSMRemoteObject, vtkSMProxyDefinitionManager, and vtkSMProxySelectionModel.
Reimplemented in vtkSMOutputPort.
Definition at line 49 of file vtkSMSessionObject.h.
