Proxy for a representations. More...
#include <vtkSMRepresentationProxy.h>
typedef vtkSMSourceProxy | Superclass |
enum | ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH } |
typedef vtkSMProxy | Superclass |
enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
typedef vtkSMRemoteObject | Superclass |
virtual vtkPVDataInformation * | GetRepresentedDataInformation () |
Returns information about the data that is finally rendered by this representation. More... | |
void | UpdatePipeline () override |
Calls Update() on all sources. More... | |
void | UpdatePipeline (double time) override |
Calls Update() on all sources with the given time request. More... | |
void | PostUpdateData (bool) override |
Overridden to reset this->MarkedModified flag. More... | |
virtual void | ViewUpdated (vtkSMProxy *view) |
Called after the view updates. More... | |
vtkTypeUInt32 | GetGlobalID () override |
Overridden to reserve additional IDs for use by internal composite representation. More... | |
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
Marks the selection proxies dirty as well as chain to superclass. More... | |
virtual vtkPVProminentValuesInformation * | GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
Returns information about a specific array component's prominent values (or nullptr). More... | |
virtual vtkPVProminentValuesInformation * | GetBlockProminentValuesInformation (std::string blockSelector, std::string assemblyName, std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
void | UpdatePipelineInformation () override |
Calls UpdateInformation() on all sources. More... | |
virtual unsigned int | GetNumberOfOutputPorts () |
Return the number of output ports. More... | |
virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
Return an output port. More... | |
virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
Return an output port, given the name for the port. More... | |
virtual unsigned int | GetOutputPortIndex (const char *portname) |
Returns the port index, given the name of an output port. More... | |
virtual const char * | GetOutputPortName (unsigned int index) |
Returns the output port name given its index. More... | |
virtual void | CreateOutputPorts () |
Creates the output port proxies for this filter. More... | |
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
A GetSubsetDataInformation overload that uses composite index. More... | |
virtual void | CreateSelectionProxies () |
Creates extract selection proxies for each output port if not already created. More... | |
void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
Set/Get the selection input. More... | |
void | CleanSelectionInputs (unsigned int portIndex) |
Clean all selection inputs for the given port. More... | |
vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
Returns the source proxy which provides the selected data from the given output port. More... | |
unsigned int | GetNumberOfAlgorithmOutputPorts () |
Returns the number of output ports provided by the algorithm. More... | |
virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
Returns the number of non-optional input ports required by the algorithm. More... | |
virtual int | GetOutputPortsCreated () |
Returns if the output port proxies have been created. More... | |
vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
It is possible to provide some documentation for each output port in the configuration xml. More... | |
vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
vtkPVDataInformation * | GetDataInformation () |
DataInformation is used by the source proxy to obtain information on the output(s) from the server. More... | |
vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
For composite datasets, GetDataInformation returns summary data information for all blocks combined. More... | |
vtkPVDataInformation * | GetRankDataInformation (int rank) |
Get rank-specific data information. More... | |
vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
API to query selection input set using SetSelectionInput. More... | |
unsigned int | GetSelectionInputPort (unsigned int portIndex) |
virtual int | GetProcessSupport () |
This returns information about whether the VTK algorithm supports multiple processes or not. More... | |
virtual bool | GetMPIRequired () |
This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More... | |
Retrieve an annotation with a given key. More... | |
Remove a given annotation based on its key to the proxy. More... | |
Remove all proxy annotations. More... | |
Return true if a given annotation exists. More... | |
Return the number of available annotations. More... | |
Return the nth key of the available annotations. More... | |
Get/Set the location where the underlying VTK-objects are created. More... | |
Return the property with the given name. More... | |
Return a property of the given name from self or one of the sub-proxies. More... | |
Given a property pointer, returns the name that was used to add it to the proxy. More... | |
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
Recreate the VTK object for this proxy. More... | |
Convenience method equivalent to UpdateProperty(name, 1). More... | |
Returns a new (initialized) iterator of the properties. More... | |
Returns the number of consumers. More... | |
Returns the consumer of given index. More... | |
Returns the corresponding property of the consumer of given index. More... | |
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
Returns a proxy this proxy depends on, given index. More... | |
Returns the property holding a producer proxy given an index. More... | |
Updates all property information by calling UpdateInformation() and populating the values. More... | |
Similar to UpdatePropertyInformation() but updates only the given property. More... | |
Marks all properties as modified. More... | |
Use this method to set all properties on this proxy to their default values. More... | |
Use this method to set all properties on this proxy to their default domains. More... | |
Use this method to set all properties on this proxy to their default domain or values. More... | |
Calls MarkDirty() and invokes ModifiedEvent. More... | |
bool | IsDeprecated () |
Returns true if the proxy has a deprecation tag. More... | |
Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
Returns the client side object associated with the VTKObjectID (if any). More... | |
Saves the state of the proxy. More... | |
