vtkSMTransferFunctionProxy is the proxy used for "PVLookupTable", "ColorTransferFunction" and "PiecewiseFunction". More...
#include <vtkSMTransferFunctionProxy.h>
typedef vtkSMProxy | Superclass |
enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
typedef vtkSMRemoteObject | Superclass |
virtual bool | RescaleTransferFunction (const double range[2], bool extend=false) |
Rescale the "RGBPoints" for the transfer function to match the new range. More... | |
virtual bool | RescaleTransferFunction (double rangeMin, double rangeMax, bool extend=false) |
virtual bool | InvertTransferFunction () |
Invert the transfer function. More... | |
virtual bool | MapControlPointsToLogSpace (bool inverse=false) |
Remaps control points by normalizing in linear-space and then interpolating in log-space. More... | |
virtual bool | MapControlPointsToLinearSpace () |
virtual bool | ApplyPreset (const char *presetname, bool rescale=true) |
virtual bool | SaveColorMap (vtkPVXMLElement *xml) |
Save to ColorMap XML. More... | |
virtual bool | IsScalarBarVisible (vtkSMProxy *view) |
Return true if the representation corresponding to the transfer function for the view is showing a Scalar-Bar (Color Legend). More... | |
virtual vtkSMProxy * | FindScalarBarRepresentation (vtkSMProxy *view) |
Find and return the Scalar-Bar (Color Legend) representation corresponding to the transfer function for the view, if any. More... | |
virtual bool | ComputeAvailableAnnotations (bool extend=false) |
virtual bool | ApplyColorMap (const char *text) |
Load a ColorMap XML. More... | |
virtual bool | ApplyColorMap (vtkPVXMLElement *xml) |
Retrieve an annotation with a given key. More... | |
Remove a given annotation based on its key to the proxy. More... | |
Remove all proxy annotations. More... | |
Return true if a given annotation exists. More... | |
Return the number of available annotations. More... | |
Return the nth key of the available annotations. More... | |
Get/Set the location where the underlying VTK-objects are created. More... | |
Return the property with the given name. More... | |
Return a property of the given name from self or one of the sub-proxies. More... | |
Given a property pointer, returns the name that was used to add it to the proxy. More... | |
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
Recreate the VTK object for this proxy. More... | |
Convenience method equivalent to UpdateProperty(name, 1). More... | |
Returns a new (initialized) iterator of the properties. More... | |
Returns the number of consumers. More... | |
Returns the consumer of given index. More... | |
Returns the corresponding property of the consumer of given index. More... | |
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
Returns a proxy this proxy depends on, given index. More... | |
Returns the property holding a producer proxy given an index. More... | |
Updates all property information by calling UpdateInformation() and populating the values. More... | |
Similar to UpdatePropertyInformation() but updates only the given property. More... | |
Marks all properties as modified. More... | |
Use this method to set all properties on this proxy to their default values. More... | |
Use this method to set all properties on this proxy to their default domains. More... | |
Use this method to set all properties on this proxy to their default domain or values. More... | |
Calls MarkDirty() and invokes ModifiedEvent. More... | |
bool | IsDeprecated () |
Returns true if the proxy has a deprecation tag. More... | |
Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
Dirty means this algorithm will execute during next update. More... | |
Returns the client side object associated with the VTKObjectID (if any). More... | |
Saves the state of the proxy. More... | |
The iterator is use to filter the property available on the given proxy. More... | |
Loads the proxy state from the XML element. More... | |
This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
bool | GetIsSubProxy () |
A proxy instance can be a sub-proxy for some other proxy. More... | |
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
Allow to switch off any push of state change to the server for that particular object. More... | |
Enable the given remote object to communicate its state normally to the server location. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Returns the number of property groups that the proxy contains. More... | |
A helper that makes up an default name if none is provided. More... | |
Return the property names that have values different from the otherProxy argument. More... | |
Update the value of one property (pushed to the server) if it is modified. More... | |
Returns the type of object managed by the proxy. More... | |
the type of object created by the proxy. More... | |
Copies values of all the properties and sub-proxies from src. More... | |
Returns the documentation for this proxy. More... | |
