#include <vtkSMVRInteractorStyleProxy.h>
enum | { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 } |
typedef vtkSMProxy | Superclass |
enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
typedef vtkSMRemoteObject | Superclass |
virtual int | GetControlledPropertySize () |
virtual void | SetControlledProxy (vtkSMProxy *) |
virtual vtkSMProxy * | GetControlledProxy () |
virtual void | SetControlledPropertyName (const char *) |
virtual char * | GetControlledPropertyName () |
virtual bool | HandleEvent (const vtkVREvent &event) |
virtual bool | Update () |
Update() called to update all the remote vtkObjects and perhaps even to render. More... | |
void | GetValuatorRoles (vtkStringList *) |
void | GetButtonRoles (vtkStringList *) |
void | GetTrackerRoles (vtkStringList *) |
int | GetNumberOfValuatorRoles () |
int | GetNumberOfButtonRoles () |
int | GetNumberOfTrackerRoles () |
std::string | GetValuatorRole (const std::string &name) |
std::string | GetButtonRole (const std::string &name) |
std::string | GetTrackerRole (const std::string &name) |
void | AddValuatorRole (const std::string &role) |
void | AddButtonRole (const std::string &role) |
void | AddTrackerRole (const std::string &role) |
void | ClearAllRoles () |
bool | SetValuatorName (const std::string &role, const std::string &name) |
std::string | GetValuatorName (const std::string &role) |
bool | SetButtonName (const std::string &role, const std::string &name) |
std::string | GetButtonName (const std::string &role) |
bool | SetTrackerName (const std::string &role, const std::string &name) |
std::string | GetTrackerName (const std::string &role) |
virtual bool | Configure (vtkPVXMLElement *child, vtkSMProxyLocator *) |
Load state for the style from XML. More... | |
virtual vtkPVXMLElement * | SaveConfiguration () |
Save state to xml. More... | |
Retrieve an annotation with a given key. More... | |
Remove a given annotation based on its key to the proxy. More... | |
Remove all proxy annotations. More... | |
Return true if a given annotation exists. More... | |
Return the number of available annotations. More... | |
Return the nth key of the available annotations. More... | |
Get/Set the location where the underlying VTK-objects are created. More... | |
Return the property with the given name. More... | |
Return a property of the given name from self or one of the sub-proxies. More... | |
Given a property pointer, returns the name that was used to add it to the proxy. More... | |
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
Recreate the VTK object for this proxy. More... | |
Convenience method equivalent to UpdateProperty(name, 1). More... | |
Returns a new (initialized) iterator of the properties. More... | |
Returns the number of consumers. More... | |
Returns the consumer of given index. More... | |
Returns the corresponding property of the consumer of given index. More... | |
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
Returns a proxy this proxy depends on, given index. More... | |
Returns the property holding a producer proxy given an index. More... | |
Updates all property information by calling UpdateInformation() and populating the values. More... | |
Similar to UpdatePropertyInformation() but updates only the given property. More... | |
Marks all properties as modified. More... | |
Use this method to set all properties on this proxy to their default values. More... | |
Use this method to set all properties on this proxy to their default domains. More... | |
Use this method to set all properties on this proxy to their default domain or values. More... | |
Calls MarkDirty() and invokes ModifiedEvent. More... | |
bool | IsDeprecated () |
Returns true if the proxy has a deprecation tag. More... | |
Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
Dirty means this algorithm will execute during next update. More... | |
Returns the client side object associated with the VTKObjectID (if any). More... | |
Saves the state of the proxy. More... | |
The iterator is use to filter the property available on the given proxy. More... | |
Loads the proxy state from the XML element. More... | |
This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
bool | GetIsSubProxy () |
A proxy instance can be a sub-proxy for some other proxy. More... | |
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
Allow to switch off any push of state change to the server for that particular object. More... | |
Enable the given remote object to communicate its state normally to the server location. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
Returns the number of property groups that the proxy contains. More... | |
A helper that makes up an default name if none is provided. More... | |
Return the property names that have values different from the otherProxy argument. More... | |
Update the value of one property (pushed to the server) if it is modified. More... | |
Returns the type of object managed by the proxy. More... | |
the type of object created by the proxy. More... | |
Copies values of all the properties and sub-proxies from src. More... | |
Returns the documentation for this proxy. More... | |
Returns if the VTK objects for this proxy have been created. More... | |
