bool | LoadPlugin (const char *filename) |
| Loads the plugin. More...
bool | LoadPluginByName (const char *name, bool acceptDelayed=true) |
| Loads the plugin based on its name. More...
void | LoadPluginConfigurationXMLFromString (const char *xmlcontents) |
| Loads the configuration xml contents. More...
void | LoadPluginConfigurationXML (const char *configurationFile) |
| Loads a configuration xml file. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