Returns if the VTK objects for this proxy have been created. More... | |
Gathers information about this proxy. More... | |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
Log name is a name for this proxy that will be used when logging status messages. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
Get the global unique id for this object. More... | |
bool | IsPrototype () |
virtual void | Modified () |
static vtkSMTransferFunctionProxy * | New () |
static vtkSMTransferFunctionProxy * | SafeDownCast (vtkObject *o) |
static bool | InvertTransferFunction (vtkSMProxy *) |
Safely call InvertTransferFunction() after casting the proxy to the appropriate type. More... | |
static bool | MapControlPointsToLinearSpace (vtkSMProxy *proxy) |
Safely call MapControlPointsToLinearSpace() after casting the proxy to the appropriate type. More... | |
static bool | ApplyPreset (vtkSMProxy *proxy, const char *presetname, bool rescale=true) |
static bool | ComputeAvailableAnnotations (vtkSMProxy *proxy, bool extend=false) |
static bool | ConvertLegacyColorMapsToJSON (const char *inxmlfile, const char *outjsonfile) |
Converts legacy xml file to json. More... | |
static bool | ExportTransferFunction (vtkSMTransferFunctionProxy *colorTransferFunction, vtkSMTransferFunctionProxy *opacityTransferFunction, const char *tfname, const char *filename, vtkTypeUInt32 location=0x10) |
Export a transfer function to a json file. More... | |
static bool | RescaleTransferFunction (vtkSMProxy *proxy, double rangeMin, double rangeMax, bool extend=false) |
Safely call RescaleTransferFunction() after casting the proxy to appropriate type. More... | |
static bool | RescaleTransferFunction (vtkSMProxy *proxy, const double range[2], bool extend=false) |
static bool | MapControlPointsToLogSpace (vtkSMProxy *proxy, bool inverse=false) |
Safely call MapControlPointsToLogSpace() after casting the proxy to the appropriate type. More... | |
static bool | ApplyColorMap (vtkSMProxy *proxy, const char *text) |
Safely call ApplyColorMap(..) after casting the proxy to the appropriate type. More... | |
static bool | ApplyColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
static bool | SaveColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
static bool | IsScalarBarVisible (vtkSMProxy *proxy, vtkSMProxy *view) |
Safely call IsScalarBarVisible(..) after casting the proxy to the appropriate type. More... | |
static vtkSMProxy * | FindScalarBarRepresentation (vtkSMProxy *proxy, vtkSMProxy *view) |
Safely call FindScalarBarRepresentation(..) after casting the proxy to the appropriate type. More... | |
static Json::Value | ConvertLegacyColorMapXMLToJSON (vtkPVXMLElement *xml) |
Method to convert legacy color map preset XML to JSON. More... | |
static Json::Value | ConvertLegacyColorMapXMLToJSON (const char *xmlcontents) |
static Json::Value | ConvertMultipleLegacyColorMapXMLToJSON (vtkPVXMLElement *xml) |
Method to convert legacy "ColorMaps" preset XML to JSON. More... | |
static Json::Value | ConvertMultipleLegacyColorMapXMLToJSON (const char *xmlcontents) |
static Json::Value | ConvertVisItColorMapXMLToJSON (vtkPVXMLElement *xml) |
Method to convert VisIt color map preset XML to JSON. More... | |
static Json::Value | ConvertVisItColorMapXMLToJSON (const char *xmlcontents) |
static vtkSMProxy * | New () |
static vtkSMProxy * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMTransferFunctionProxy ()=default | |
~vtkSMTransferFunctionProxy () override=default | |
void | RestoreFromSiteSettingsOrXML (const char *arrayName) |
Attempt to reset transfer function to site settings. More... | |
vtkSMProxy () | |
~vtkSMProxy () override | |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
Invoke that takes a vtkClientServerStream as the argument. More... | |
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
Add a property with the given key (name). More... | |
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
void | MarkInputsAsDirty () |
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
virtual void | CreateVTKObjects () |
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
Cleanup code. More... | |
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
Add a sub-proxy. More... | |
void | RemoveSubProxy (const char *name) |
Remove a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (const char *name) |
Returns a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
Returns the number of sub-proxies. More... | |
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of consumers. More... | |
virtual void | RemoveAllConsumers () |
Remove all consumers. More... | |
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of producers. More... | |
virtual void | PostUpdateData (bool using_cache) |
This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
void | PostUpdateDataSelfOnly (bool using_cache) |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