Gathers information about this proxy. More... | |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
Log name is a name for this proxy that will be used when logging status messages. More... | |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
Get the global unique id for this object. More... | |
bool | IsPrototype () |
virtual void | Modified () |
static vtkSMVRInteractorStyleProxy * | New () |
static vtkSMVRInteractorStyleProxy * | SafeDownCast (vtkObject *o) |
static vtkSMProxy * | New () |
static vtkSMProxy * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Types | |
typedef std::map< std::string, std::string > | StringMap |
vtkSMVRInteractorStyleProxy () | |
virtual | ~vtkSMVRInteractorStyleProxy () |
virtual void | HandleButton (const vtkVREvent &event) |
virtual void | HandleValuator (const vtkVREvent &event) |
virtual void | HandleTracker (const vtkVREvent &event) |
void | MapKeysToStringList (const StringMap &source, vtkStringList *target) |
bool | SetValueInMap (StringMap &map_, const std::string &key, const std::string &value) |
std::string | GetValueInMap (const StringMap &map_, const std::string &key) |
std::string | GetKeyInMap (const StringMap &map_, const std::string &value) |
vtkSMProxy () | |
~vtkSMProxy () override | |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
Invoke that takes a vtkClientServerStream as the argument. More... | |
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
Add a property with the given key (name). More... | |
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
void | MarkInputsAsDirty () |
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
virtual void | CreateVTKObjects () |
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
Cleanup code. More... | |
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
Add a sub-proxy. More... | |
void | RemoveSubProxy (const char *name) |
Remove a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (const char *name) |
Returns a sub-proxy. More... | |
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
Returns the name used to store sub-proxy. More... | |
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
Returns the number of sub-proxies. More... | |
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of consumers. More... | |
virtual void | RemoveAllConsumers () |
Remove all consumers. More... | |
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
Remove the property,proxy pair from the list of producers. More... | |
virtual void | PostUpdateData (bool using_cache) |
This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
void | PostUpdateDataSelfOnly (bool using_cache) |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
bool | WarnIfDeprecated () |
If a proxy is deprecated, prints a warning. More... | |
bool | LoadPluginIfEnsured () |
If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
virtual void | UpdatePipelineInformation () |
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
Parses the XML to create a new property group. More... | |
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
Adds a property groups. More... | |
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
Expose a subproxy property from the base proxy. More... | |
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
Handle events fired by subproxies. More... | |
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
Called to update the property information on the property. More... | |
void | RebuildStateForProperties () |
vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
Internal method used by SetLogName More... | |
bool | ArePropertiesModified () |
Indicates if any properties are modified. More... | |
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
void | SetXMLElement (vtkPVXMLElement *element) |
vtkSMProxy (const vtkSMProxy &)=delete | |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
Get the last result. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
virtual int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
Read attributes from an XML element. More... | |
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
SIClassName identifies the classname for the helper on the server side. More... | |
virtual char * | GetSIClassName () |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Static Protected Member Functions | |
static std::vector< std::string > | Tokenize (std::string input) |
Definition at line 22 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 26 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 113 of file vtkSMVRInteractorStyleProxy.h.
anonymous enum |
Enumerator | |
INTERACTOR_STYLE_REQUEST_CONFIGURE |
Definition at line 95 of file vtkSMVRInteractorStyleProxy.h.
protectedvirtual |
Reimplemented in vtkSMVRStylusStyleProxy, vtkSMVRPythonInteractorStyleProxy, vtkSMVRMovePointStyleProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRSpaceNavigatorGrabWorldStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRVirtualHandStyleProxy, vtkSMVRControlSlicePositionStyleProxy, and vtkSMVRControlSliceOrientationStyleProxy.
inlinevirtual |
Reimplemented in vtkSMVRMovePointStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRControlSlicePositionStyleProxy, and vtkSMVRControlSliceOrientationStyleProxy.