The iterator is use to filter the property available on the given proxy. More... | |
This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
bool | GetIsSubProxy () |
A proxy instance can be a sub-proxy for some other proxy. More... | |
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
Allow to switch off any push of state change to the server for that particular object. More... | |
Enable the given remote object to communicate its state normally to the server location. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Returns the number of property groups that the proxy contains. More... | |
A helper that makes up an default name if none is provided. More... | |
Return the property names that have values different from the otherProxy argument. More... | |
Update the value of one property (pushed to the server) if it is modified. More... | |
Returns the type of object managed by the proxy. More... | |
the type of object created by the proxy. More... | |
Copies values of all the properties and sub-proxies from src. More... | |
Returns the documentation for this proxy. More... | |
Returns if the VTK objects for this proxy have been created. More... | |
Gathers information about this proxy. More... | |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
Log name is a name for this proxy that will be used when logging status messages. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
Get the global unique id for this object. More... | |
bool | IsPrototype () |
virtual void | Modified () |
static vtkSMRepresentationProxy * | New () |
static vtkSMRepresentationProxy * | SafeDownCast (vtkObject *o) |
static vtkSMSourceProxy * | New () |
static vtkSMSourceProxy * | SafeDownCast (vtkObject *o) |
static vtkSMProxy * | New () |
static vtkSMProxy * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMRepresentationProxy () | |
~vtkSMRepresentationProxy () override | |
void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override |
When the representation is being marked dirty due to a producer i.e. More... | |
void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override |
Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override |
Remove the property,proxy pair from the list of consumers. More... | |
void | RemoveAllConsumers () override |
Remove all consumers. More... | |
void | CreateVTKObjects () override |
Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More... | |
void | OnVTKRepresentationUpdated () |
void | OnVTKRepresentationUpdateSkipped () |
void | OnVTKRepresentationUpdateTimeChanged () |
virtual void | UpdatePipelineInternal (double time, bool doTime) |
void | InvalidateDataInformation () override |
Mark the data information as invalid. More... | |
int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
Overridden to restore this->Servers flag state. More... | |
vtkSMSourceProxy () | |
~vtkSMSourceProxy () override | |
virtual void | SetExecutiveName (const char *) |
int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
Read attributes from an XML element. More... | |
void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
Overridden to pass the logname to the internal ExtractSelection proxies. More... | |
void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
Method to set an output port at the given index. More... | |
void | RemoveAllOutputPorts () |
void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
void | RemoveAllExtractSelectionProxies () |
vtkSMProxy () | |
~vtkSMProxy () override | |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
Invoke that takes a vtkClientServerStream as the argument. More... | |
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
Add a property with the given key (name). More... | |
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
void | MarkInputsAsDirty () |
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
Cleanup code. More... | |
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
Add a sub-proxy. More... | |
void | RemoveSubProxy (const char *name) |
Remove a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (const char *name) |
Returns a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
Returns the number of sub-proxies. More... | |
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of producers. More... | |
void | PostUpdateDataSelfOnly (bool using_cache) |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
bool | WarnIfDeprecated () |
If a proxy is deprecated, prints a warning. More... | |
bool | LoadPluginIfEnsured () |
If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
Parses the XML to create a new property group. More... | |
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
Adds a property groups. More... | |
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
Expose a subproxy property from the base proxy. More... | |
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
Handle events fired by subproxies. More... | |
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
Called to update the property information on the property. More... | |
void | RebuildStateForProperties () |
vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
bool | ArePropertiesModified () |
Indicates if any properties are modified. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
void | SetXMLElement (vtkPVXMLElement *element) |
vtkSMProxy (const vtkSMProxy &)=delete | |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
Get the last result. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
SIClassName identifies the classname for the helper on the server side. More... | |
virtual char * | GetSIClassName () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Friends | |
class | vtkPVComparativeViewNS::vtkCloningVectorOfRepresentations |
static bool | SetRepresentationType (vtkSMProxy *repr, const char *type) |
Set the representation type. More... | |
static const char * | GetRepresentationType (vtkSMProxy *repr) |
virtual bool | SetRepresentationType (const char *type) |
const char * | GetRepresentationType () |
static bool | IsVolumeRendering (vtkSMProxy *repr) |
Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More... | |
static bool | GetUsing2DTransferFunction (vtkSMProxy *repr) |
bool | IsVolumeRendering () |
bool | GetUsing2DTransferFunction () |
vtkSMRepresentationProxy is a vtkSMSourceProxy subclass that is designed to be used either directly or as a superclass for "data" representations i.e. representation that have an input (as against proxies for annotations such as 3D widgets).