bool | WarnIfDeprecated () |
If a proxy is deprecated, prints a warning. More... | |
bool | LoadPluginIfEnsured () |
If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
virtual void | UpdatePipelineInformation () |
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
Parses the XML to create a new property group. More... | |
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
Adds a property groups. More... | |
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
Expose a subproxy property from the base proxy. More... | |
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
Handle events fired by subproxies. More... | |
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
Called to update the property information on the property. More... | |
void | RebuildStateForProperties () |
vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
Internal method used by SetLogName More... | |
bool | ArePropertiesModified () |
Indicates if any properties are modified. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
void | SetXMLElement (vtkPVXMLElement *element) |
vtkSMProxy (const vtkSMProxy &)=delete | |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
Get the last result. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
virtual int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
Read attributes from an XML element. More... | |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
SIClassName identifies the classname for the helper on the server side. More... | |
virtual char * | GetSIClassName () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
double | LastRange [2] = { 0, 1 } |
vtkSmartPointer< vtkTable > | HistogramTableCache |
bool | NeedsUpdate |
char * | VTKClassName |
char * | XMLGroup |
char * | XMLName |
char * | XMLLabel |
char * | XMLSubProxyName |
int | ObjectsCreated |
int | DoNotUpdateImmediately |
int | DoNotModifyProperty |
int | InUpdateVTKObjects |
Avoids calls to UpdateVTKObjects in UpdateVTKObjects. More... | |
bool | PropertiesModified |
Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls. More... | |
vtkPVXMLElement * | XMLElement |
vtkSMDocumentation * | Documentation |
vtkPVXMLElement * | Hints = nullptr |
vtkPVXMLElement * | Deprecated = nullptr |
vtkPVXMLElement * | EnsurePluginLoaded = nullptr |
vtkSMMessage * | State |
int | InMarkModified |
vtkWeakPointer< vtkSMProxy > | ParentProxy |
vtkSMProxyInternals * | Internals |
vtkSMProxyObserver * | SubProxyObserver |
char * | SIClassName |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false) |
Locates all representations that are currently using this transfer function and then rescales the transfer function scalar range to exactly match the combined valid scalar ranges obtained from them all. More... | |
virtual bool | RescaleTransferFunctionToDataRange (bool extend=false) |
static bool | ApplyPreset (vtkSMProxy *proxy, const Json::Value &value, bool rescale=true) |
Apply a preset. More... | |
virtual bool | ApplyPreset (const Json::Value &value, bool rescale=true) |
static Json::Value | GetStateAsPreset (vtkSMProxy *proxy) |
Saves the transfer function state as a preset. More... | |
virtual Json::Value | GetStateAsPreset () |
static bool | UpdateScalarBarsComponentTitle (vtkSMProxy *proxy, vtkPVArrayInformation *arrayInfo) |
Update component titles for all scalar bars connected to this transfer function proxy. More... | |
virtual bool | UpdateScalarBarsComponentTitle (vtkPVArrayInformation *arrayInfo) |
static bool | ComputeDataRange (vtkSMProxy *proxy, double range[2]) |
Helper method used by RescaleTransferFunctionToDataRange() to compute range from all visible representations using the transfer function. More... | |
virtual bool | ComputeDataRange (double range[2]) |
static vtkTable * | ComputeDataHistogramTable (vtkSMProxy *proxy, int numberOfBins) |
Helper method used to compute a histogram with provided number of bins based on the data from all the visible representations using the transfer function. More... | |
virtual vtkTable * | ComputeDataHistogramTable (int numberOfBins) |
static vtkTable * | GetHistogramTableCache (vtkSMProxy *proxy) |
Helper method used to recover the last histogram computed by ComputeDataHistogram Returns the histogram as a vtkTable if available, nullptr otherwise. More... | |
virtual vtkTable * | GetHistogramTableCache () |
static void | ResetPropertiesToDefaults (vtkSMProxy *proxy, const char *arrayName, bool preserve_range=false) |
Helper method to reset a transfer function proxy to its defaults. More... | |
virtual void | ResetPropertiesToDefaults (const char *arrayName, bool preserve_range) |
static bool | GetRange (vtkSMProxy *proxy, double range[2]) |
Returns current transfer function data range. More... | |
virtual bool | GetRange (double range[2]) |
It provides utility API to update lookup-table ranges, invert transfer function, etc. that can be used from C++ as well as Python layers.