Definition at line 37 of file vtkSMVRInteractorStyleProxy.h.
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
Reimplemented in vtkSMVRGrabPointStyleProxy, vtkSMVRControlSlicePositionStyleProxy, and vtkSMVRControlSliceOrientationStyleProxy.
void vtkSMVRInteractorStyleProxy::GetValuatorRoles | ( | vtkStringList * | ) |
void vtkSMVRInteractorStyleProxy::GetButtonRoles | ( | vtkStringList * | ) |
void vtkSMVRInteractorStyleProxy::GetTrackerRoles | ( | vtkStringList * | ) |
int vtkSMVRInteractorStyleProxy::GetNumberOfValuatorRoles | ( | ) |
int vtkSMVRInteractorStyleProxy::GetNumberOfButtonRoles | ( | ) |
int vtkSMVRInteractorStyleProxy::GetNumberOfTrackerRoles | ( | ) |
std::string vtkSMVRInteractorStyleProxy::GetValuatorRole | ( | const std::string & | name | ) |
std::string vtkSMVRInteractorStyleProxy::GetButtonRole | ( | const std::string & | name | ) |
std::string vtkSMVRInteractorStyleProxy::GetTrackerRole | ( | const std::string & | name | ) |
void vtkSMVRInteractorStyleProxy::AddValuatorRole | ( | const std::string & | role | ) |
void vtkSMVRInteractorStyleProxy::AddButtonRole | ( | const std::string & | role | ) |
void vtkSMVRInteractorStyleProxy::AddTrackerRole | ( | const std::string & | role | ) |
void vtkSMVRInteractorStyleProxy::ClearAllRoles | ( | ) |
bool vtkSMVRInteractorStyleProxy::SetValuatorName | ( | const std::string & | role, |
const std::string & | name | ||
std::string vtkSMVRInteractorStyleProxy::GetValuatorName | ( | const std::string & | role | ) |
bool vtkSMVRInteractorStyleProxy::SetButtonName | ( | const std::string & | role, |
std::string vtkSMVRInteractorStyleProxy::GetButtonName | ( | const std::string & | role | ) |
bool vtkSMVRInteractorStyleProxy::SetTrackerName | ( | const std::string & | role, |
std::string vtkSMVRInteractorStyleProxy::GetTrackerName | ( | const std::string & | role | ) |
Reimplemented in vtkSMVRPythonInteractorStyleProxy.
Save state to xml.
protectedvirtual |
Reimplemented in vtkSMVRPythonInteractorStyleProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRControlSlicePositionStyleProxy, vtkSMVRControlSliceOrientationStyleProxy, vtkSMVRMovePointStyleProxy, vtkSMVRStylusStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, and vtkSMVRVirtualHandStyleProxy.
protectedvirtual |
Reimplemented in vtkSMVRPythonInteractorStyleProxy, vtkSMVRSkeletonStyleProxy, and vtkSMVRSpaceNavigatorGrabWorldStyleProxy.
protectedvirtual |
Reimplemented in vtkSMVRPythonInteractorStyleProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRControlSlicePositionStyleProxy, vtkSMVRControlSliceOrientationStyleProxy, vtkSMVRMovePointStyleProxy, vtkSMVRStylusStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRTrackStyleProxy, and vtkSMVRVirtualHandStyleProxy.
staticprotected |
Definition at line 110 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 111 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 114 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 115 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 116 of file vtkSMVRInteractorStyleProxy.h.
