const char * | GetPresetName (int preset) |
| Get the preset name. More...
const char * | GetPresetDisplayName (int preset) |
| Get a display name for the preset. More...
int | GetCurrentPreset () |
| Get the current preset value. More...
void | SetPreset (int preset) |
| Set Preset onto properties. More...
void | SetPreset (const char *name) |
bool | SetRepresentationType (const char *type) override |
| Overridden to ensure when picking representation types that require scalar colors, scalar coloring it setup properly. More...
bool | GetVolumeIndependentRanges () |
| True if ranges have to be computed independently on component 0 for the color and 1 for the opacity on the Volume representation. More...
void | ViewUpdated (vtkSMProxy *view) override |
| Called after the view updates. More...
void | SetLastLUTProxy (vtkSMProxy *proxy) |
| Set/get last LUT proxy. More...
void | SetLastLookupTable (vtkSMProxy *proxy) |
vtkSMProxy * | GetLastLUTProxy () |
vtkSMProxy * | GetLastLookupTable () |
void | SetLastBlockLookupTable (const std::string &blockSelector, vtkSMProxy *proxy) |
void | SetLastBlocksLookupTable (const std::vector< std::string > &blockSelectors, vtkSMProxy *proxy) |
vtkSMProxy * | GetLastBlockLookupTable (const std::string &blockSelector) |
std::vector< vtkSMProxy * > | GetLastBlocksLookupTables (const std::vector< std::string > &blockSelectors) |
virtual bool | GetUsingScalarColoring () |
| Returns true if scalar coloring is enabled. More...
virtual bool | GetBlockUsingScalarColoring (const std::string &blockSelector) |
virtual std::vector< vtkTypeBool > | GetBlocksUsingScalarColoring (const std::vector< std::string > &blockSelectors) |
virtual bool | GetAnyBlockUsingScalarColoring () |
vtkSMProxy * | GetLUTProxy (vtkSMProxy *view) |
| Returns the lut proxy of this representation in the given view. More...
vtkSMProxy * | GetLookupTable (vtkSMProxy *view) |
vtkSMProxy * | GetBlockLookupTable (vtkSMProxy *view, const std::string &blockSelector) |
std::vector< vtkSMProxy * > | GetBlocksLookupTables (vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
bool | UpdateScalarBarRange (vtkSMProxy *view, bool deleteRange) |
| Updates the ranges shown in the scalar bar. More...
std::vector< vtkTypeBool > | UpdateBlocksScalarBarRange (vtkSMProxy *view, bool deleteRange) |
virtual bool | SetScalarColoring (const char *arrayName, int attributeType) |
| Enable/disable scalar coloring using the specified array. More...
virtual bool | SetBlockScalarColoring (const std::string &blockSelector, const char *arrayName, int attributeType) |
virtual std::vector< vtkTypeBool > | SetBlocksScalarColoring (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType) |
virtual bool | SetScalarColoring (const char *arrayName, int attributeType, int component) |
virtual bool | SetBlockScalarColoring (const std::string &blockSelector, const char *arrayName, int attributeType, int component) |
virtual std::vector< vtkTypeBool > | SetBlocksScalarColoring (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, int component) |
virtual bool | RescaleTransferFunctionToDataRange (bool extend=false, bool force=true) |
| Rescales the color transfer function and opacity transfer function using the current data range. More...
virtual bool | RescaleBlockTransferFunctionToDataRange (const std::string &blockSelector, bool extend=false, bool force=true) |
virtual std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRange (const std::vector< std::string > &blockSelectors, bool extend=false, bool force=true) |
virtual bool | RescaleTransferFunctionToDataRange (const char *arrayName, int attributeType, bool extend=false, bool force=true) |
| Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
virtual bool | RescaleBlockTransferFunctionToDataRange (const std::string &blockSelector, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
virtual std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRange (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
virtual bool | RescaleTransferFunctionToDataRangeOverTime () |
| Rescales the color transfer function and opacity transfer function using the current data range over time. More...
virtual bool | RescaleBlockTransferFunctionToDataRangeOverTime (const std::string &blockSelector) |
virtual std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRangeOverTime (const std::vector< std::string > &blockSelectors) |
virtual bool | RescaleTransferFunctionToDataRangeOverTime (const char *arrayName, int attributeType) |
| Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
virtual bool | RescaleBlockTransferFunctionToDataRangeOverTime (const std::string &blockSelector, const char *arrayName, int attributeType) |
virtual std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRangeOverTime (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType) |
virtual bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *view) |
| Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
virtual bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *view, const char *arrayName, int attributeType) |
virtual bool | SetScalarBarVisibility (vtkSMProxy *view, bool visible) |
| Set the scalar bar visibility. More...
virtual bool | SetBlockScalarBarVisibility (vtkSMProxy *view, const std::string &blockSelector, bool visible) |
virtual std::vector< vtkTypeBool > | SetBlocksScalarBarVisibility (vtkSMProxy *view, const std::vector< std::string > &blockSelectors, bool visible) |
virtual bool | HideScalarBarIfNotNeeded (vtkSMProxy *view) |
| While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
virtual bool | HideBlocksScalarBarIfNotNeeded (vtkSMProxy *view) |
virtual bool | IsScalarBarVisible (vtkSMProxy *view) |
| Check scalar bar visibility. More...