Definition at line 25 of file vtkSMTransferFunctionProxy.h.
Definition at line 29 of file vtkSMTransferFunctionProxy.h.
protecteddefault |
overrideprotecteddefault |
inlinevirtual |
Returns true if rescale was successful. If extend
is true (false by default), the transfer function range will only be extended as needed to fit the data range.
Definition at line 38 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 51 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 64 of file vtkSMTransferFunctionProxy.h.
Returns true if successful.
This is useful when converting the transfer function from linear- to log-mode. If inverse
is true, the operation is reversed i.e. the control points are normalized in log-space and interpolated in linear-space, useful when converting from log- to linear-mode.
inlinevirtual |
Definition at line 90 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 97 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 108 of file vtkSMTransferFunctionProxy.h.
Apply a preset.
If rescale
is true (default), then apply loading the preset, the transfer function range will be preserved (if originally valid). If not valid, or rescale
is false, then the range provided by the preset is used. When using indexed color maps, the rescale
implies loading of annotations since the "range" for indexed color maps is described by the annotations.
inlinestatic |
Apply a preset.
If rescale
Definition at line 123 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 131 of file vtkSMTransferFunctionProxy.h.
This is simply a subset of the state of the transfer function proxy.
This will update a transfer function using the ColorMap XML. Currently, this is only supported for color transfer functions. Returns true on success.
inlinestatic |
Definition at line 161 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 173 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 191 of file vtkSMTransferFunctionProxy.h.
Otherwise return false.
inlinestatic |
Definition at line 210 of file vtkSMTransferFunctionProxy.h.
This returns the proxy if one exists, it won't create a new one.
inlinestatic |
Definition at line 229 of file vtkSMTransferFunctionProxy.h.
The arrayInfo is used to determine component names, if possible.
inlinestatic |
Definition at line 243 of file vtkSMTransferFunctionProxy.h.
Returns true if a valid range was determined.
inlinestatic |
Definition at line 257 of file vtkSMTransferFunctionProxy.h.
If successful, returns the histogram as a vtkTable containing two columns of double, the first one being the indexes, the second one the number of values. If not, returns nullptr.
inlinestatic |
Definition at line 273 of file vtkSMTransferFunctionProxy.h.
inlinevirtual |
Definition at line 285 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 286 of file vtkSMTransferFunctionProxy.h.
inlinestatic |
Definition at line 296 of file vtkSMTransferFunctionProxy.h.
By passing in preserve_range, you can make this method preserve the current transfer function range.
inlinestatic |
Definition at line 309 of file vtkSMTransferFunctionProxy.h.
Use this to convert a single ColorMap xml. To convert a collection of color maps, use ConvertMultipleLegacyColorMapXMLToJSON().
This converts all colormaps in the XML.
Returns false is a valid range could not be determined.
inlinestatic |
Definition at line 359 of file vtkSMTransferFunctionProxy.h.
opacityTransferFunction can be nullptr but colorTransferFunction must not be nullptr. The tfname will be the preset name upon importing the transfer function back into ParaView.
If site settings are not available, then the application XML defaults are used.
Definition at line 389 of file vtkSMTransferFunctionProxy.h.
Definition at line 394 of file vtkSMTransferFunctionProxy.h.
