void | UpdateVTKObjects () override |
void | UpdatePipelineInformation () override |
| Calls UpdateInformation() on all sources. More...
virtual void | UpdatePipeline () |
| Calls Update() on all sources. More...
virtual void | UpdatePipeline (double time) |
| Calls Update() on all sources with the given time request. More...
virtual unsigned int | GetNumberOfOutputPorts () |
| Return the number of output ports. More...
virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| Return an output port. More...
virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| Return an output port, given the name for the port. More...
virtual unsigned int | GetOutputPortIndex (const char *portname) |
| Returns the port index, given the name of an output port. More...
virtual const char * | GetOutputPortName (unsigned int index) |
| Returns the output port name given its index. More...
virtual void | CreateOutputPorts () |
| Creates the output port proxies for this filter. More...
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
| A GetSubsetDataInformation overload that uses composite index. More...
virtual void | CreateSelectionProxies () |
| Creates extract selection proxies for each output port if not already created. More...
void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| Set/Get the selection input. More...
void | CleanSelectionInputs (unsigned int portIndex) |
| Clean all selection inputs for the given port. More...
vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| Returns the source proxy which provides the selected data from the given output port. More...
unsigned int | GetNumberOfAlgorithmOutputPorts () |
| Returns the number of output ports provided by the algorithm. More...
virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 | GetGlobalID () override |
| Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Marks the selection proxies dirty as well as chain to superclass. More...
virtual int | GetOutputPortsCreated () |
| Returns if the output port proxies have been created. More...
vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
vtkPVDataInformation * | GetDataInformation () |
| DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
| For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * | GetRankDataInformation (int rank) |
| Get rank-specific data information. More...
vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| API to query selection input set using SetSelectionInput. More...
unsigned int | GetSelectionInputPort (unsigned int portIndex) |
virtual int | GetProcessSupport () |
| This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool | GetMPIRequired () |
| This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
