void | Update (vtkSMProperty *) override |
| Overridden to setup domain range values based on required properties supported by this domain. More...
Public Member Functions inherited from vtkSMIntRangeDomain |
virtual int | GetMinimum (unsigned int idx, int &exists) |
| Return a min. More...
virtual int | GetMaximum (unsigned int idx, int &exists) |
| Return a max. More...
virtual int | GetMinimumExists (unsigned int idx) |
| Returns if minimum/maximum bound is set for the domain. More...
virtual int | GetMaximumExists (unsigned int idx) |
virtual int | GetMinimum (unsigned int idx) |
| Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual int | GetMaximum (unsigned int idx) |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual void | Modified () |
| vtkSMAnimationFrameWindowDomain () |
| ~vtkSMAnimationFrameWindowDomain () override |
Protected Member Functions inherited from vtkSMIntRangeDomain |
| vtkSMIntRangeDomain () |
| ~vtkSMIntRangeDomain () override |
| vtkSMDomain () |
| ~vtkSMDomain () override |
| Load the state of the domain from the XML. More...
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Set the appropriate ivars from the xml element. More...
| Remove the given property from the required properties list. More...
| Add a new required property to this domain. More...
void | DomainModified () |
| Invokes DomainModifiedEvent. More...
void | InvokeModified () |
| Gets the number of required properties added. More...
| Set the domain's property. More...
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
domain for animation frame window.
vtkSMAnimationFrameWindowDomain is used on the "FrameWindow" property on the "SaveAnimation" proxy. It's a int-range, where the range is determined using the animation scene's play mode and frame rate.
Definition at line 18 of file vtkSMAnimationFrameWindowDomain.h.
