virtual vtkSMProxy * | GetContextItemProxy () |
| Get Representation Proxy. More...
bool | LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup) |
| Called to link properties from a Widget to controlledProxy i.e. More...
bool | UnlinkProperties (vtkSMProxy *controlledProxy) |
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
