int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
virtual int | IsInDomain (vtkSMSourceProxy *oldProxy, vtkSMSourceProxy *newProxy) |
| Returns true if old and new source proxies have the same output data type, false otherwise. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void | Update (vtkSMProperty *requestingProperty) |
| Update self based on the "unchecked" values of all required properties. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMFixedTypeDomain () |
| ~vtkSMFixedTypeDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
restricts the proxy to have the same type as previous proxy
vtkSMFixedTypeDomain is used by input properties of filters that can not have different input types after input is set the first time. For example, a sub-class vtkDataSetToDataSetFilter, once connected in a pipeline can not change it's input type, say, from vtkImageData to vtkUnstructuredGrid because it's output can not change.
- See also
- vtkSMDomain
Definition at line 24 of file vtkSMFixedTypeDomain.h.
