int | GetControlledPropertySize () override |
bool | Update () override |
| Update() called to update all the remote vtkObjects and perhaps even to render. More...
virtual void | SetControlledProxy (vtkSMProxy *) |
virtual vtkSMProxy * | GetControlledProxy () |
virtual void | SetControlledPropertyName (const char *) |
virtual char * | GetControlledPropertyName () |
virtual bool | HandleEvent (const vtkVREvent &event) |
void | GetValuatorRoles (vtkStringList *) |
void | GetButtonRoles (vtkStringList *) |
void | GetTrackerRoles (vtkStringList *) |
int | GetNumberOfValuatorRoles () |
int | GetNumberOfButtonRoles () |
int | GetNumberOfTrackerRoles () |
std::string | GetValuatorRole (const std::string &name) |
std::string | GetButtonRole (const std::string &name) |
std::string | GetTrackerRole (const std::string &name) |
void | AddValuatorRole (const std::string &role) |
void | AddButtonRole (const std::string &role) |
void | AddTrackerRole (const std::string &role) |
void | ClearAllRoles () |
bool | SetValuatorName (const std::string &role, const std::string &name) |
std::string | GetValuatorName (const std::string &role) |
bool | SetButtonName (const std::string &role, const std::string &name) |
std::string | GetButtonName (const std::string &role) |
bool | SetTrackerName (const std::string &role, const std::string &name) |
std::string | GetTrackerName (const std::string &role) |
virtual bool | Configure (vtkPVXMLElement *child, vtkSMProxyLocator *) |
| Load state for the style from XML. More...
virtual vtkPVXMLElement * | SaveConfiguration () |
| Save state to xml. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
