void | CreateVTKObjects () override |
| Overridden to pass a unique identifier to vtkSpreadSheetView. More...
void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) override |
| Overridden to update FieldAssociation property on the view to match the data type being shown. More...
virtual void | StillRender () |
| Renders the view using full resolution. More...
virtual void | InteractiveRender () |
| Renders the view using lower resolution is possible. More...
virtual void | Update () |
| Called vtkPVView::Update on the server-side. More...
virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *, int) |
| Create a default representation for the given source proxy. More...
virtual const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) |
| Returns the xml name of the representation proxy to create to show the data produced in this view, if any. More...
virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * | GetClientSideView () |
| Returns the client-side vtkView, if any. More...
int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| Saves a screenshot of the view to disk. More...
int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
virtual bool | HasDirtyRepresentation () |
| Return true any internal representation is dirty. More...
virtual vtkRenderWindow * | GetRenderWindow () |
| Return the vtkRenderWindow used by this view, if any. More...
virtual vtkRenderWindowInteractor * | GetInteractor () |
| Returns the interactor. More...
virtual void | SetupInteractor (vtkRenderWindowInteractor *iren) |
| A client process need to set the interactor to enable interactivity. More...
virtual bool | MakeRenderWindowInteractor (bool quiet=false) |
| Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void | SetEnable (bool) |
| Enable/Disable a view. More...
virtual bool | GetEnable () |
virtual void | EnableOn () |
virtual void | EnableOff () |
vtkImageData * | CaptureWindow (int magnification) |
| Captures a image from this view. More...
vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
virtual bool | GetNeedsUpdate () |
| Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