vtkSMProxy::MarkDirty
is a mechanism that ParaView uses to know on the client side (i.e. in the server-manager layer) when a pipeline on the server side is "dirty" or has potential to execute on an update causing things like data information to be invalidated. Simply speaking, when a property on a vtkSMProxy is modified and pushed (using vtkSMProxy::UpdateVTKObjects
or vtkSMProxy::UpdateProperty
), it calls this->MarkDirty(this)
. vtkSMProxy::MarkDirty
invokes vtkSMProxy::MarkConsumersAsDirty
which results in any consumers of this dirtied proxy also getting the notification. Consumers (and conversely producers) are setup via ProxyProperty and InputProperty connections. For standard data processing pipelines, this mechanism works quite well. Consider a filter proxy, say Clip
, which has an input set via a InputProperty and a implicit function set via a ProxyProperty. If either the input or the implicit function is modified, it is reasonable to expect the Clip filter to re-execute on an UpdatePipeline
call. Whether the call will truly cause the VTK pipeline (server side) to execute is not that important. The pipeline may not re-execute and that's not a big deal.
Things get a little complicated for representations, however. Data representations don't necessary have valid input connections on all processes where their VTK objects are present (note, representations create VTK objects on all process while data input is only available on the data server nodes). As a result representations have to be explicitly told to re-execute following upstream changes since they cannot rely on their VTK-level upstream. Re-executing a representation means regenerating the geometry or data artifacts for rendering, redelivering them to the rendering nodes, etc. It can also mean cleaning up any caches the representation built for flip-book animation support. In other words, re-executing a representation is non-trivial task. Thus, we want do it only when absolutely needed.
The explicit pipeline update is often referred to as "update suppression" and handled by vtkPVDataRepresentation
and vtkPVDataRepresentationPipeline
. In short, calling Update
on vtkPVDataRepresentation has no effect unless vtkPVDataRepresentation::MarkModified
was explicitly called at some point since the last Update
To explicitly call vtkPVDataRepresentation::MarkModified
for only those cases where the representation must be re-executed, we follow the following strategy.
this->MarkModified
when a public API that invalidates the data pipeline is invoked. vtkSMProxy::MarkDirtyFromProducer
to call MarkModified
on the VTK object if the producer was connected to the representation via a InputProperty and not a ProxyProperty. The assumption is that InputProperty connections typically imply pipeline connections while ProxyProperty connections are other supporting VTK objects e.g. LUT. Definition at line 78 of file vtkSMRepresentationProxy.h.
Definition at line 82 of file vtkSMRepresentationProxy.h.
Reimplemented from vtkSMSourceProxy.
Reimplemented in vtkSMPVRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMChartRepresentationProxy, and vtkSMSpreadSheetRepresentationProxy.
Reimplemented in vtkSMSpreadSheetRepresentationProxy.
The name, fieldAssoc, and numComponents arguments specify which arrays on the input dataset to examine. Because multiblock datasets may have multiple arrays of the same name on different blocks, and these arrays may not have the same storage type or number of components, this method requires you to specify the number of components per tuple the array(s) of interest must have. You may call GetRepresentedDataInformation() to obtain the number of components for any array.
See vtkAbstractArray::GetProminentComponentValues for more information about the uncertaintyAllowed and fraction arguments.
It also creates output ports if they are not already created.
Reimplemented in vtkSMPVRepresentationProxy.
Default implementation simply updates the "Representation" property, if present with the value provided. Subclasses can override this method to add custom logic to manage the representation state to support the change e.g. pick a scalar color array when switching to Volume or Slice representation, for example. Returns true, if the change was successful, otherwise returns false.
inlinestatic |
Definition at line 153 of file vtkSMRepresentationProxy.h.
const char* vtkSMRepresentationProxy::GetRepresentationType | ( | ) |
inlinestatic |
Definition at line 159 of file vtkSMRepresentationProxy.h.
inlinestatic |
Definition at line 171 of file vtkSMRepresentationProxy.h.
bool vtkSMRepresentationProxy::IsVolumeRendering | ( | ) |
inlinestatic |
Definition at line 177 of file vtkSMRepresentationProxy.h.
bool vtkSMRepresentationProxy::GetUsing2DTransferFunction | ( | ) |
overrideprotectedvirtual |
a proxy-property input-property connection, we need to decide if the representation's data pipeline is indeed invalidated or is this simply a "rendering" change. We override this method to make that distinction.
protectedvirtual |
friend |
Definition at line 243 of file vtkSMRepresentationProxy.h.
