void | Import (vtkSMRenderViewProxy *renderView) |
| Imports scene from the file. More...
void | UpdatePipelineInformation () override |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More...
const std::vector< std::string > & | GetFileExtensions () const |
| Returns the suggested file extensions for this importer. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
