void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Set the property's default value based on the domain. More...
virtual void | SetDefaultValue (const char *) |
virtual int | GetDefaultMode () |
| Get the default-mode that controls how SetDefaultValues() behaves. More...
Public Member Functions inherited from vtkSMStringListDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More...
const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More...
unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More...
void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More...
virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More...
virtual void | SetNoneString (const char *) |
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMChartSeriesSelectionDomain () |
| ~vtkSMChartSeriesSelectionDomain () override |
vtkPVDataInformation * | GetInputInformation () |
| Returns the datainformation from the current input, if possible. More...
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Process any specific XML definition tags. More...
virtual bool | GetDefaultSeriesVisibility (const char *) |
| Returns the default visibility for a series given its name. More...
virtual std::vector< std::string > | GetDefaultValue (const char *series) |
| Get the default value that will be used for the series with the given name by this domain. More...
virtual void | PopulateAvailableArrays (const std::string &blockName, std::vector< std::string > &strings, vtkPVDataInformation *dataInfo, int fieldAssociation, bool flattenTable) |
| Build up the domain with available series names. More...
virtual void | PopulateArrayComponents (vtkChartRepresentation *chartRepr, const std::string &blockName, std::vector< std::string > &strings, std::set< std::string > &unique_strings, vtkPVArrayInformation *dataInfo, bool flattenTable) |
| Build up the domain with provided array. More...
virtual void | SetDefaultVisibilityOverride (const std::string &arrayname, bool visibility) |
| Call this method in PopulateAvailableArrays() to override a specific array's default visibility. More...
Protected Member Functions inherited from vtkSMStringListDomain |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | SetStrings (const std::vector< std::string > &strings) |
| Call to set the strings. More...
const std::vector< std::string > & | GetStrings () |
| vtkSMStringListDomain () |
| ~vtkSMStringListDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-parameter type properties such as SeriesVisibility, SeriesLabel, etc.
vtkSMChartSeriesSelectionDomain extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-parameter type properties such as SeriesVisibility, SeriesLabel, etc.
This domain also supports an experimental feature (we can generalize this to vtkSMDomain is found useful in other places). Generally, a vtkSMProperty never changes unless the application/user updates it. However for things like series parameters, it is useful if the property is updated to handle changed/newly added series consistently in the Qt application and the Python. To support that, this domain resets the property value to default every time the domain changes preserving status for existing series i.e. it won't affect the state for any series that already set on the property. Thus, it's not a true "reset", but more like "update".
Supported XML attributes
- hide_partial_arrays : when set to 1, partial arrays will not be shown in the domain (default).
Definition at line 41 of file vtkSMChartSeriesSelectionDomain.h.
