virtual bool | Write (vtkSMExtractsController *extractor)=0 |
| Generate the extract. More...
virtual bool | CanExtract (vtkSMProxy *proxy)=0 |
| Returns true if the provided proxy can be extracted/written by this writer. More...
virtual bool | IsExtracting (vtkSMProxy *proxy)=0 |
| Returns true this extract writer proxy is generating and extract from the provided proxy . More...
virtual void | SetInput (vtkSMProxy *proxy)=0 |
| This is convenience method that gets called by vtkSMExtractsController to set the extract writer to extract the given proxy. More...
virtual vtkSMProxy * | GetInput ()=0 |
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
