list of strings corresponding to the names of the arrays in the required input dataset that can be used as a series in a chart.
void | Update (vtkSMProperty *) override |
| Update self checking the "unchecked" values of all required properties. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Set the default values for the property. More...
Public Member Functions inherited from vtkSMStringListDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (const char *string, unsigned int &idx) |
| Returns true if the string is in the domain. More...
const char * | GetString (unsigned int idx) |
| Returns a string in the domain. More...
unsigned int | GetNumberOfStrings () |
| Returns the number of strings in the domain. More...
void | SetAnimationValue (vtkSMProperty *, int, double) override |
| Set the value of an element of a property from the animation editor. More...
virtual char * | GetNoneString () |
| Return the string that is used as "none_string" in XML configuration. More...
virtual void | SetNoneString (const char *) |
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMChartSeriesListDomain () |
| ~vtkSMChartSeriesListDomain () override |
vtkPVDataInformation * | GetInputInformation () |
| Returns the datainformation from the current input, if possible. More...
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| Set the appropriate ivars from the xml element. More...
virtual void | PopulateArrayComponents (vtkPVArrayInformation *, std::vector< std::string > &) |
Protected Member Functions inherited from vtkSMStringListDomain |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | SetStrings (const std::vector< std::string > &strings) |
| Call to set the strings. More...
const std::vector< std::string > & | GetStrings () |
| vtkSMStringListDomain () |
| ~vtkSMStringListDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
vtkSMChartSeriesListDomain is designed to be used for the X-axis array name property on chart representations. This is similar to vtkSMArrayListDomain, however, it simplifies the logic that is uses to determine the available arrays and at the same time, uses custom logic to pick the default array for based on priorities for arrays.
Supported Required-Property functions:
Input
: (required) refers to a property that provides the data-producer.
FieldDataSelection
: (required) refers to a field-selection property used to select the data-association i.e. cell-data, point-data etc.
Supported XML attributes
- hide_partial_arrays : when set to 1, partial arrays will not be shown in the domain (default).
Definition at line 34 of file vtkSMChartSeriesListDomain.h.
