int | GetControlledPropertySize () override |
virtual void | SetControlledProxy (vtkSMProxy *) |
virtual vtkSMProxy * | GetControlledProxy () |
virtual void | SetControlledPropertyName (const char *) |
virtual char * | GetControlledPropertyName () |
virtual bool | HandleEvent (const vtkVREvent &event) |
virtual bool | Update () |
| Update() called to update all the remote vtkObjects and perhaps even to render. More...
void | GetValuatorRoles (vtkStringList *) |
void | GetButtonRoles (vtkStringList *) |
void | GetTrackerRoles (vtkStringList *) |
int | GetNumberOfValuatorRoles () |
int | GetNumberOfButtonRoles () |
int | GetNumberOfTrackerRoles () |
std::string | GetValuatorRole (const std::string &name) |
std::string | GetButtonRole (const std::string &name) |
std::string | GetTrackerRole (const std::string &name) |
void | AddValuatorRole (const std::string &role) |
void | AddButtonRole (const std::string &role) |
void | AddTrackerRole (const std::string &role) |
void | ClearAllRoles () |
bool | SetValuatorName (const std::string &role, const std::string &name) |
std::string | GetValuatorName (const std::string &role) |
bool | SetButtonName (const std::string &role, const std::string &name) |
std::string | GetButtonName (const std::string &role) |
bool | SetTrackerName (const std::string &role, const std::string &name) |
std::string | GetTrackerName (const std::string &role) |
virtual bool | Configure (vtkPVXMLElement *child, vtkSMProxyLocator *) |
| Load state for the style from XML. More...
virtual vtkPVXMLElement * | SaveConfiguration () |
| Save state to xml. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
| vtkSMVRGrabTransformStyleProxy () |
| ~vtkSMVRGrabTransformStyleProxy () override |
void | HandleButton (const vtkVREvent &event) override |
void | HandleTracker (const vtkVREvent &event) override |
| vtkSMVRTrackStyleProxy () |
| ~vtkSMVRTrackStyleProxy () override |
| vtkSMVRInteractorStyleProxy () |
virtual | ~vtkSMVRInteractorStyleProxy () |
virtual void | HandleValuator (const vtkVREvent &event) |
void | MapKeysToStringList (const StringMap &source, vtkStringList *target) |
bool | SetValueInMap (StringMap &map_, const std::string &key, const std::string &value) |
std::string | GetValueInMap (const StringMap &map_, const std::string &key) |
std::string | GetKeyInMap (const StringMap &map_, const std::string &value) |
| vtkSMProxy () |
| ~vtkSMProxy () override |
void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| Invoke that takes a vtkClientServerStream as the argument. More...
virtual void | UpdateAndPushAnnotationState () |
virtual void | AddProperty (const char *name, vtkSMProperty *prop) |
| Add a property with the given key (name). More...
virtual void | MarkConsumersAsDirty (vtkSMProxy *modifiedProxy) |
| Calls MarkDirtyFromProducer on all consumers. More...
virtual void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) |
| MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More...
void | MarkInputsAsDirty () |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More...
virtual void | CreateVTKObjects () |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More...
| Cleanup code. More...
virtual void | SetPropertyModifiedFlag (const char *name, int flag) |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More...
void | AddSubProxy (const char *name, vtkSMProxy *proxy, int overrideOK=0) |
| Add a sub-proxy. More...
void | RemoveSubProxy (const char *name) |
| Remove a sub-proxy. More...
vtkSMProxy * | GetSubProxy (const char *name) |
| Returns a sub-proxy. More...
vtkSMProxy * | GetSubProxy (unsigned int index) |
const char * | GetSubProxyName (unsigned int index) |
| Returns the name used to store sub-proxy. More...
const char * | GetSubProxyName (vtkSMProxy *) |
unsigned int | GetNumberOfSubProxies () |
| Returns the number of sub-proxies. More...
virtual void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More...
virtual void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of consumers. More...
virtual void | RemoveAllConsumers () |
| Remove all consumers. More...
void | AddProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More...
void | RemoveProducer (vtkSMProperty *property, vtkSMProxy *proxy) |
| Remove the property,proxy pair from the list of producers. More...
virtual void | PostUpdateData (bool using_cache) |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More...
void | PostUpdateDataSelfOnly (bool using_cache) |
| This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
bool | WarnIfDeprecated () |
| If a proxy is deprecated, prints a warning. More...
bool | LoadPluginIfEnsured () |
| If a proxy need to ensure a plugin is loaded, make sure it is. More...
virtual void | UpdatePipelineInformation () |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More...
void | LinkProperty (vtkSMProperty *inputProperty, vtkSMProperty *outputProperty) |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More...
vtkSMPropertyGroup * | NewPropertyGroup (vtkPVXMLElement *propElement) |
| Parses the XML to create a new property group. More...
void | AppendPropertyGroup (vtkSMPropertyGroup *group) |
| Adds a property groups. More...
void | ExposeSubProxyProperty (const char *subproxy_name, const char *property_name, const char *exposed_name, int overrideOK=0) |
| Expose a subproxy property from the base proxy. More...
virtual void | ExecuteSubProxyEvent (vtkSMProxy *o, unsigned long event, void *data) |
| Handle events fired by subproxies. More...
virtual int | CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
virtual void | UpdatePropertyInformationInternal (vtkSMProperty *prop=nullptr) |
| Called to update the property information on the property. More...
void | RebuildStateForProperties () |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More...
virtual void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) |
| Internal method used by SetLogName More...
bool | ArePropertiesModified () |
| Indicates if any properties are modified. More...
void | SetHints (vtkPVXMLElement *hints) |
void | SetDeprecated (vtkPVXMLElement *deprecated) |
void | SetEnsurePluginLoaded (vtkPVXMLElement *ensurePluginLoaded) |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
void | SetXMLElement (vtkPVXMLElement *element) |
| vtkSMProxy (const vtkSMProxy &)=delete |
void | operator= (const vtkSMProxy &)=delete |
virtual const vtkClientServerStream & | GetLastResult () |
| Get the last result. More...
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLLabel (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
vtkSMProperty * | NewProperty (const char *name) |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More...
vtkSMProperty * | NewProperty (const char *name, vtkPVXMLElement *propElement) |
virtual int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) |
| Read attributes from an XML element. More...
void | SetupExposedProperties (const char *subproxy_name, vtkPVXMLElement *element) |
void | SetupSharedProperties (vtkSMProxy *subproxy, vtkPVXMLElement *element) |
virtual void | SetSIClassName (const char *) |
| SIClassName identifies the classname for the helper on the server side. More...
virtual char * | GetSIClassName () |
| vtkSMRemoteObject () |
| Default constructor. More...
| ~vtkSMRemoteObject () override |
| Destructor. More...
void | PushState (vtkSMMessage *msg) |
| Subclasses can call this method to send a message to its state object on the server processes specified. More...
bool | PullState (vtkSMMessage *msg) |
| Subclasses can call this method to pull the state from the state-object on the server processes specified. More...
void | SetGlobalID (vtkTypeUInt32 guid) |
| Set the GlobalUniqueId. More...
vtkTypeUInt32 | GetFilteredLocation () |
| vtkSMSessionObject () |
| ~vtkSMSessionObject () override |
| vtkSMObject () |
| ~vtkSMObject () override |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
