void | SetViewProxy (vtkSMViewProxy *) |
| Get/Set the view proxy for whom we are delivering the data. More...
void | Deliver (bool interactive) |
| Called to request delivery of the geometry. More...
bool | DeliverStreamedPieces () |
| EXPERIMEMTAL: Delivery when streaming is enabled. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
