| This method is used to initialise the object to the given state. More...
void | ValidateState () |
bool | HasGlobalID () |
virtual void | EnableLocalPushOnly () |
virtual void | DisableLocalPushOnly () |
virtual void | SetLocation (vtkTypeUInt32) |
virtual void | PrototypeOn () |
virtual void | PrototypeOff () |
bool | IsPrototype () |
virtual void | SetPrototype (bool) |
virtual void | Modified () |