virtual bool | IsBlockScalarBarVisible (vtkSMProxy *view, const std::string &blockSelector) |
virtual std::vector< vtkTypeBool > | IsBlocksScalarBarVisible (vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
virtual vtkPVArrayInformation * | GetArrayInformationForColorArray (bool checkRepresentedData=true) |
| Returns the array information for the data array used for scalar coloring, from input data. More...
virtual vtkPVArrayInformation * | GetBlockArrayInformationForColorArray (const std::string &blockSelector) |
virtual std::vector< vtkPVArrayInformation * > | GetBlocksArrayInformationForColorArray (const std::vector< std::string > &blockSelectors) |
virtual vtkPVProminentValuesInformation * | GetProminentValuesInformationForColorArray (double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
| Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
virtual vtkPVProminentValuesInformation * | GetBlockProminentValuesInformationForColorArray (const std::string &blockSelector, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
virtual std::vector< vtkPVProminentValuesInformation * > | GetBlocksProminentValuesInformationForColorArray (const std::vector< std::string > &blockSelectors, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
int | GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view) |
| Get an estimated number of annotation shown on this representation scalar bar. More...
int | GetBlockEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view, const std::string &blockSelector) |
std::vector< int > | GetBlocksEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
int | IsScalarBarStickyVisible (vtkSMProxy *view) |
| Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
int | IsBlockScalarBarStickyVisible (vtkSMProxy *view, const std::string &blockSelector) |
std::vector< int > | IsBlocksScalarBarStickyVisible (vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
std::pair< int, std::string > | GetBlockColorArray (const std::string &blockSelector) |
| Set/Get the block color array name. More...
std::vector< std::pair< int, std::string > > | GetBlocksColorArrays (const std::vector< std::string > &blockSelectors) |
int | GetBlockColorArrayAssociation (const std::string &blockSelector) |
std::string | GetBlockColorArrayName (const std::string &blockSelector) |
void | SetBlockUseSeparateColorMap (const std::string &blockSelector, bool use) |
| Set/Get if we should use a separate color map for this block. More...
void | SetBlocksUseSeparateColorMap (const std::vector< std::string > &blockSelectors, bool use) |
bool | GetBlockUseSeparateColorMap (const std::string &blockSelector) |
std::vector< vtkTypeBool > | GetBlocksUseSeparateColorMaps (const std::vector< std::string > &blockSelectors) |
virtual vtkPVDataInformation * | GetRepresentedDataInformation () |
| Returns information about the data that is finally rendered by this representation. More...
void | UpdatePipeline () override |
| Calls Update() on all sources. More...
void | UpdatePipeline (double time) override |
| Calls Update() on all sources with the given time request. More...
void | PostUpdateData (bool) override |
| Overridden to reset this->MarkedModified flag. More...
vtkTypeUInt32 | GetGlobalID () override |
| Overridden to reserve additional IDs for use by internal composite representation. More...
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Marks the selection proxies dirty as well as chain to superclass. More...
virtual vtkPVProminentValuesInformation * | GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
| Returns information about a specific array component's prominent values (or nullptr). More...
virtual vtkPVProminentValuesInformation * | GetBlockProminentValuesInformation (std::string blockSelector, std::string assemblyName, std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
const char * | GetRepresentationType () |
| Set the representation type. More...
bool | IsVolumeRendering () |
| Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
bool | GetUsing2DTransferFunction () |
void | UpdatePipelineInformation () override |
| Calls UpdateInformation() on all sources. More...
virtual unsigned int | GetNumberOfOutputPorts () |
| Return the number of output ports. More...
virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| Return an output port. More...
virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| Return an output port, given the name for the port. More...
virtual unsigned int | GetOutputPortIndex (const char *portname) |
| Returns the port index, given the name of an output port. More...
virtual const char * | GetOutputPortName (unsigned int index) |
| Returns the output port name given its index. More...
virtual void | CreateOutputPorts () |
| Creates the output port proxies for this filter. More...
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
| A GetSubsetDataInformation overload that uses composite index. More...
virtual void | CreateSelectionProxies () |
| Creates extract selection proxies for each output port if not already created. More...
void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| Set/Get the selection input. More...
void | CleanSelectionInputs (unsigned int portIndex) |
| Clean all selection inputs for the given port. More...
vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| Returns the source proxy which provides the selected data from the given output port. More...
unsigned int | GetNumberOfAlgorithmOutputPorts () |
| Returns the number of output ports provided by the algorithm. More...
virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| Returns the number of non-optional input ports required by the algorithm. More...
virtual int | GetOutputPortsCreated () |
| Returns if the output port proxies have been created. More...
vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
vtkPVDataInformation * | GetDataInformation () |
| DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
| For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * | GetRankDataInformation (int rank) |
| Get rank-specific data information. More...
vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| API to query selection input set using SetSelectionInput. More...
unsigned int | GetSelectionInputPort (unsigned int portIndex) |
virtual int | GetProcessSupport () |
| This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool | GetMPIRequired () |
| This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
